Question about HP Pavillion ZV6000 Athlon 64 3500+ 15.4in WideScreen w/ 512MB/80GB/DVDRW/Flash Slot (PCLHCA6435512WWD) PC Notebook
The computer still works, just the screen keeps getting darker and darker.
  • 4 Answers
Check and see through hp if there is a driver that might have been installed from microsoft that caused this problem. if the drivers where changed put them back to the original drivers. if this started to happen after an update. check your update settings and turn off the automatic update from microsoft. it is some times better to see what upsdate is being installed before you let it.
Posted on May 15, 2010
I get an intermittent shadow on the left-side of myscreen. Computer works fine, except at times I have the shadow.
If you mean that the left side of the screen goes darker than the right side, then this is an indication of a faulty backlight. There are probably two CCFL tubes, one on each side of the screen. If one starts to fail, then that side of the screen will get less light and look darker. The tube may need to be replaced.
May 25, 2011 | Acer Aspire One PC Notebook
The laptop screen freezes and fades out slowly becoming darker and darker. Moving the screen however helps restore it back to life for a short while
Hello
Ok, because the screen gets better for a little while if you move it, this might just be a simple connection problem. The thing is, and it is quit common on notebooks, is that the data cable linking the screen to the motherboard sometimes get a little loose. Hence, the screen still works, but not properly.
I would suggest that you open up the unit and just make sure that the data cable is plugged in correctly. If you do not feel comfortable doing this yourself, you can take it to your nearest computer repair shop.
Hope this can be of help.
Kind regards
Andrea
Aug 27, 2010 | Acer Extensa 4620 Notebook
I'm tring to restore original settings on my LG monitor and keep getting "osd lock" message. Half my monitor is very bright, the other half it 10-15 shades darker.
I held the "Menu" button down for 15 sec. and it unlocked. Then used the Auto Set feature. It didn't work immediately on the two-towned
screen, but corrected itself within 1/2 hr.
Thank you.
Feb 08, 2010 | LG 22" FLATRON LCD Monitor
Laptop screen keeps getting darker
Is it happening when u do not use the laptop for few minutes??
Or it could be something to do with the power on the battery which is reducing due to usage. Screen would get darker to make optimum usage of battery and give longer back ups.
Jan 26, 2009 | Computers & Internet
The bottom of the screen has become darker!
Hi
The symptom you are telling is similar to FL inverter problem but with that case usually entire screen goes dim. You may try to reset the settings (Usually AUTO button). Unplug and plug in the electrical connection+Computer connection. Also make sure your Display setting in computer side has not been modified. If issue persist take to the qualified service center. FL inverter is the illuminator part of LCD works like fluorescent tube. FL inverter issue rather lower cost compare to other LCD issues.
Good Luck Happy New Year
Dec 28, 2007 | Samsung SyncMaster 171S 17" Flat Panel LCD...
Lg 1919s flatron monitor slowly gets dark
This problem is showing when the main PCB of the monitor failed. Contact the LG service provider in your area. They will change the full package assembly or PCB. check this link to get the service center info
http://www.lgservice.com/
Dec 13, 2007 | LG L1915S 19" LCD Monitor
Tv screene getting darker and darker
Caps in high voltage needs changing, needs tech
Aug 19, 2007 | Maxent MX-42VM 42 in. Plasma HDTV
Apple 30 inch monitor
Sounds like a possible bad pixel. I would power the machine down, reseat the graphics card, reconnect the dvi link, and reset the PRAM.
Keep me posted.
Nov 14, 2006 | Apple Cinema HD 30" LCD Monitor
HP Pavillion ZV6000 Athlon 64 3500+ 15.4in WideScreen w/ 512MB/80GB/DVDRW/Flash Slot (PCLHCA6435512WWD) PC Notebook Logo
54 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
