Question about Dishwashers
Upon start water does not go in - Dishwashers
  • Dishwashers Master
  • 43,501 Answers
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
Dishwasherupon start water  does not go in - 2_bing.gif Trouble No Water entering Dishwasher2_bing.gif
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Posted on May 15, 2010
Loud backfiring noise upon start up.
the main jet is open before the pizo starts
for safety sake have a gas fitter look at it
May 23, 2015 | A.O. Smith BTH-199 BTH-199 100 Gallon...
Upon starting a loud whining sound as you accelerate - cause$
Belts slipping . Or bearings on water pump . Spray some belt dressing on main drive belt a see if it changes or goes away. If so change the belt , easy to do. If not then it's a new water pump needed
Feb 23, 2015 | 2007 Honda Pilot
My Husky Pressure Washer bogs the motor down immediately upon start.
Rebuilding the pump is not easy. Did you use the right seal drivers? Lube the seals when you installed them? Use a torque wrench? But a valve in backwards?
May 04, 2013 | Garden
Why is there a gurgling sound upon starting and the antifreeze blows out
Check head gasket. Pull spark plugs and perform compression check? Check plugs for fouling. Check engine oil for water/antifreeze
Hope this helps?
Jun 20, 2017 | 1999 Mercury Grand Marquis
2006 cts, several times now after washing vehicle the car stalls out, idles ruff then stalls upon starting. then car wont start at all and when trying to start car the electronic ignition keeps rolling...
water is getting into the harness connections for the ECM
use water displacer ( wd-40 or the like ) after a wash or find where the water is affecting and use a spray wax to cover all of the electrical connections
Apr 25, 2017 | 2006 Cadillac CTS
My dishwasher no longer cleans my dishes and white spots remain even when jet dry is being used.
Dishwashers rely upon water circulation. Make sure there is nothing blocking the pump receiver at the bottom of the washer, like paper labels from gars, or large food pieces. It also relies upon the proper amount of water in the washer. After the washer fills and starts its cycle, squeeze the handle to open the door but do not open the door until all the sound has stopped. The water level should be visible and close to the top edge of the basin. Don't worry, opening the door after the pump has stopped will not spill water on the floor. If the water level is good and you are sure there is nothing blocking the pump receiver, check the stem in the center of the basket.
Sep 20, 2010 | Dishwashers
GE Dishwasher no water upon start, humming, blinking lights
Seems like the anti flood is activated when water (even a small amount) appears on the bottom of the machiene. This is usualy a leaking pipe but can also be caused by a clogged pipe. Most machiens do have a plastic pipe that (from the flat water tank) feeds water to the bottom of the machiene in case of an internal fault. The anti flood is normaly a polystireen float with micro switch on the base of the washer. This automatically puts the outlet pump on to drain the water. The machiene does not work exept the outlet pump in this mode.
Jan 18, 2010 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
