Question about Dual Car Audio & Video
My car amp wont power up any more
By accident i hooked up the ground and the positive backwards to my amplifier
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 35 Answers
Either an external or internal fuse is blown on the amp or the fuse by the battery is blown. If that's not the case your amp is done
Posted on May 15, 2010
I have a pioneer GM-X524 amp connected to a TS-W253C subwoofer and it isn't working. It has 12v power to it and a solid ground, but the power light wont come on and the sub isnt working
there should be 3 power related cables connected to the amplifier:
1-From battery to amp via fuse (positive)
2-From chassis of car to amplifier (negative)
3-From head units (power continuous) (blue or blue/white cable) to the amplifiers remote connection.
this connection enables the amplifier to switch on when the head unit is switched on and off when the headunit is switched off.
I hope this helps and let me know if I can further assist you.
....andy....
Jan 06, 2014 | Pioneer Car Audio & Video
My power acoustic protection light stays on i got good ground and a good positive connection, no speakers or RCA's hooked up, what could it be
Are you fused close to the battery with a 30-50 amp fuse block?
Ground unit also to most closest suitable location!
Is your power wire undersized?
Check units fuses you may have blown one hooking it up!!
Good luck
Feb 15, 2011 | Power Acoustik LT-1920/2 Car Audio...
I have the am hooked up correctly but it wont work.
its a good idea get vom and start from power ant coming from head unit ussually 13.80 volts to the trigger of amp also check battery power to be present on power terminal (13 volts)positive. also getting a good ground connection , again digital or analog volmiter get the difference.
Nov 24, 2010 | Jl Audio E1200 Car Audio Amplifier
Blow out amp
try a basic connection connect
positive from car to positive of amp
ground to ground
and positive of car to remote of amp
see if it turns on
also check the fuses in the car
check for voltage on the wires
May 15, 2010 | Performance Teknique ICBM-782 Car Audio...
My kenwood amp wont turn on all the way i just hooked it up to my truck. the blue lights and the fan come on but the red light wont come on to power my subs
REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL DOES NOT POWER UP, VERIFY THAT THE POSITIVE AND ESPECIALLY THE GROUND CONNECTIONS, ALONG WITH THE REMOTE CONNECTIONS ARE 100%, THEN TRY AGAIN. IF STILL NOT POWERED UP, MEASURE THE REMOTE WIRE VOLTAGE TO INSURE THAT IT IS NOT LOWER THAN 11 VOLTS. IF YOU CANNOT MEASURE IT, THEN DISCONNECT THE REMOTE LEAD FROM THE AMPLIFIER AND TEMPORARILY INSTALL A JUMPER WIRE FROM THE POSITIVE POWER TERMINAL TO THE AMPS REMOTE TERMINAL WHICH WILL FORCE IT TO TURN ON. IF IS STILL DOES NOT POWER UP, THEN IT WILL HAVE TO BE SERVICED. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Nov 20, 2009 | Kenwood KAC-7203 Car Amp
Amp gets power but doesnt send anything through speaker wire
There are several things that could cause this that i know of, bad ground not being one of them.
A bad ground terminal should cause a noticeable distortion in sound and cause the amplifier to turn on and off.
If you are getting power and no sound, the first and easiest thing i would check is your RCA wires. Replace them with known good wires.
If that does not work, are you positive the speakers you have hooked up to your amplifier are not blown?
If available, use a DVOM to check resistances on the coils on your speakers. An open lead reading indicates a blown voice coil.
Also make sure that your speakers are each hooked up to a positive and negative terminal, as some amplifiers have two positives next to each other and two negatives, while others go + - + -.
Your amplifier could also have bad input or outputs, but i would try these other easy fixes before resorting to buying a replacement amplifier.
The only other cause to my knowledge would be bad RCA outputs on your head unit.
If possible try with a head unit you know the outputs work on.
Hopefully one of these suggestions solves your problem.
Dec 16, 2008 | Alpine MRP-M350 Car Audio Amplifier
No power to pioneer 5300 amp
ur remote wire needs to be hooked up to the spot marked remote on the amp....and ground to the ground slot..if that is done check the fuses on the amp or check the fuse under the hood from your power wireif it still wont come on..make sure ur ground is touching a good metal area sand around the area if needed this should sole ur problem
Jul 27, 2008 | Car Audio & Video
POWER
Have you connected the remote wire from the stereo to the amp? assuming it has one.
If the stereo has not got a remote wire you can link it from the positive 12 volt on the amp to the remote connection on the amp, usually it's in between the ground connector and the 12volt.
Mar 22, 2008 | Lightning Audio LA1.300.2 Car Audio...
Car Audio & Video Logo
340 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
