Question about Konica Minolta magicolor 5440 DL Laser Printer
What does trans roller low mean - Konica Minolta magicolor 5440 DL Laser Printer
  • Konica Minolta Master
  • 5,479 Answers
The transfer roller is near the end of life; you need to prepare a new transfer roller. The printer will tell you when by changing the message to trans. roller end. The directions start on page 76 of the user's guide. http://printer.konicaminolta.com/support/current_printers/mc5440dl_sup.htm for the PDF You'll need to reset the counter as well when you insert the new roller. Other consumables may also be nearing the end of life (like the transfer unit itself). The manual has details for checking their status. Get the appropriate parts from the company (or a third-party vendor).
I hope this helps.
Posted on May 15, 2010
Just bought 98 taursus did routine fluid check transmission fluid show to be dry even after i puy 2quarts in what could problem be
Be sure you have the correct dipstick
Engine should be running and warmed up
The trans can be a couple quarts low and still operate
You may still need more trans oil
You should check for evidence of leakage
Try and look under the car for dripping or wet areas
Being low on transmission fluid means there is a leak somewhere
If you don't see any evidence of leakage then make sure it is full and drive and monitor the oil level - i.e. check after each trip
You need to get an idea of how fast the leak is - you don't want to get stuck some where being too low on trans fluid
Does that help?
Apr 19, 2015 | Cars & Trucks
WHAT IS P2780
you did not ask a question, why is that? just a code.
which trans, regular or CVT? there are 3 transmissions. and m/t
the Trans chapter shows 7 trans. and 4wd options.???
VIN code A,C or G? (tranny code is in VIN)????
p2 is a factory only code.
Downshift Switch Circuit Low are asking how to do all the FSM steps. to diagnose this.?
you reset it and it came back
are there driving symptoms??????????
the set is.
P2779 Downshift Switch Circuit Range/Performance
P2780 Downshift Switch Circuit Low
P2781 Downshift Switch Circuit High
P2782 Downshift Switch Circuit Intermittent/Erratic
the key to understanding the cause is to understand the test.
how is the test done, (monitors) and what does it actually measure.
a real fsm will tell you if the LOW means, voltage at solenoid is low.
or RPM was too low.
see?
and is key to the cause.
i dont have the real FSM, and online shows nothing.
Jun 23, 2014 | 2011 Ford Fusion
What does transmission performance low mean?
Stop using it for sure, with any trans issues
All you can do, is go to a repair or trans shop
for advice
May 10, 2014 | 2007 Volvo XC90 V8 AWD Sport
My '04 Acura rsx jerks when accelerating from a stop.
1ST THING YOU NEED TO DO IS CK TRANS FLUILD ON FRONT SIDE OF TRANS AND MAKE SURE IT IS NOT LOW,AND MAY ALSO START BEING SIGNS OF TRANS ISSUE,NEED TO HAVE CK BY TRANS SHOP IF FLUILD IS NOT LOW SO YOU WANT DO ANY MORE DAMAGE IF CASE OF TRANS ISSUE,HOPE I WAS A HELP
Jul 29, 2012 | 2004 Acura RSX
Trans slipping
CHECK TRANSMISSION FLUID LEVEL.MAKE SURE FLUID LEVEL NOT LOW.IF FLUID LEVEL OKAY BUT TRANSMISSION FLUID LOOK DARK HAS BURNT SMELL CHANGE TRANSMISSION FILTER + FLUID.IF FLUID AND FILTER HAS BEEN CHANGED YOU HAVE THE RIGHT AMOUNT FLUID IN TRANSMISSION AND MANUAL SHIFT LINKAGES PROPER ADJUSTED.CHECK TRANSMISSION FUSE AND SCAN FOR PRESSURE CONTROL SOLENOID VALVE MALFUNCTION FAULT.IF ALL IS GOOD HAVE TRANSMISSION OIL PUMP PRESSURE TEST.YOUR PUMP COULD BE FAULTY OR YOU HAVE WORN LOW ROLLER CLUTCH AND WORN FORWARD CLUTCH PLATES AND LEAKING FORWARD CLUTCH PISTON SEALS.
Jul 10, 2010 | 1999 Oldsmobile Alero
I changed my trans roller on a magicolor 5440DL printer but the message 'trans. Roller low' is still appearing on the screen have i installed it incorrectly?
You can reset the transfer roller counter under the menu for the printer. To do this:
1. Press menu.
2. Push the right arrow twice to get to "Engine"
3. Verify Engine is the option displayed and press select/enter.
4. Scroll through the menu until you see "Engine Service". Press select.
5. Scroll to "Reset Counter Transfer Roller". Press select.
After pressing Select on step 5 it appears to run a calibration (at least it did on mine.) But the message should be gone after that. The counter for the transfer belt is also here. Please be sure not to reset the wrong one.
I hope I've done a good job answering your question. If you have any additional questions I will do my best to answer them. If my answer was helpful for you I'd appreciate a 5 thumbs up rating, or a click on the yes this was helpful button. Thank you!
May 21, 2010 | Konica Minolta magicolor 5430 DL Laser...
My a604 transmission wont shift into 3rd or overdrive.
You may be low on fluid, so check that first, after driving a bit and getting the trans up to operating temp. If it is low, fill it with the proper type of trans fluid and then see how it operates.
Check it with the motor running, gear in park and parking brake on. If that is not the culprit, it could be a solenoid or other fault that is causing the trans to operate in "limp mode" meaning it will only allow first and second gear to get you home.
Nov 24, 2008 | Chrysler Voyager Cars & Trucks
Will Not Shift Into Overdrive.
I have Kia spectra and it just not change to low gears when scan it shows Trans. Sensor abnormal'
where can i find this Trans Sensor ? (I mean which place it fix in the car)
Sep 22, 2008 | 2003 Kia Spectra
Transmission Problems
code P0700 means that there is a code in the trans controller. P0605 means there is an internal failure in the trans controller that can not be repaired. The only step in checking this code is replacing the trans controller. The controller is not the solenoid pack . Its the actual transmission computer.
Aug 10, 2008 | 2001 Chrysler Town & Country
Konica Minolta magicolor 5440 DL Laser Printer Logo
400 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
