Question about Toshiba Axiom 80GB kit for Tecra 9000 Portege 4000 Slim Select Bay (AXT2480) Hard Drive
Display of error message 5001 on Tec Toshiba SL-9000 Electronic S
I bought a used tec toshiba electronic printing scale sl-9000 recently and it worked perfectly well at the supplier's shop. however, the scale was delivered to me two weeks after. after unwrapping the package and plugging it to the electricity mains, the tower display came with an error 5001 and a buzzer (kind of audible sound) went off. this has remain constant on the display while the scale will not respond to the pressing of any key.
Please help come up with a solution.
Regards,
Bode
Benimur
  • 6966 Answers
SOURCE: I'm using a toshiba 4300 satellite pro 4300 series laptop, i don't know how to dim the screen. i've tried pressing Fn and various F keys to no avail. Please don't reply in computer language because i'
Hi. According to the user manual, the Fn + Esc (key)displays the screen brightness pop-up window which are: super bright; bright and semi bright. You may want to check out Toshiba 32-bit Online User's Guide for Satellite Pro 4300 Series (5790)at http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlViewDL.jsp?soid=107128&moid=1073769765&BV_SessionID=@@@@0579949615.1140817607@@@@&BV_EngineID=cccfaddhdidhgdecgfkceghdgngdgmm.0&ct=DL. Hope this works out ok for you. Regards.
Posted on Apr 09, 2007
  • 1019 Answers
SOURCE: Toshiba Hard Drive Crash
if the datas aleady deleted, then you have nothing to lose. Right ?
What you need is a 2.5 to 3.5 inch IDE ribbon cable connector.
this will enable you to put the drive into an IDE slot on the PC internal motherboard ( primary/secondary )
Unless it,s already 3.5"
boot the computer, see if it recognises the drive. And format it.
then you may be able, to re-fit back into the external casing, and use as an external again.
Mike @ compurepair.
Posted on Feb 25, 2008
iqbal_del
  • 655 Answers
SOURCE: change display from portrait to landscape
see on icon tray there will be an icon for you monitor.
Right click on it, it will pop-up a menu, Navigate 'Rotatio' and select 0 degree. Then it will be back as usual.
Thanks
iqbal
Posted on Mar 09, 2008
s4u311
  • 813 Answers
SOURCE: sound/audio drivers for toshiba 1415-s173
please tell me model no of ur laptop
Posted on Mar 30, 2008
SOURCE: We just purcased Toshiba 26AV502U, now the screen is blank
Heard back from Toshiba. They said to unplug the TV, wait at least 3 minutes, and then plug it back in. This should allow it to reset itself. Sounded too simple, but after doing just that the tv has worked fine for the last three days! Toshiba noted that if this didn't resolve the problem we should contact them to have a Toshiba Authorized service person come check out the tv. It worked for us, hopefully it'll work for you too. Good Luck
Posted on Apr 25, 2009
Does anyone know how to rectify the TEC B-SX4 head temperature error? it's the correct version printhead for the model of MLB and the correct firmware, but problem still exists.
This excess temperature may be caused by a temperture detector.
Ther are two detectors on a Toshiba Tec Printer.
- On the print head.
- In the top part of the label sensor mecanism.
You cna check if they are working when going in the adjust set parameter setting.
You can read Head temp and air temp
If one of them is not working you will not be able to adjust the temperature. Worst you'll have the message Head excess temperature message.
Oct 23, 2013 | Toshiba TEC B-SX4 Thermal Label Printer
Toshiba TEC B-472 printing only top half of label
Perform hard reset of electronics and also re install the driver.
Sep 17, 2017 | Toshiba TEC Office Equipment & Supplies
TEC 21 SL calibration
I have a tech sl 21 on the start up the number displays just keep flashing and it wont stop help please
Feb 15, 2012 | Taylor 5757 Digital Glass Body Fat Scale
Tec B 452 error 482 run time error, printer error
This is a problem with windows error 482 is probably a problem with activeX
Jan 04, 2012 | Toshiba TEC B-452 Thermal Label Printer
I am testing an aold B-572 printer. If I print one label it works allright, if I choose to print multiple labels, after the first label I get a ribbon error message with the remaining prints to do. If I...
Check:
- The value of the Rbn adj Fwd and Bck value.
Check that you are in thermal transfer mode in the driver.
Check if yu don't have dusts on the synchro wheels (You have to open the printer electronic cover.
Apr 18, 2011 | Toshiba TEC B-572 Printer
My scale starts out with 7.2 instead of 0.0
try removing battery if this does not work you have a faulty weight sensor
May 10, 2010 | Taylor 5757 Digital Glass Body Fat Scale
The 'eye' won't read the space between the labels,
recalibrate the sensors and check your label lengths and gap size
Mar 31, 2009 | Toshiba TEC B-472 Thermal Label Printer
RIBBON ERRORS
Ribbon error message is displayed when the rotation of the ribbon spindle is not performed or not correctly detected. This can be due to various factors.
- The ribbon roll is not correctly fitted to the spindle.
- The sensors detecting the rotation are out of order or completetly filled with dust or grease.
In this case clean the sensors.
Another reason may be due to Direct thermal printing with a ribbon mounted.
Mar 02, 2009 | Toshiba TEC BSX5 Thermal Label Printer
Open Questions:
Cloud Backup For Small Business 'Dataalign We understand the difficulty of reaching a great quality tech support at time. We all have gone through the phase of struggle when we have to look for reliable tech support in affordable prices. Toshiba support is now available at just a click away or just a phone call away on toll free helpline number. Toshiba support by well-informed and erudite experts who have made it a mission of their lives to provide best tech support for their customers. Customers have shown over whelming response to Toshiba tech support as it a one and only needed platform for all tech issues faced by the customers ever. Toshiba support provided by TechFree has always gained appreciative remarks from customers. They have always been praised for their hard work and dedication over the years which has resulted them in gaining a lot of fame for their work. Toshiba customers face many type of issues like dealing with their slow performing Toshiba devices, treating issues faced in Gmail, yahoo or any other email supporting site, networking issues, software not working issues, issues with viruses, malwares and issues in printers, routers or other relatable peripheral devices. These issues and many more are professionally resolved without much delay. Tech support professionals of Toshiba support use their knowledge and experience of years and together with highly advanced technologies to resolve issues of their customers in the right way. They get highly acclaimed by their work and the way they treat their customers with respect and courtesy. They make sure to patiently listen to their customer's issues in order to be able to understand the issue in depth and provide right type of support for longer lasting effects. Tech support of Toshiba can be reached via the toll free helpline number +1 888 784-9316 and they assure to be assisted by expert tech support executives. These executives work 24/7 throughout the year. They also provide 30 days money back guarantee and free device check-up along with free online data backup. For any type of tech support or computer repair services at any time of the hour call on toll free helpline number +1 888 784-9316
Jul 05, 2018 | Toshiba Computers & Internet
Toshiba Axiom 80GB kit for Tecra 9000 Portege 4000 Slim Select Bay (AXT2480) Hard Drive Logo
401 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
