Question about Pentax *ist DL Digital Camera
Pentax istd built in flash goes off when taking picture but picture is underexposed but if I use a different flash in manual mode the camera works ok
    Problem Solver:
  • 12 Answers
What distance are the subjects when using the built-in flash?
The built-in flash is optimized for use between 0.7m (2.3ft) and 4m (13ft).
You could also try adjusting the ISO setting (higher ISO requires less light) or adjusting the EV value to a positive number to increase the exposure.
Posted on Sep 03, 2010
Overexposure unless in manual mode
Is your "exposure compensation" (the button with the +/-) set to "0" or some other setting?
Feb 10, 2010 | Pentax *ist DL Digital Camera
Using a 500mm fixed aperture lens on a Pentax ist
Use "exposure compensation" (the button with a plus/minus symbol). It allows you to lighten (toward the + side) or darken (toward the - side).
Nov 15, 2009 | Pentax *ist DL Digital Camera
Pentax istD won't take pictures
i found this which seems similar
http://www.pentaxuser.co.uk/forum/topic/ist-D--HELP-444/p-0#comm_2164
"I know this is late, but the issue sounds to me like the aperture ring is not on A. and if this is a manual lens then you have to set the mode to hyper-program mode and set it to work with "other than A" on aperture."
this was my issue, i never knew that has i bought the camera 2nd hand without a manual - your issue might be something else but it's worth posting just incase
Mar 26, 2008 | Pentax *ist D Digital Camera
Nikon D50 flash not synchronizing
Ok this is a crappy fix but it works for me.
If your flash isn't syncing correctly make sure your on auto flash. when your flash flips up and you get the beep push the piece that holds the flash just a little forward. and walla your flash syncs up.
Sep 25, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
*istD pop-up flash problem
Not sure if you try fresh Alkaline battery. Try it if you havn't already. Fully charged batteries, how do you know it fully charged? The "charger said so"? Your batteries or charger might give you a fault peak reading. Try fresh battery or AC adepter and go from there.
Sep 08, 2005 | Pentax *ist D Digital Camera
Flash problem
That is normal operation, if poped up, the flash fires rapidily in low light to assist the auto focus, on a plain white wall, it can't focus, see the manual on AUto Focus limitations.
Sep 08, 2005 | Pentax *ist DS Digital Camera
Exposure problem
I've found that the *istD underexposes ( as it should metering 18% grey ) light subjects, or with light backgrounds. A white wall using TTL ( AF500ftz ) behind any subject it always turns grey! You need to manually adjust 1 stop over. With dark subjects, overexposing with out blowing out much. If your used to the metering from a PS digi cam the *istD takes a bit of getting used to.
Portraits underexposed
Whenever you are taking pictures of people within six feet of them, it is a good idea to turn on the flash - whether you are indoors or out. The Flash mode is easily accessed via the arrow pad on the back of the camera. Press the right arrow key, which has a lightning bolt icon, to enter the Flash Mode. Press the down key to select the lightning bolt icon and press “OK”. The flash will fire every time in this mode. Your outdoor pictures of people should improve in appearance since the flash will fill-in shadows normally apparent in outdoor shots.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
Outdoor portraits underexposed
Whenever you are taking pictures of people within six feet of you, it is a good idea to turn on the flash whether you are indoors or out. The Flash mode is easily accessed via the arrow pad on the back of the camera. Press the up arrow key, which has a lightning bolt icon, to enter the Flash Mode. Press the down key to select the lightning bolt icon and press “OK”. The flash will fire every time in this mode. Your outdoor pictures of people should improve in appearance since the flash will fill-in shadows normally apparent in outdoor shots.
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Pentax *ist DL Digital Camera Logo
81 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
