Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
Screen on off often for no reason
Screen cycles off and on about every 60-70 minutes, does not show any loss of signal, overheating?? no off long enough to cool down, memory glitch?
  • 178 Answers
There are some common problem for this model:
1. Power cycles on off with no error codes. (not screen on off) G1 board failure. Part # 1-468-980-12
2. LVDS cable failure my cause picture comes and goes. Part # 1-832-470-11
This information reference Sony tech support.
Posted on May 15, 2010
Second level tv has a signal but the main tv on first floor has no signal.
Hello! It sounds like there are a few things that could actually be going on. If you are getting no picture on the TV(you have a black, blue, or snowy screen), you will want to make sure that the TV is on the correct channel and/or input. You will want to be on channel 3 or 4, and possibly on a Video 1 or 2 or HDMI 1 or 2 input. If that doesn't work, then try unplugging the receiver from the power source for about 10 seconds. If you are still not getting a picture, let me know!
If you have a signal loss message on your screen (Signal has been lost, Partial SIgnal loss, COmplete signal loss, or Acquiring signal), you will first want to unplug the receiver from the power source for 10 seconds. You will get the Acquiring singla message as the receiver reboots after you plug it in, but that should only be about 5 minutes at the most. If you get the message after 5 minutes, you will want to make sure that all of the cables going from the back of the receiver to the wall are tight. If that still doesn't do it, please let me know!
Becki Barned
DISH Network Customer Service
becki.barned@dishnetwork.com
Jul 13, 2011 | DISH Network ViP622 DVR DTV Receiver /...
Engine overheated because of radiator hose clamp loose (5 Minutes) Loss of engine power after +- 2 weeks Suspect head gasket or damaged vacuum signal rubber piping near engine block Kia Sportage 2000
5 minutes is a long time to drive a car with no coolant. Does the engine run rough, or miss? Or is it just sluggish and low on power? If it got hot enough, there could be permanent damage to the engine. Overheating can cook the engine oil into a gummy sludge and loses it;s lubricating properties.Check for signs of coolant in the oil. That would indicate a head gasket failure or a cracked head.
Dec 22, 2010 | 2000 Kia Sportage
The projector powers up but turns off after 1-2 minutes
There ar a few reasons that will occur. The main two are,
If there is no signal and if it is overheating.
If there is no signal. that is an easy fix and so is the overheating.
Consult your instruction manual and remove the filters, clean the air intakes and filters and refit the filters.
Hope that helps.
Nov 09, 2010 | Sanyo Office Equipment & Supplies
My ps3 its not playing games or movies.i think the reason why is because i moved it while playing a movie. now is making a scratching noise.do i need to sent it for repair.can i get your expert opinion on...
You may have to try the power cycling procedure more than once before it is accepted. Try power cycling it by unplugging it & waiting a minute or 2, put the plug back in, press and hold the power button until you hear 4 beeps (1-1-2). As soon as it ends the 4th beep take your finger off the button. It should show a screen that says something like "attach the usb cable to your PS3 and the controller". Once you do that, just follow the online prompts. BE WARNED: THIS PROCEDURE MAY RESULT IN THE COMPLETE LOSS OF ALL SAVED GAMES, DEMOS, & ETC. Hopefully following these steps resolves your problems. Please leave feedback and a rating vote on this information I've provided.
Aug 19, 2010 | Sony Playstation 3 (PS3) Console
I am having problems getting conected to the internet on a daily basis.When it happens the orange light on the router is flashing. Checked all connections each time & all seem ok. Please advise.
I would contact your internet service provider. There is likely something wrong with your line that is causing your router to loose signal. I don't know what type of router you have, but a loss of signal usually causes that. There are other reasons, such as, your modem is going bad, your cable from the modem to the router has an internal break in a wire, your router could be going bad as well. Try power cycling both your model and router. You can do this by unplugging them for a couple of minutes and them plugging them back in. Plug in the modem first and wait a few minutes, then plug in your router and wait a few minutes, then try getting on-line. If this is a persistent issue even after doing all of this and contacting your ISP, then I would conclude that your hardware (modem, router, &\or ethernet cables) is giving out on you.
Mar 26, 2010 | Computers & Internet
When I charge the phone it tells me on the screen no signal
This is a minus point with your hand set. it will show the same message because while charging its connectivitydecreases and to avoid loss it starts showing NO Signal...
Sep 22, 2009 | Vtech 2432 Cordless Phone
''no signal'' message on blue screen after watching for 10-30 min
First try another signal input like a DVD player or other source, is the signal displayed ok? Then you have lost the signal on one input from whatever the device is.
Mar 16, 2017 | Spectroniq PLTV3250 32 in. LCD TV
Keeps on d/c
You need to access the modem setup screen and see what the signal and signal to noise ratio is. The reason most modems drop the connection is because the signal gets weak. Since you are using cable, any connections to that cable cause it to lose signal. If there are splices, or splitters before that modem, each one can cause a 3 dB or more loss and 3dB in half your signal. When the signal drops past a specific level, the modem cannot use it and cuts the connection.
Sep 01, 2017 | Toshiba DOCSIS Cable PCX2200 (DAZ8817F-R)...
Sirus radio
I had to replace my Sportster because it was overheating and caused it to loose signal.
Jul 12, 2007 | Jensen JXM900CMB Satellite Radio Receiver
Sony KV-32S25 loss of picture and sound
The set might have loose conections in the horizontal drive circuit and other overheated places in the power supply,dont use the set like that or it wii die completly and it will be more expensive.Call a technician so he can resoldered all the bad and questionable solder conections.Be safe and let a proffessional do it.Good day.
Sep 13, 2006 | Sony KV-32S25 32" TV
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
211 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
