Maytag performa. wtaer will not drain.machine will not wash or spin
  • 10,319 Answers
The motor ia attached to the transmission. This is called a direct drive system. Between the motor and the transmission is a coupler. The coupler has sheared apart causing your problem. The coupler is very inexpensive although it will take a little muscle to replace
Posted on May 15, 2010
Maytag Performa washer will not spin
Typically when the washing machines wont spin it's off the belt. I havent done this myself, I usually have a technician come out to take care of it.
Apr 16, 2013 | Maytag Washing Machines
I need to know how a maytag performa pavt-1 washer drains. does it drain beneath the agitator or through the holes in the basket?
It drains through the holes in the plastic tub. You may hear a sloshing sound when you move the tub and this is normal. There is a solution sealed inside the tub on this unit to balance out the spin cycle.
Sep 01, 2011 | Maytag Performa PAV2200
Maytag performa PAV2300AWW does not spin (wash cycle works fine). During the spin cycle the tub does not rotate...but i can hear the motor running...water drains...Pls help
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Maytag PAV2300 Top Load Washer
Maytag Performa agitates, but wont spin corectly.
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 07, 2010 | Washing Machines
Maytag Performa Washer PAV1000AWW. Shakes when spinning out
My washer doesnt drain in the rinse cycle?? dont kno what to do
Feb 15, 2010 | Maytag Performa PAV2200
I have a maytag performa it wont run the cleaning cycle and wont pump out wtaer
check your motor coupling,it could have broken,if you hear the motor running but no agitation i'm sure it has broken. cost about $20 between motor and transmission
Jan 09, 2010 | Maytag PAV2300 Top Load Washer
Maytag performa mod#pav2200aww leaking between rinse and spin cyc
My Performa started leaking from the Drain Pump rubber gasket. It had dryrotted. However, Maytag doesn't make a replacement O-ring gasket. You have to buy the whole new pump! Thanks Maytag.
Jul 05, 2009 | Maytag PAV2300 Top Load Washer
Washing machine
check your belt...first ,,if good check your pump..1 of theses parts are defective...onthejob
Jan 19, 2009 | Maytag Performa PAV2200
Washing Machines Logo
59 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
