Question about Bang and Olufsen Beosound 2000 Shelf System
How to remove the Beocenter 7002 tape deck
Where can I find step by step instructions for removing the Beocenter 7002 tape deck? How many belts are needed and what are the belt sizes?
Thank you for the previous answer beodude.
howdo
2 Suggested Answers
  • 122 Answers
SOURCE: Beocenter 7002 tape deck starts and clicks off within 2 sec.
If the take-up spool (r/h) doesnt turn the autostop will activate.Both these spools get clogged with old grease with age, remove and clean/regrease them,check all belts while apart and replace any limp ones.Removing the tape deck requires some knowledge.
Posted on May 14, 2010
KX-710 belts
There are no instruction manuals on how to get to belts- it is an experience thing that comes from working on the bench as you repair these decks. In 42 years I have never seen a step by step instruction on how to replace belts.
Feb 09, 2014 | Kenwood Audio Players & Recorders
Replace a Tape Deck Belt
. Remove top lid (4 screws on the side)
2. remove the back plastic mount on the mechanics (2 pink long screws on the top). The bottom are two plastic hook lock. The mount pulls back and the belt and pulleys are exposed. NOTE: It is the mount you are removing, not the tape deck itself.
Jul 05, 2008 | Audio Players & Recorders
Instructions for Teac Tascam 32-2B belt replacement. I have had this Reel to Reel Tape Recorder for a number of years and the belts have now perished. I have purchased replacement belts on ebay but could...
Ebay is the worse place to get belts- why do I know this? Well, as a servicer I am constantly replacing belts that are from E bay when clients can not get their decks to work with those wrong belts. While the counter belt is not critical the capstan belts are in a dual capstan system. The 32-2B is a X10 derivative so it will need proper servicing to work well. I am in the Chicago area and work on decks all the time as Skywave Tape Deck Repair just google it.
Mar 19, 2011 | Teac Audio Players & Recorders
Instructions to replace belts on teac cx650r stereo cassette deck
The replacement of belts on any deck requires you to dismount the transport section and take thrust plate off as well as other mechanical parts to get to the belt location. It is at this time that the reel table should be removed and rebuilt as the take-up torque due to old felt will be excessive and you don't want to have to go in again. Oiling of the Flywheel bearings is also good to do at this time.
If you can not do it I work on deck as Skywave Tape Deck Repair near Chicago. That is one option. There is another service provider in New Jersey.
Jan 22, 2011 | Teac Audio Players & Recorders
I need to replace the walking belt on a ProForm PFTL40070.
Installing An Icon Fitness Treadmill Belt You can save yourself a great deal of time by following these instructions as opposed to those of the manufacturer. Please contact us if you need any further help. UNPLUG THE TREADMILL BEFORE DOING ANY REPAIR!
Step #1- Remove the plastic railing on the right hand side of the deck. Most railings are stapled down so using a flat head screwdriver or another prying device is the easiest way to do it. The plastic is refastened using screws provided with the belt in a later step. If you cannot see the staples, you may need to remove the cosmetic center insert cover first by simply sliding it to the back of the treadmill. This rail is on the opposite side of the front roller pulley and motor. Some of the models aren’t stapled down and with these, you simply remove the rear end cap and slide the rail off the back of the treadmill.
Step #2- Loosen the rear roller and remove the two adjustment bolts. Some models have a spring loaded tensioner on the right hand side so be careful when removing these bolts. After the bolts have been removed, remove the rear roller end cap(s). The rear roller should now simply slide out of the walking belt.
Step #3- Remove the motor hood. Using a black permanent marker, make a mark on the front roller adjustment bolt on the motor compartment side at exactly where it fits flush with the roller so you will know where to retighten it later. The adjustment bolt is on the right hand side of the front roller. Then remove the bolt with a 7/16” wrench. Step #4- Remove the deck screws which should now be exposed since the plastic cover is off. In this step, also remove the staples with a pair of pliers. Be sure to remove all deck and staple debris before continuing.
Step #5- This step is easiest if you have another person to help but it is possible with one person. Lift up the side of the deck that has been loosened and making sure that the front roller is angled toward the deck, remove the old belt by simply pulling it to the side. A few models had a side hand rail that attaches to the side of the treadmill and if you have one of these, the hand rail must be removed first.
Step #6- Install the new belt just like you removed the old belt. Before proceeding, make sure that the belt is in the center of the two metal belt guides that protrude from the bottom of the deck. The guides should be angled where the sides of the belt are turned slightly upward. Sometimes these can get bent during installation so make sure they are contacting the edges of the belt or the belt will not stay centered properly. Step #7- Install the front roller adjustment bolt where you just start it. Do not return it to its original position yet.
Step #8- Install the deck screws.
Step #9- Slide the rear roller back into position and insert the end caps and rear roller bolts. Most models have a small ground wire on one of the rear roller bolts. Make sure to just slide this over the bolt before it is inserted in the roller. The ground wire dissipates static electricity that is built up on the walking belt to help the roller bearings last longer and reduce static discharge on the electronics.
Step #10- Adjust the front roller bolt to its original position.
Step #11- Tighten the rear roller bolts to where the tension on both sides feels even and you can lift the walking belt 2-3” in the center of the belt from the deck surface.
Step #12- Replace the right side railing with the screws provided using a screwdriver.
Step #13- Start the treadmill and align the belt according to the instructions in the owner’s manual or on our web site troubleshooting page under “Belt Centering Tensioning Instructions.”
Step #14- Once the belt is aligned, test the belt for slippage. If the belt slips at all, tighten the rear roller adjustment bolts equally on both sides ½ turn until the slippage is gone. Do not over tighten the belt where it has less than 2” of lift from the deck surface.
Step #15- Replace the motor hood and make sure no odd noise is apparent and that the belt is tracking and tensioned properly.
May 19, 2010 | Proform 325 Treadmill Walking Belt
May 09, 2010 | Bang and Olufsen Beosound 2000 Shelf...
Sony tc-wr535 won't eject. Tape stuck. Won't play cassette on either deck A or B .makes noises but won't FF or play, gets stuck and wont eject. Will belt conditioner work? What do I use?
The problem, according to messages on your site, is that the belts are old and have stretched. There is a great step by step tutorial on www.Instructables.com with pictures and all. Parts are not too hard to find on search engine. Looks like less than $25 to fix.
http://www.instructables.com/id/How_to_replace_the_belts_on_a_Sony_TC_WR535_Dual_C/
Jan 16, 2010 | Sony CASSETTE DECK Single Dual Cassette...
B&O 7007 beocenter. need belts for tape deck,
belts are long since discontinued.cartridges are expensive look for mmc20s mmc20e mmc20en
Nov 23, 2008 | Audio Players & Recorders
Sony Cassette TC-WR535 BELT REPLACEMENT
Unit may have defective idler or gear. Have serviced
Aug 05, 2008 | Sony CASSETTE DECK Single Dual Cassette...
Replacing drive belts on Sony TC-WR535
http://www.eserviceinfo.com/index.php?what=search2
I am having the same problem with a Sony K717 ES. I found
this site above where they have the service manual for every tape cassette known to man. They ask that you make a donation to
a charity and then they will email you the pdf for free.
Sep 25, 2007 | Sony CASSETTE DECK Single Dual Cassette...
209 people viewed this question
Top Bang and Olufsen Audio Players & Recorders Experts
 Grubhead
Grubhead
Iluvintage
Level 1 Expert
Are you a Bang and Olufsen Audio Player and Recorder Expert? Answer questions, earn points and help others
