Keep getting error message saying Dymo had to close. Running Windows XP
  • 10,515 Answers
This is the response from dymo stamp. I did as they said and am now printing stamps again.
We have seen this cause problems with the .NET framework Microsoft uses and Dymo Stamp uses. Follow these steps to correct it Step 1: Download Microsoft Windows Installer CleanUp Utility
1. Visit:
http://download.microsoft.com/download/E/9/D/E9D80355-7AB4-45B8-80E8-983A48D5E1BD/msicuu2.exe
2. Save the file on the Desktop.
3. Please double click the msicuu2.exe file to install it on the computer.
Step 2: Remove .NET Framework
1. Click Start -> (All) Programs->Windows Installer Clean Up.
2. Please locate and remove Any .NET Framework 2.0 software.
After that, please perform the following suggestions to reinstall .NET
Framework 2.0 and its updates. Step 3: Reinstall .NET Framework Version 2.0 SP 1
Please download and install the following
Microsoft .NET Framework 2.0 Service Pack 1 (x86
http://download.microsoft.com/download/0/8/c/08c19fa4-4c4f-4ffb-9d6c-150906578c9e/NetFx20SP1_x86.exe
Note: When the "File Download" window appears, please click Save, and follow
the directions to save the file on the Desktop. After downloading all the
setup files, please double-click on each one to install them.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 14, 2010
How can I fix a Win32 error message on my LabelWriter 450 printer. Was working b-4 on windows x-p. Can't get it to work on Windows 10 !!!!!!!!help
chances is it is not compatible with Windows 10! If you have another computer running windows xp or vista hook the label writer to it, if it works then compatibility with with windows 10 is the problem, unless they have an software update for your printer, it wont work.
Feb 10, 2016 | Dymo ® LabelWriter® 450 Series PC...
WINDOWS ERROR MESSAGE
boot from the CD copy of your windows XP. enter in console session and manually replace the file. if the file is corrupted this should fix it
Feb 26, 2012 | Gateway GT5026E PC Desktop
Why does my computer keep saying "(insert program name here).exe has encourtered a program and needed to close, we are sorry for any inconvenience" it's been doing that with a few games, including...
I suspect that one or more of the game programs you have loaded have not been tested for compatibility with Windows XP and may have corrupted the hard drive.
Run chkdsk /f (/f is for "fix") and XP will check and try to fix your hard drive the next time you start windows.
If the error messages persist, you will have to use add-remove peograms ro remove all your games and then (after running chkdsk /f again) see if the error messages stop.
If they do not, you are faced with a reload of XP and then only load programs that have been certified by MIcrosoft to run under XP.
Oct 23, 2010 | E-Machines T4892 PC Desktop
I'm getting an error that says MFC application has stopped working. It's coming up when I open my PED-Basic. I have deleted the program and reinstalled but i still keep getting this message. When I...
if you have win 7 or vista on your laptop .. the program may be written for win xp .. if so, you can check to see if ugraded software is available from brother for your operating system .. .. or you can load your present software using windows " Compaaibillity Mode" chose XP or whatever operating system the brother software was written for .. right click on your program loader on your disk (setup or whateve) . then select "compatability mode"
Jan 27, 2010 | Brother SE-270D Computerized Sewing...
This is the error message when openning the Dymo Software on Server 2008. We have openned this same softare successfully on other 2008 Severs. Exception EPrinter in module Labels.DLL at 0000643E6
http://global.dymo.com/enGB/Troubleshooting/LabelWriter_320.html
From this site.
    • The error message: "Exception Eprinter in module LABELS.DLL at ...." is displayed.
      or
      The error message: "Access violation at address ... in module DYMOLBL.EXE" is displayedA. This problem can occur when DLS 7.x was installed over DLS 6.x, without first uninstalling DLS 6.x.
      Solution:
      Delete the file Dymolbl.ENG.
      DLS will still work, however, all default settings will be incorrect.
      The settings will need to be set correctly.
      On the DLS menubar, click Preferences and set the preferences as desired.
      The default values are:
      Default label file folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Label Files"
      Default address book folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Address Books"
      Default clipart folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Clipart"
      B. An incorrect printer has been selected in the DYMO software.
      Solution:
      1. Start the DYMO Software.
      2. Click on File and point to Change printer.
      3. Click the LabelWriter model connected to the PC (e.g. Dymo Turbo)
      C. Occasionally, double-clicking the print command button in the list manager is not handled properly by the software.
      Solution:
      Single-click the print command button.
      D. An incorrect driver has been installed.
      Solution:
      Run the DYMO Driver Uninstaller
      Restart the PC and install the correct driver.
      To remove and reinstall the printer driver:
      1. On the Windows taskbar, click Start, point to Settings and click Printers (& Faxes).
      The printers window is displayed.
      2. Double-click the LabelWriter icon and delete any documents waiting to be printed.
      3. Close all programs.
      4. On the Windows taskbar, right-click on Start and click Explore.
      Windows Explorer is started.
      5. Double-click the file C:/Program Files/DYMO Label/Support Files/LW Remove.exe
      6. Unplug the LabelWriter's USB connection from the back of pc and click OK.
      7. Choose Select all and then remove.
      Once the driver has disappeared from the printers dialog box, click Close.
      Restart the PC.
      8. When Windows has restarted, on the Windows taskbar, click Start, point to Programs, point to DYMO Label and click Uninstall DYMO Label.
      9. Reconnect the LabelWriter to the computer and reinstall both driver and software.
Jun 16, 2009 | Dymo LabelWriter 400 Turbo Thermal Printer
Dymo LabelWriter 400 Turbo won't installl
I had the exact same problem. I found that the "All Users/My Documents" folder did not have permissions set that would allow the user account I was logged in under to access the folder, even though I was an administrator account.
I set the permissions on the my documents folder to allow "everyone" to have full control, and then it all worked just fine.
Sep 25, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Letra Tag QX50 Error 1 message
Don`t close the back plane compleet, push print and pull on the tape, now it runs on mine. Close the back plane and everything is ok now, Good Luck!
Michel
Sep 20, 2006 | Dymo LetraTag QX50 Thermal Label Printer
Open Questions:
How To Fix Laptop That Won't Turn On 'Call +1888784-9316 In case you have encountered certain issues while working on your important project from office or while doing college assignments due the next day and now you are searching for some strong supportive tech support service, then get in touch with the tech support executives of Dataalign. Call Toshiba support for getting rid of all sorts of tech issues whether related to software or hardware. Getting tech issues fixed in a matter of few minutes is the speciality of tech support executives of Toshiba support. These executives of Toshiba are certified professionals and they make proper use of their expertise and years of working experience in the field of customer support for customizing a unique and exclusive tech support service according to the required need of the customer. We can say that Toshiba tech support is the simplest, effective and customer friendly tech service. It has got everything that makes a tech support service high in demand, like being pocket friendly, easy accessibility, available even at the odd hours, courteous and polite support executives. These technicians always try that all the customers they deal with, get satisfactory outcome and also experience friendly customer service. Toshiba laptops are famous around the world for their eye catching features and advanced technical characteristics that make them everyone's first choice. Still Toshiba customers face issues in their devices ranging from minor issues to major ones that can gradually lead to effecting the laptops performance permanently for a long term. Issues that are usually faced by customers are not able to process fast, getting the command keys wrong, screen freezing issue, blue screen of *****, frequent invasion of viruses, Trojans and malwares etc. Toshiba support has been helping customers to get rid of all these issues as soon as possible. Their assistance is available 24/7 through various modes of communication like via mail or through phone. They employ advanced techniques for resolution of issues and they use remote access process for their work which makes is more accurate and faster. Call on toll free helpline number +1 888 784-9316 anytime and get support anywhere. Enjoy the work being done in front of your eyes by asking for tech support service at the time and place of your choice.
Jul 17, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
