Sound problem on my TV
I have a sound problem on my TV, one of the side speakers does not work when a switch the balance from one side to the other?
  • 81 Answers
It could be the audio cables from your cable box or sat box. make sure its connected all the way in on boths sides.
Posted on Apr 01, 2008
SOURCE:
Can't get balance, bass and treble to work when connecting Bose Acoustimass 5II to HK AVR 525
On my yamaha 375 receiver if I connect digital or hdmi it disables the balance/bass treble etc but they work with anolog don't know if yours might be the same just abit strang if anolog doing it aswell
Jan 15, 2014 | Harmon Kardon Harman Kardon Avr 525 7.1...
What would cause the driver side front door speaker and the passenger side rear deck speakers not to work. When if fade the sound all the way to the front with no sound in rear and with the balance turned...
Check the speakers if they work. Connect the speaker terminals using a short wire to a 1.5 volt battery (AA or any dry cell batter) and listen if there's a thumping sound when the wires are connected to the battery terminals. If there's no sound, your speakers are busted. If there's a sound, check if the wires are okay. Use the same method with the battery with the wires from the back of your stereo. Make a small cut on the wire and attach the short wires you used earlier.
Nov 04, 2013 | Cars & Trucks
I have a Toshiba flatscren, just baught a Bose cinemate GS series 2 sound sytem, and only one speaker works, Returned it, got a new one and it does the same thing, It must be a settings issue on my TV ?? ...
The left audio channel pre-amplifier in your TV is not working. Fixing that is a job for a technician with an oscilloscope, or else you would have to replace the main board in the TV.
If you connect another device (CD or MP3 player to your Bose sound system, I expect you will hear both speakers playing the sound from the other device.
Oct 19, 2017 | Bose Cinemate Digital Home Theater System...
No sound on right side speakers on A&B.Sound does work in test mode. Right side Chanel is working, just no sound on right side front in all input modes. I'm a amateur when it comes to stereos.
Go to "menu/Setup/Speaker level" and adjust the balance of L-R.See page 21 of the manual:
http://usa.yamaha.com/products/audio-visual/av-receivers-amps/rx/rx-v540/?mode=model
Jan 20, 2013 | Yamaha RX-V540 Receiver
How to turn sound on phillips plasma 32 inch tv
Hello
I thinks that you want to tune your TVs sound parameters, and answers. As you know, when the TV is switched on it will display picture as well as sound, according to the volume level setting. If you want the qulality of sound much more better, by pressing Menu button and higlight the opton 'Sound'. As you select, there will be a 'tick' mark appears, indicating that sound option is selected. On to the right side, there will be Bass, Treble,and balance control displays. Use "Cursor Up" button to go box 'Bass", and increse or decrese Bass lavel as you likes. If you wants to adjust treble, use "Curser Right" button and do as previous to your taste. Come to the "Balance" option by using "Cursor Up or Dn' keys and set it to mid position. There will be indication for its mid position, and it should be in that position, so that you can hear sound from both speakers equally.
All jumpings and adjustments can be done with 'CursorUp, CurserDn, CursorLeft, CurserRight' Ok.
Oct 31, 2010 | Philips 32PT6441/37 32" TV
My Aiwa Colour TV, model No. TV-A2019, has developed audio problems. 1. The audio output from the speaker is high even when volume is set at level one. Audio output is constant for volume level 1 to...
You just come aroung the sound decoder section of your tv. Decoder problems may cause the fult you pointed out. Since all the controls are electronically controlled, and all are through sound decoder, which converts sound to stereo the problem must be there. Since sound comes from two channels are ok, there is no problem around sound output. Check for some soldering loose contact, wire socket loose cotanct also.
Oct 14, 2010 | Aiwa F2000 20" TV
I have a panosonic plasma tv when i switch it on it tell me there is a speaker short and then switches it self of model number pdp507xda help
It's the internal circuitry problem. Try muting it and put audio connection to other speakers if it repeats, your TV audio system is internally dying.the audio connections has to be checked and faulty components should be replaced.
1. Speaker short.
Open it up and check the speaker connections. ONLY if you have basic skills working on electronics and don't have a warranty.
2. Sound Volume "Leveler"
Look in your sound option menu for a sound "balancer" option and turn it off.
If this doesn't work disable the sound and invest in that surround sound system (external speakers solution of your choice)
try this.for first unplug the main power cord of the tv for couple of minutes and then reconnect it.also before reconnecting the power cord of the tv again remove all the external device wires connected at its back such as dvd player/vcr etc etc.just connect only tv wire and check out.if still the same problem then its quite possible that the capacitors and ic on the audio circuit board are getting short in between so the circuit is not getting completed and cutting in between so the tv starts and turns off. if the tv is connected to externalk speakers then check out without connecting the external speakers and see whether it works.if it works that means tv is perfect.but if tv is having inbuilt speakers that its confirm problem with inter audio circuit of tv.so try connecting external speakers at the back of tv and check out.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Oct 20, 2009 | Panasonic PDP-428XDA 42 in. Plasma TV
Sound fluxuates,crackling sound samsungTX-R3079WH sound goes up and down automaticly
If the sound FLUCTUATES up & down, try turning off the AutoVolume in the sound menu. You didn't say if it's one or all speakers crackling. Crackling is either a speaker or circuitry issue. Adjust the balance away from the speaker that crackles, if it stops, that speaker is probably "fried". If it still crackles, I'd turn off the speakers and run the sound thru a stereo for the quick, cheap fix. My Samsung (10+ years old to be fair) crackles due to a circuit issue but if I SMACK the left side speaker (behind which is the sound board and side panel connectors) it stops for a while. Maddening. I think I broke it squeezing it into the furniture it's in, pressing on the protruding RCA plugs. Dumb design.
Aug 15, 2009 | Samsung SlimFit TX-S2783 TV
No sound out of 4 of 5 speakers when using tv only.
switch around rca cords and verify its not a bad wire(s),Check and see in the TV menu audio settings are correct/ balances R/L etc. audio outputs are on,Try different theater amp if you have an extra.
Jan 26, 2009 | Samsung HT-X50 System
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Ekse
