Question about Powerline 200Watt DC to AC inverter (0900-35) Power Supply
When i turn mine on, it beeps and blows a fuse, even if theres nothing plugged in
    Genius:
  • 1,027 Answers
Internal fault - replace it.
Posted on May 14, 2010
My 2008 suzuki grand vitara keeps blowing the fuses for the ACC outlets. both are 15AMP, but even with nothing plugged in, nothing down in the outlets and even with larger AMP fuses, they keep blowin
If you use too large a fuse, the wiring can catch on fire, and the whole car could burn up. You'll need an auto electrician to trace that problem. You can remove any bulb and unplug any device that is on the Acc(essories?) circuit; then see if a fuse will stay; start replacing items till you blow the fuse. It seems like a dead short which can surely melt wires if you keep taking chances. good luck.
Feb 14, 2015 | 2008 Suzuki Grand Vitara
Fuse keeps blowing La Pavoni Europiccola 1996
Hi That's a short it's all it could be isn't it. Plug? lead? water or damp in the base? try slipping the black base off you will need a security bit to get it off or at least mine does its a t bit with a hole in the middle I think, have a look for water that might be shorting it out also try it in another socket , you never know.
Best of luck.
Feb 28, 2014 | La Pavoni Coffee Makers & Espresso...
Blows fuse when turned on
Mine is doing the same thing, but I have searched and not found any solutions...
Jul 06, 2012 | Aquabot Pool Rover Above Ground Robotic...
I have a 2008 Suzuki ATV King Quad 400 - everything works fine except the ignition fuse keeps blowing. I used to be able to change it & it worked for a while but now today everytime I put a new fuse in...
I had same problem on mine, just discovered there is another hidden 30 Amp (green) fuse that was blown. If you follow the red cable from the battery, you will find a connector module. Lift that module out and disconnect the wires leading to the rear of the ATV (one plug, pulls out easily). You will see a semi-transparent plastic cover on this module, remove it and you'll see the 30 Amp fuse and the cover should have a spare in it. Replace the fuse, cover, and plug the wires back in - re-seat the module and see if it starts.
I'm still not sure what is causing all these problems, I'm suspecting it could be a bad battery. For now just carrying a lot of spare fuses.
Aug 10, 2009 | Sport & Outdoor - Others
2001 Saturn SC2, a/c won't blow but heater works fine
It sound like an electrical issue ( fuses wired wrong exc.) how many miles on the vehicle?
Apr 28, 2009 | 2001 Saturn SC
We just bought a 65 piont heir dehunidifer. we cant even get it to come on!!
Fuses have been known to blow easily. They are on the inside and I have yet to find a replacment for a 12A 120V fuse for mine.
Jun 14, 2008 | Haier HDN655E Dehumidifier
Tv won't come on
Beeping in that model usually refers to the flyback needing to be replaced or the Horizontal output transistor. Flyback is most likely the cause as the HOTransistor will usually blow a fuse causeing the set to be dead.
May 22, 2008 | RCA P60920BL 60" Rear Projection...
GFI outlet fuse trips even when nothing is plugged in
hi there, there is a shorted electronic parts at your power supply, fuse allways blows means a shorted diode, regulator and a transistor. it should be replace, do some testing and replace the defective parts. ty
Jan 10, 2008 | Computers & Internet
TV DEAD
On some models the reset is unplugging for a minute or two and plugging back up. Otherwise you have a blown fuse where the power goes in. If you decide to replace the fuse do no go over 5 amps. If the replacement fuse blows there is a short in the set and needs a repairman.
Jan 02, 2008 | Philips 19PR19 19" TV
Blowing fuses under hood but nothing looks smoked in the amp
Sounds like the amp is fried, most likley in one or both of the output sections. Good luck.
Feb 21, 2007 | PPI DCX-1500.1 Car Audio Amplifier
Powerline 200Watt DC to AC inverter (0900-35) Power Supply Logo
164 people viewed this question
Top Powerline Computers & Internet Experts
David Payne
David Payne
Are you a Powerline Computer and Internet Expert? Answer questions, earn points and help others
