The safe and easy way to do this is to first unplug the set and then remove the back cover.
Most likely you are seeing spider webs; with the back off I use a swiffer duster with a fairly long handle. Clean the three large black lens you will see with a lens cloth or a paper towel with glass cleaner sprayed on the towel.
With the duster get all the webs and do not apply force for any attached to the inside of the screen.
Common problem and I have seen it many times. It is a good idea to clean the lens on the three tubes once a year--any dust on them will make the picture look somewhat darker and dull.
SD TECH
Testimonial: "SD Tech Thank you so much, I thought that was about what you would do. But I wanted to make sure there wasn't a easy secret way the tech's did it. I will do this tomorrow! My husband won't even watch the tv for the last yr. Say's it that is HD I don't want it. He never had time to watch before he retired. I knew something was wrong. Then I got up close and found all the cobwebs from the tops, sides and bottom. I knew what had happened to the picture. thank you so much. You guys do a great job here! Deb Sullivan"
