Question about Ecoquest Fresh Air Air Purifier
Does not turn on
There is no response when I push the power button on the front panel. I also checked the switch on the back. Nothing works. Checked the fuse but it appears to be ok. Ideas?
    Guru:
  • 415 Answers
Fuses often fail without appearing to be bad. Test the continuity of the fuse by using an ohmeter.
If, after testing your fuse, you continue to have a problem, let us know and we will dig deeper.
I hope you find this to be very helpful as a jumping off point, moving forward.
Please leave a rating. :-)
Posted on May 14, 2010
Will not operate, no reaction when power button pressed. All panels properly locked.
first off does the light come on at all? when the switch is moved to the High Medium or low setting do you see a red light or a green light on the right side of the unit? if there is no light at all, then there is either no power and you have a bad cord or a bad outlet. The only other thing could be the switch that needs to be tripped in order to let the unit run, that switch is closed by the front cover locking in place. that switch could be bad or your cover may have the tip of the pin that pushes the switch closed broken off or deformed and not pushing down enough to close the switch. try pushing a screwdriver down on the switch and see if it comes on. There's nothing that can shock you if you push on that switch, the power wires are concealed inside a plastic covered area that the switch slides into. If you close the switch and it doesn't come on the check the power cord or the wall socket for power. See if the cord has any unusual looking spots or lumps, stretching, cuts or anything that looks suspicious.
Apr 06, 2015 | Oreck XL Professional Air Purifier
On/off switch stuck Brookstone air filter 561274, can't open top to get to switch
there are two very small screws just above the on/off switch. Once you unscrew those two, you can use a knife (carefully) to lift the on/off panel out of the air filter. I just did this. My problem is now that I don't understand how the on/off button is supposed to work at all.. there was no spring or anything I can see that could have pushed the on/off button back up. I am considering just leaving the actual button out and pushing the microswitch directly. Looks like bad engineering to me.
Feb 26, 2012 | Air Purifiers
Came home and unit was off and cannot turn back on. No response at all. Cleaned it and still nothing happens
Check to make sure the screen is pushed down in the back to activate the failsafe button. Sometimes the button can get finicky. Take off the screen and push it down with something. See if it does anything, if not, check the fuse and the plate, if it cracks, it's blow the fuse later.
Jun 08, 2011 | Ecoquest Breeze AT Living Air Purifier
I have no power to my Fresh Air by Ecoquest. I've taken it apart and all connections seem to be in place. Still nothing when pushing the reset or power buttons. Any advice?
Remove the filter on the back. On the outer edge of the filter frame, you will see a plastic tab. This tab is a safety switch and if it's not making proper contact with the trigger of the unit, it will not power up. Push the tab section of the filter frame snugly in first and then the remainder of the filter frame. That should solve your problem. It that doesn't solve the problem, check for a blown fuse, The fuse holder is on the back of the unit.
Mar 14, 2011 | Ecoquest Fresh Air Air Purifier
I replace my uv bulb and now have no power
Some connection has not been firmly made, or the little safety switch at the back of the machine was accidentally pushed.
1) Check the back plug and make sure it is inserted FIRMLY. Does the machine work now?
2) If not, check the little switch in the back with the 0/- markings. Make sure it is depressed to allow power to the machine (try it after checking the plug.)
3) Check the fuse.
4) Unplug the machine and go back in to make sure the UV bulb is firmly inserted. It needs to be turned so that it "clicks," or "seats" correctly at both ends.
If none of these steps work, go through your Owners Manual step by step, checking all connections and wires. Make sure nothing is visibly loose, corroded, or broken. An owners manual is available at http://www.vollara.com or call Vollara customer service at 1-800-989-2299
Jan 29, 2011 | Ecoquest Fresh Air Living Air Purifier
I cleaned my Ecoquest, it was working fine, how no power
Assuming that the unit was working fine before you cleaned it. Did you remove the back lower panel while cleaning it? It the panel that holds the electrical socket and fuse. If you did, check to see if the electrical connector is seated to the main board. Also check if the keyboard connector (the one that looks like a telephone jack) is plugged into the main board. Also, check if you model has a switch on the back that it is set to the on position. And press the power switch on the front keypad to see if that make the unit work. That all I can think that might have gone wrong.
Jun 30, 2010 | Ecoquest Fresh Air Air Purifier
Flashing blue lights
toss it. learn from it. Use Consumer Guide or something similar. Thank god it fots down the incinerator duct.
Jul 28, 2009 | Sharper Image Professional Plus Ionic...
Won't turn on
Just wanted to make sure you inserted the carbon filter on the back before turning it on. It will not turn on without the filter in place. Also, you have to make sure the on/off switch on the back is turned on. Hope that might help.
Aug 28, 2008 | Ecoquest Breeze AT Living Air Purifier
AC2044-1
Unit likely had large partical like dog or cat hair cross over cell, Unlplug and remove pre-filter & cell.
The unit has a timer that knows when power has been removed & front grille has been taken off by 2 micro switches in back of front grille that is connected to the units control board.
While you are there remove pre-filter & Cell, if ok and no debris is found & theres no need to wash, wait 10 to 15 minutes replace all & plug back in.
You should see the LED display flashing Clean Cell & Cell button flashing, hold Cell button in at least 3 seconds this may take longer to reset. Unit should turn back on.
This condition has happened to my 2 units on occasion even though I had washed the cell only a week or two previously.
The unit will turn off if a cell overload is detected by way of large static discharge. If I know the cell is clean, I just unplug the unit & take the front grille off for 15 minutes then & replace it plug back in & reset & all goes back to normal operation.
Apr 22, 2008 | Kenmore AC2044-1 Air Purifier
Red Light indicator on
I have a Bionaire tower air filter model BAP1700 that I bought from Costco. The filter check LED came on recently after 5 months of use. After cleaning the Permatech filters, I tried every remedy on this website including following the instructions that say push power button for 2 secs. Nothing worked. Then I noticed a tiny hole on the control panel in front of clean filter LED; I pushed a paper clip pin into that hole, felt a click, held it down and 2 secs later, LED went out. Success!
Apr 06, 2007 | Bionaire BAP1500-U Air Purifier
Ecoquest Fresh Air Air Purifier Logo
299 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
