Question about Sony PlayStation Portable (PSP) Console
My psp fell and the memory stick duo popped out
Ok i guess there's no troubleshooting but what will I do?
My psp fell and I can't make the memory stick duo slot to close it pops out...
I temporarily placed tape.. It was ok and nothing was wrong with my files...
BUt if i go and make someone fix it what will they do? i dont want it popping out...
  • Sony Master
  • 13,433 Answers
They will most likely open the psp and try to repair the problem.
Posted on Mar 30, 2008
MY memory stick can be seen and read in my pc but doesnt work on my psp
  • Flash Storage:
  • Memory Stick PRO Duo Expansion Slot pspphatmodelnumber.gif pspslimmodelnumber.gif pspbritemodelnumber.gif
All flash storage, including Memory Sticks and internal flash, uses the FAT32 file system. http://us.playstation.com/support/answer/index.htm?a_id=1055
The above shows how to format the Memory Stick PRO Duo in the PSP so the correct file structure will be shown.
Be sure to back up any data on the Memory Stick PRO Duo before doing this as all data will be lost on the Memory Stick PRO Duo device.
Aug 06, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
Psp memory stick won't work.
it may be damaged or full try a different one
Apr 14, 2010 | Sony PlayStation Portable (PSP) Console
I have a Memory Stick Pro Duo 8GB will not open on my computer or camera..was working then quit. Advice please
Problem for Sony Memory Stick PRO Duo (2GB) for PSP I have a Memory Stick Pro Duo 2GB will not open on pc &also not formated
Jan 02, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
Memory card, not right one and stuck!
The PlayStation Portable system is only compatible with "Memory Stick Duo" and "Memory Stick PRO Duo" memory cards. You should have read that in the manual, or on the box, or directly on the unit.
Inserting by force any other type of memory card (including "Memory Stick PRO" that are not Duo) will break your PSP. There are dozens of types of memory cards on the market. They don't have the same shape and size, and they don't work the same way.
Trying to push another type of memory card in your PSP is acting like a kindergarten child who desperately tries to push a cube in a hole that is shaped like a circle.
Jan 03, 2009 | Sony PlayStation Portable (PSP) Console
Psp illiterate
Yes there is a way. What you will need is a PC, Some form of Memory stick Duo card Reader, And a PSP Compatible Memory stick Duo/Pro Duo.
If you havent already used the memory stick inside the PSP it will not have the correct Formatted file System for use in the PSP. but you can create the file system using your computer.
heres how to do it ! :
1) plug your Memory stick Duo/Pro Duo into the card reader on your computer.
2) open my computer, locate the Memory stick usually found under the "devices with removable storage" area.
3) once inside the memory stick, create 2 seperate folders. One called "PSP" and the other one called "MP_ROOT".
4) Navigate into the "PSP" Folder and create 3 Folders, "MUSIC", "PICTURE" & "VIDEO"
5) Copy & Paste the Necessary files into each Subsequent Sub-Folder within the "PSP" Folder.
Note : The PSP Can only handle Certain File types for Pictures, Music, And Video. i would suggest Navigating to http://psp.about.com/od/hardwarefirmware/p/compformat.htm before you transfer your files to ensure that you are adding files which are Viewable/Readable by The PSP's software.
Hope this helps !?
Oct 27, 2008 | Sony PlayStation Portable (PSP) Console
I need to now how use my psp san disk and can get on websites
For you to surf the internet, your PSP has to have firmware 2.0 and above. to find out what firmware your PSP has:
1. Turn on the PSP.
2. Go to the "Settings" category (it's the one farthest to the left).
3. Scroll down to the "System Settings" icon and press x.
4. Scroll down to "System Information" and press x.
5. The screen will display the PSP's MAC Address, System Software Version, and Nickname. The
"System Software Version" is the firmware version.
If you have the 2.0 And above firmware heres how to get connected to the internet :
  1. Find a wireless access point. make sure you have the correct password as you will be asked to input it in order to connect to the WAP.
  2. Insert a Memory Stick. If you want to save any bookmarks while you're online, you'll need to have a Memory Stick to save them on. The same goes for any content you might want to download.
  3. Turn on the WLAN switch. You'll find this on the left side of the PSP, just above the Memory Stick slot.
  4. Set up the Network Settings. You'll find these under the "Settings" menu, right at the bottom of the list. Choose "Infrastructure Mode" and follow the instructions. Here's where you might need a password (see step 1).
  5. Open the Browser. Select "Network" from the home menu (it's the one farthest to the right). Scroll down and select "Internet Browser" (the icon has www on it). The PSP will connect and the browser will open (there will be a slight delay as this happens).
  6. Go to the Address Bar. If you don't see an address bar at the top of the browser, press the triangle button and it will appear. Navigate to the address bar using the up button on the d-pad. The address bar will light up.
  7. Surf away !
and in the case of you talking about San Disc. im guessing your asking how to insert and your Memory stick Duo? if so follow these steps :
  1. Open the slot cover for the Memory Stick Duo located on the left side of the PSP? system.
  2. With the printed side of the Memory Stick Duo facing out towards you, slide the Memory Stick Duo? into the slot in the direction of the arrow printed on the Memory Stick Duo.
  3. Press the Memory Stick Duo until fully inserted.
  4. Slide the slot cover back into its original position
Hope this helps !?
Oct 25, 2008 | Sony PlayStation Portable (PSP) Console
PSP 1001
If you have important data on you memory stick, back them up on your computer. Then format the memory stick with your PSP. After that, put all your PSP data from the computer back onto your memory stick.
See if the PSP recognizes your memory stick. Hope that works! ^-^
Dec 28, 2007 | Sony PlayStation Portable (PSP) Console
Can you use the PSP Memory Stick Pro Duo cards on your DC?
Yes! The Memory Stick Pro Duo's are one in the same. (Just out of curiosity, where are you finding them cheaper?) One note, however; as strange as this is, though the PSP plays mp4s, they will not play mp4s from a memory stick pro duo that comes directly out of your M1 camera... I've tried it, I have both a PSP and an M1. (The PSP will show off your M1 still photos, though.) Hope this helps! Susan
Sep 08, 2005 | Sony Cyber-Shot DSC-M1 Digital Camera
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
