Question about Breville BBL600XL. 5-Speed Blender
I need to replace frayed wire
The plug wire has become frayed. How do i replace it?
    Guru:
  • 351 Answers
You can get a new plug from any hardware store and replace the plug you have . 2 prong or 3 prong to match the original, cut the wire back just enough to get away from the frayed part ,.. when connecting the wire , curl the bare end of the wire around the screw in the direction of tightening the screw, clockwise .
thoughts?
Please Vote !!
Posted on May 15, 2010
My kitchenmaid pitcher is stuck on the mixer. it still mixes, it won;t detach
The coupling on the motor has become bonded to the coupling on the beaker. Maybe it was moving about excessively and the 2 plastic parts have fused together. You can expect to have to replace the motor coupling and at the least the blade assembly or possibly the whole beaker depending on model. Knowing what you are up for needing to replace now if you wish to get it off put a litre of water in it, put the lid on and turn it on high and wobble, wriggle it about until it is able to be lifted off.
Aug 26, 2016 | KitchenAid Blenders
What is E2 code for Hairy Bikers soup maker?
There are 5 pins on the socket in the base. on the back of that
socket there is a black strap that holds the wires in. it snaps off
and the wires drop out. you need two small washers remove the two screws push the wires replace the strap now put the two small washers the screws and replace job done
Mar 02, 2015 | Blenders
I replaced the immersion heater in my hot water tank, like for like , replicating the electrical connections as well. It does not work. There does not seem to be any power coming into the heater. The
Learn in 2 minutes to use a multimeter to measure resistence ohm and/or continuity,buy a cheap one at a local store if u don,t have and measure the integrity of the element,ceck the voltage on wiring and/plug,if no power comes in, it will not work !?!
Regards
Oct 28, 2014 | Blenders
How to
I would suggest just replacing it. It can become a shock hazard in its current conditon.
Jul 23, 2014 | Kenwood kMix BLX50 Blender, White
Blender won't work
The switch may have failed.
Dec 06, 2013 | Oster Blenders
I have the red Cuisinart BFP-703 SmartPower Duet Blender/Food processor. I turn it on and press and of the buttons and it does come on. What should I do?
if you over loaded these machines there is a thermal fuse one time shot will blow . it is not resettable , you can buy them @ Radio Shack 8 amp should do fine . it might be stamped with the rating value too. need a test meter to check component very small .187 diameter & .750 length apx
Mar 14, 2010 | Cuisinart Blenders
Blender will not run. the power button is lite but
There is a 10 Amp thermal fuse (SF129E) that is supposed to create an open circuit when the motor windings exceed 133 C degrees. Although this fuse should close again when the motor cools down it can become perminantly damaged. Locate the fuse by following the black leads from the coltrol board to the motor brushes. It's inside a cloth insulating sheath secured against the windings with a metal strap and two ty-raps. I bypassed the fuse with a wire instead of replacing it. It would probably just blow again sooner or later. p.s. you need a T10 Torx screw driver to disassemble (screws under rubber feet) $3 at ACE hardware.
Jul 01, 2009 | Breville BBL600XL. 5-Speed Blender
My cuisinart spb-7 blender won't spin
How do I replace the blender blade driver clutch? I have the part but do not know how to get it in.
Jun 13, 2009 | Cuisinart SPB-7 SmartPower Work Top...
How do I replace the fuse on my Oster Blender?
I just had the same problem too and ordered the fuse online with the link above. Thanks lele44!
The four feet on the bottom are easily removed with a 1/4" socket slipped inside the each rubber foot fitting.
I'm glad I found you. I saw some downright horrible reviews of my local Oster appliance service center here:
http://www.insiderpages.com/b/3723327730
Rob
Sep 17, 2007 | Oster 4134 / 4126 Classic Beehive Work Top...
Breville BBL600XL. 5-Speed Blender Logo
100 people viewed this question
Top Breville Blenders Experts
Mike
Craig Butler
Craig Butler
Joseph Hoffmann
Are you a Breville Blender Expert? Answer questions, earn points and help others
