Question about Canon PowerShot A430 Digital Camera
My camera lens isnt working it says "lens error please restart"
Hey it was raining a few days ago and my camera got quite a few drops of water on it. When i got back inside I cleaned it and i was using the camera and it was working just find but when the lens opened up it made a creeking/screeching sound (but it still worked when i took pictures). Now my dosnt take pictures because the when i switch it to camera/video mode it says "lens error, restart camera" i restart it but it still dosnt help.
Can anyone help
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
mcomijohns
  • 477 Answers
SOURCE: Lens error. Restart camera.
this is very common has the camera been near the ocean??? it does not have to be dropped to give you this error. repair on you lens runs 85.00 for repair. or a new lens for 125.00
Posted on Jun 27, 2009
  • 164 Answers
SOURCE: Canon PowerShot SX100 IS Lens Stuck
If the lens does not extend/retract when the camera is powered on, then lens assembly is damaged.
Unfortunately, such Canon SX100 (and the SX110 too) has a very fragile lens assembly, and it's damaged very easily. Most of the times the internal gears, the plastic post guides and the motor are damaged at the same time, so the only solution is to replace the whole lens assembly.
The lens replacement requires a qualified camera repair technician, unless you want to try in repair it yourself, which requires tools (scredrivers, soldering iron, desoldering tool, magnifier glass with light, etc).
Best regards,
Posted on Jul 22, 2009
tennisplay
  • 4 Answers
SOURCE: Lens Error, Restart Camera
Try turning it on and off, maybe even remove the battery for awhile. If the lens is physically damaged, it would actually need servicing to fix the problem. You'll likely need to look for a repair shop, a great one and probably the most popular for the Canon Powershot cameras is camerasandparts.com as they only work on the powershots. They tend to be the place if you need help with one of these powershot problems. They don't charge much at all and they do all the service on the camera too. Go to that site and you'll see they have your specific lens error problem posted right there for your G9. Good luck taking care of it, that's a very nice model.
Posted on Jan 09, 2010
  • 102366 Answers
SOURCE: PowerShot SD630 lens stuck out, says lens error, restart camera
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 23, 2010
SOURCE: Lens error
Powershot S3 IS: lens error message, lens juddering on startup but not coming out. Tried all tricks on internet without success, so decided to dismantle camera. Localised fault to optical position encoder on first transfer gear of the ultrasonic motor which controls lens position. Sensor was misaligned and/or dirty, so the camera could not detect motor rotation. Removed sensor, cleaned it, glued back in position with cyanoacrylate glue. Reassembled camera (only one internal bolt left over - not bad!) Working 100% again.
Posted on Jul 29, 2010
Nikon Coolpix ''lens error'' fix...
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Dec 06, 2009 | Nikon COOLPIX S200 Digital Camera
When I turn my camera on, it will than read: "lens error, restart camera."
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
May 27, 2009 | Canon PowerShot SD1100 IS Digital Camera
Canon power shot g9 lens
Your best bet would be to have it serviced by a professional to get you going again, those are really excellent cameras. If you'd like to have it repaired, you can have the G9's repaired here: www.camerasandparts.com This place just does the Canons exclusively, they don't work on any other models. The best part, the work through them is superb and they are not expensive at all. It runs $89 for parts / labor on the repair and the servicing for the camera included. Plus they cover shipping back which we like. The best part is the work through them just excellent on the Canons, they'd be the place if you want to have it fixed. Hope that helps you with it, all the best. That's a great little camera.
May 10, 2009 | Canon Cameras
Problem with the lens
Apr 25, 2009 | Cameras
Lens error on Cannon Powershot SD600
Jan 03, 2009 | Canon PowerShot SD600 Digital Camera
Kodak easyshare m753
Hi Nancy This error is due to a few conditions that the camera might have been involved in. First the camera might have been dropped, powered on while in a case or in a purse or pocket. dropped in sand been at the beach around salt water. Any of these listed things could have caused your problem it could have also been a defective lens. But like most camera companies they do not warranty lens errors because they are one of the first things to go out because they fell they are right and you are wrong. now if you got this camera from a place like walmart or target. and you bought a extended warranty with it take it back. If not try any way you never know what they might do just tell them it is not doing right and you would like to exchange it for another one.
Mar 18, 2008 | Kodak Easyshare M753 Digital Camera
Lens error on brand new G9
i got the exactly same problem!!
i bought it on 16th/Feb, next day,17/Feb not more than 20 pictures i took, the issue comes (lens won't action while shift the zoom lever, but it's working ok while switch on and off the camera)
so i bing it to the shop with my angry, they just said to me that you must dropped the camera.
--but i sware i didn't !!!
now they took the camera to Canon base for the exam...
Jan 20, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
The lens on my camera won't retract.
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
Jan 05, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Lens wont close.
Damage to the lens Mechanism is a repair shop job- or contact Kodak tech support for further advice.
May 13, 2007 | Kodak EasyShare CX7430 Digital Camera
Canon PowerShot A430 Digital Camera Logo
76 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
