Question about Vizio L32 32 in. LCD HDTV
I have a vizio hdtv which I have connected to my computer tower but there is no sound, I have connected it via a vga cable and have also connecte the audio cables without avail, I have been able to make the regular computer speakers work but the tv speakers wont work I have checked the mute mode, my computer mute mode as well but nothing, can you help me?
    President:
  • 3,085 Answers
Set the TV sound to EXTERNAL
Posted on May 14, 2010
My VIZIO 1080P cannot connect thru HDMI cable To My Laptop
Just use the VGA/PC input instead. It requires an rs232 cable. It's HD and will automatically adjust the proper settings for the display.
Jun 08, 2014 | Vizio 47 120Hz 1080P Full HD LCD HDTV
Have a toshiba a10 and a vizio hdtv, what cable do I need to connect the two
Hi.
You don't say what you intend to do once the 2 devices are connected. I am going to assume that you just want to use the vizio hdtv as a large external monitor.
The laptop's vga (15-pin blue or black D-shaped) port can connect direct to the hdtv via it's blue vga (15-pin blue D-shaped) port.
However, your toshiba a10 laptop is relatively old, discoontinued technology with (in original specification) low RAM (256mb ddr), a single, slow processor (2.2ghz celeron) and slow (4300rpm), small hard drive (30gb), with limited, low level vga graphics capability, running xp home edition operating system. VGA is a slow analogue video technology.
To get the full benefit of the hdtv, which is almost state-of-the-art, you need a laptop with a fast dual or quad core processor, 3-4gb ddr3 RAM, 320-500gb 5400-7200rpm or solid state HDD, running the latest windows 7 operating system. Such a laptop would have hdmi ports and powerful, fast, state-of-the-art graphics capability.
A new laptop would unlock the full spectrum of , high definition video, high speed audio-visual streaming, fast video-editing, multimedia functionality between the two devices.
For your current laptop you need a male-to-male 15-pin, D-Sub VGA cable.
For the recommended or a similar, modern laptop you would need an HDMI cable.
Hope this helps.
Aug 02, 2011 | Computers & Internet
I have a vizio vf552xvt lcd led hdtv and i wood like some help with connecting my computer dell xps 8100
You can connect your computer in your television by using VGA connector cable or HDMI cable.Then set the TV into PC in by selecting at the menu setting.
Jul 04, 2011 | Vizio VF550M 55 in. LCD HDTV
How to connect a pc
If your flat panel TV has a 15 pin VGA input, which most new HDTV's have nowadays, you would simply connect a monitor cable (VGA) from your computer tower to your TV. If it doesnt, you will need some sort of converter, adapter, or card for your computer, allowing you to connect via HDMI.
Mar 19, 2011 | Vizio Televison & Video
Just purchased a Vizio 37" HDTV with Netflix app
The Vizio does not have Internet capabilities. You need to hook up a computer via the VGA or HDMI port. Then youor computer controls what you do with the intenet.
Dec 03, 2010 | D-Link DIR-625 (790069292637) Wireless...
No sound from monitor
that problem is very common on a viewsonic tv replace the power supplyboard.
Jun 04, 2010 | ViewSonic VX1932WM LCD Monitor
Buzzing noise coming from Vizio HD TV speakers
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
Apr 07, 2010 | Vizio VW32L 32 in. LCD HDTV
Hook up computer to tv
The Vizio GV47LF HDTV's connection bay has everything we'd expect. It includes a pair of HDMI inputs which can take 1080p sources (at 60 but not 24Hz), two component-video inputs, one A/V input with composite video and one with composite and S-Video, one RF input for cable for antenna connections, an optical digital audio output, and a VGA-style PC input for PC connections.
If you're connecting a computer, you'll probably be disappointed that the VGA input maxes out at 1,360x768 resolution (which did look pretty good) instead of the full 1,920x1,080. We did connect a PC via HDMI and got 1,920x1,080 resolution, but the image didn't look as sharp as the 1,360x768 version. Again, we believe this has to do with the lack of a dot-by-dot mode, although perhaps people playing with picture settings, either in the Vizio or in the video card's drivers, can achieve a better-looking higher-resolution computer image. All-in-all, shoppers looking for a big computer monitor would be better served by the Westinghouse LVM-47w1.
Jan 30, 2010 | Vizio GV47LF Television
I want to hook my vizio tv up to my computer what cords are needed?
Likely standard VGA ... unless you have an HD card in your computer ... I got one for mine in order to play blu ray after I bought a blu ray drive for my computer. In that case I needed an HDMI cable. HDMI passes both the video and the audio, otherwise you need to connect also a stereo audio cable between your sound card output and the tv input, close to the computer VGA connection.
So:
1.) http://www.google.com/search?sourceid=navclient&ie=UTF-8&rlz=1T4ADBF_enUS255US256&q=SVGA+Cable
2.) http://www.newegg.com/Product/Product.aspx?Item=N82E16882021054&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-Audio+/+Video+Cables-_-Rosewill-_-82021054
Nov 23, 2009 | Vizio L32 32 in. LCD HDTV
SAMSUNG HDTV LCD DIRECTIONS ON CONNECTING COMPUTER TOWER SO IT IS EEN ON TV SCREEN?
depending on what graphics card and audio connectors you have on your computer will determine how you connect it but generally speaking there are a few ways to connect video and the same for audio.
If your computer has a DVI port then you can use DVI to HDMI cable ( which you would have to purchase yourself and make sure the length of the cable is sufficient )
If your computer has VGA for your graphics card then you would get a VGA to VGA cable ( making sure the connectors are the correct type ie male or female ) you would have to check your computers vga port and the vga port on the HD TV and again get the correct length.
WIth regards to audio you can get a double ended 3.5 mm audio jack audio cable
OR
an audio cable that has one 3.5 mm audio jack and 2 RCA ends ( one for left audio and one for right audio generally colour coded red and white )
OR
If you have optical you can get an optical audio cable.
If you have an amp then you could do the audio through an amp and connect your computer to the amp and depending on the amp will depend how you configure the amp ie surround sound or stereo.
Apr 18, 2009 | Computers & Internet
Vizio L32 32 in. LCD HDTV Logo
250 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
