Question about InSTEP Baby Gear
I am in need of a new rim for an InSTEP Ride and Run - the one I have uses a 16" tire - where can I get one?
    Top Expert:
  • InSTEP Master
  • 79,024 Answers
Hello, I am sorry but we are a technical support service and have no parts connections or catalogs of supplier's for parts for anything, have u tried a hardware store, they carry a variety of small wheels, one might work. Sorry we can't be of more help here, just have no resources.
Posted on May 14, 2010
What are the wheel and tire sizes front and rear for my 99 1200 sportster?
Fitment for 1999 XL Tubeless Cast Wheels:
Wheel Position and size = 19 inch Front; Rim Size and Contour = T19x 2.15 MT; Rim Valve Hole Diameter = 0.45 inch; Tire Size = Dunlop D401 ELITE S/T 100/90-19
Wheel Position and size = 16 inch Rear; Rim Size and Contour = T16 x 3.00 D; Rim Valve Hole Diameter = 0.35 inch Tire Size = Dunlop D401 ELITE S/T 130/90-16
Wheel Position and size = 19 Inch Front; Rim Size and Contour = T19x2.50 TLA; Rim Valve Hole Diameter = 0.45 inch Tire Size = Dunlop K591 S&FR Elite SP 100/90-V19
Wheel Position and size = 16 Inch Rear; Rim Size and Contour = T16x3.00 D; Rim Valve Hole Diameter = 0.45 inch Tire Size = Dunlop K591 S&FR Elite SP 130/90-V16
Tire Fitment for 1999 XL Tube Laced Wheels:
Wheel Position and size = 19 Inch Front; Rim Size and Contour = T19x2.50 TLA; Tube Size = MJ90-19 Tire Size = Dunlop D401 ELITE S/T 100/90-19
Wheel Position and size = 16 Inch Rear; Rim Size and Contour = T16 x 3.00 D ; Tube Size = MT90-16; Tire Size = Dunlop D401 ELITE S/T 130/90-16
Wheel Position and size = 21 Inch Front; Rim Size and Contour = T21x215 TLA; Tube Size = 3.00 x 21; Tire Size = Dunlop Touring ELITE II MH90 - 21 56H
Wheel Position and size = 16 inch Rear; Rim Size and Contour = T16x 3.00 D; Tube Size = MT90-16; Tire Size = Dunlop Touring ELITE II MT90 - B16
Tire Pressure - All Models:
Cold up to 300 Lb. Load (includes rider, passenger and cargo)
Front = 30 psi (2.1 bar)
Rear = 36 psi (2.5 bar)
Up to GVWR maximum load
Rear = 40 psi (2.8 bar)
Jul 07, 2014 | 1993 Harley Davidson XLH Sportster 883
Will 16 inch tires fit on a 97 ford windstar
If the stud pattern and off set is the same they will fit on. The problem is that regulation requires the ride height to be maintained which means that you will have to fit a lower profile tyre . For example if you use 15 " 205/95-r15 tyres then you may have to go to 205/65 r16 tyres . Talk with a tyre shop and discuss the legal requirements as far as insurance goes with a wheel size change
May 26, 2014 | 1997 Ford Windstar
What kind of tires should we get for a 2008 Jeep Patriot 4wd. It has Good Year P205/70R16, but we're not very happy with the tires. Do you have any recommendations? Can you put P215/65R17 on a 16"...
No, you sould stay with the recommed size for your vehicle. The 16" is the rim size. If you want a bigger tires and wheels you need to change your rims to 17". If you want good tires you want to look for something with a good rating.The original size for the vehicle is calibrated for speedometer and the ABS of your vehicle and so is you gear ratio in the trans and front and rear differential.
Jan 10, 2011 | 2008 Jeep Patriot
My '08 Highlander Sport needs new tires. I'm considering the Bridgestone Alenza. It is a 255/55R19 whereas the OEM tire is 245/55R19. Any advise would be appreciated. Toyota dealer says I shouldn't do...
Hi,the 255/55R/19 is just a little taller ( 3/4--1" inch.) than the oem tire and should not be an issue to use, i took the 16" rims & tires off my 99 f-350 truck and put 18" rims and tires from a 2008 f-350 on it ( the dealer said they would not even bolt on!! but they bolted right up with no issues,and they improved my ride tremendously.) as long as you have enough clearance between tire and fender it will not be an issue at all. yz-maniac.
Oct 14, 2010 | 2008 Toyota Highlander
16 inch bicycle tire is flat. Need replacement, where to buy?
Call Dynacraft (bike maker) at 1-800-551-0032. My daughter's rear tire was flat and they sent out a new tube for free. She had the bike for only about 4 months. They also sent out a new rear tire as bearing/coaster brake assembly was make noises. The only problem is her original rim was purple and they sent out a silver colored rim as they don't have purple replacement part. I also had to install the tube and tire on the new rim. They only send replacement parts not assemblies.
Sep 16, 2010 | Dynacraft Girls 16" Barbie Bike
2006 Mini Cooper S - tire conversion
You are right about the quality of ride,and would probably notice better handling as well.However when selecting new tires you need to awnser 3 basic questions.Where do you live?,what type of driver are you?And of course, what is your price range.If you live where you get snow and ice your going to need all-season tires.If you dont have to worry about that I would go with summer tires.They tend to offer better grip and ride and are also cheper.The down side is they tend to wear quicker.As far as brand,if money isnt an object go with bridgestone,michelin,or goodyear.If it is there are many good tires for less,check out sites like tirerack.com and you can read customer reviews.Hope this helps.
Nov 25, 2009 | 2007 Mini Cooper S Convertible
New wheel in instep duo stroller needed (BACK WHEEL)
I should go to he Pram Shop where you bought it from, if it has closed down go to a Mothercare Shop or similar Pram Shop. They will be able to get you the information you need.
Apr 08, 2009 | InSTEP 10K Single KA106 Jogger
I have a 2004 (bought new) honda crv. a couple of years ago i replaced the tires with the same tires that came with the car: bridgestone dueler h/t d684 bl p205/70r15 95s 40,000 mi warranty. the first two...
I recommend taking your vehicle to a shop (any shop) that use a Hunter tire balancer. These machines can detect all variables that affect ride quality by not only spinning the rim, but it uses a roller to inspect the tire itself for its "road force". They can also measure the rim while on the machine for run-out to detect for a bent rim. There can be times when a tire can be mounted to the wheel in a postion that promotes more vibration, but the hunter machines can check and show the correct location to minimize the feel to the driver. Here is a picture of the kind of balancer you want your vehicle serviced at. Please let me know how things work out.7e27679.jpg
Mar 13, 2009 | Honda CR-V Cars & Trucks
Need to know how many lugs on a 96 chrysler lhs and are they 16 inch rims?
5 lug nuts , and tire size is printed on all tire sidewall , look at the tire notice something like example > 235 - 60 - 16 , or 225 - 70 - 15 . the number 16 or 15 will indicate if you have 15 or 16 " tires and rims . hope that helps you . if the tire is 16" so is the rim .
J5
Jan 18, 2009 | 2000 Chrysler LHS
Baby Gear Logo
29 people viewed this question
Top InSTEP Baby Gear Experts
Jennifer Rock
Jennifer Rock
Are you an InSTEP Baby Gear Expert? Answer questions, earn points and help others
