Question about Kenmore 63942 Dryer
I have a kenmore dryer series 80 model#110.66812690 it is blowing cold air. Does any one have an idea what could be wrong?
  • Kenmore Master
  • 494 Answers
Is it gas or electric? If it's electric, it will have a large, gray 220 volt power cord. If it's not under warranty, you'll have to call a local repairman. It's probably the heating element. Easy things to check. Make sure your lint filter is not clogged. Check the vent cap outside and make sure the flap is not stuck and is easy to open. Using a flashlight, make sure it's not clogged inside the vent either. The back opening of your dryer may be clogged as well, but it may not be easy to check. Hope that helps.
Posted on May 15, 2010
MY kenmore 80 series dryer does not heat up it only blows cold air what could be wrong with it ?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 29, 2011 | Dryers
Kenmore Electric Dryer model #11060812990, 80 Series - dryer is working but only blowing cool air.
heatman101
Jun 15, 2011 | Kenmore 659 Electric Dryer
I own a Kenmore dryer 80 series and the dryer works; however, its not blowing out hot air?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 25, 2010 | Kenmore Dryers
Gas dryer starts blowing cold air after 5 minutes
This sounds like the dryer coils are failing. They tend to fail as they heat up. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Jun 24, 2010 | Kenmore 73932 Gas Dryer
I have a Kenmore 110 60812990 80 series dryer
bad heater box fuse,get the model number from inside the dryer door,and go to your local appliance parts store and give them the number and they will get you a thermal fuse kit,remove the back of dryer and you will see the heater box on the right side
Feb 02, 2010 | Kenmore 64742 Electric Dryer
Kenmore 90 series electric dryer blowing cold air only
1st check the breakers
2nd check wiring in back to see connections are secure.
3rd check element. It would be burned in two.
4th check thermal overload switch which is located underneath top of dryer. Easy to remove top. Probably 4-6 screws.
Jan 15, 2009 | Zanussi TC7102W Electric Dryer
Kenmore 80 series runs but dont blow hot air
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
Kenmore Dryer - Series 80 - Model 96586200
the brown streaks are from the seals most likely from the front seal ... if your handy it will be an easy fix..
Oct 12, 2008 | Dryers
Kenmore 63942 Dryer Logo
184 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
