Question about Toshiba 32A41 32" TV
The volume does not go up , it stops at low mode and some times goes down by itself
    Problem Solver:
  • 5 Answers
YOUR VOLUME CONTROL BUTTONS MAY BE DEFECTIVE.
Posted on May 15, 2010
2 Suggested Answers
Shuttle83
  • 1139 Answers
SOURCE: 36a43 volume goes up and down buy itself
This problem sometime occurs due to a bad capacitor in the volume control circuitry. You will need a multimeter and a schematic to find out the proper voltages within the volume control circuitry. I would suggest that if you do not have a background in electronics that you take the set to a qualified shop for repairs.
Thank you,
Shuttle83
Posted on Nov 14, 2007
Samsung 3d bluray volume keeps goind down by itself?
The volume down button on your remote may be stuck. Take the batteries out of the remote and try operating the player from the onboard buttons and see if that stops it. If it does then it will be the remote. If it doesn't, then it is the player.
Nov 08, 2015 | Samsung Bd-c6800 3d Blueray
Got the Boston Tvee 25 and was able to program the volume up ok, but not able to program the volume down or mute functions. The process is the same but ive tried 100 times with no luck! Any help?
I had this same problem and it was due to their instructions which do not adequately explain the setup procedure.
On my own, I was successful in programming volume up but that was all. I assumed that for volume down I would hold the power button and the VOLUME DOWN button and wait for the flashing light just as I had for volume up. Problem is, you never get a flashing light.
Today, I spoke with a rep from Boston Acoustics who patiently explained that step one of the instructions has to be done the same way each time as it is the step that puts the soundbar into programming mode.
It is only at step 2 that things change.
The solution is to hold the power button and the Volume Up button every time in order to get the system into programming mode. Once the light is flashing, in order to program Volume Down, you then hold the Volume Down button until the light goes solid. Once the light goes solid, then press the volume down button on your remote 4 times slowly. Works like a charm.
Works the same way to program the mute button. Follow step one to get the unit in programming mode. Once the light is flashing, hold down only the mute button until the light goes solid. When the light goes solid, press the mute button slowly 4 times.
OBTW, this was programmed with a Logitech Harmony 650 remote unit.
Jun 05, 2011 | Boston Acoustics TVee Model Two TV...
Sound wont work
If sound won't work while playing videos from Youtube, it could be either of the following:
  1. The volume control of the video itself is in mute or low mode;
  2. The volume control of the headset or speaker is in low mode;
  3. The volume control of the computer itself is in mute or low mode that can be found in the task-bar sound icon; or
  4. The computer itself has no audio device installed.
Sep 06, 2010 | YouTube Videos
I have a iphone 8GB and is on silent seen nd i don't know how to remove it on silent? pls can u tell me want to do?
To enable/disable the silent feature on an iPhone, simply look to the left-side of the phone. There will be 2 buttons there:
1. A small, switch that goes left/right. 2. A longer longer that can be pressed up/down.
Button #1 is the silent toggle switch. Moving it to the left enables silent-mode; to the right disables silent-mode.
Button #2 is the volume adjustment button which will raise the volume if pressed up and decrease the volume if pressed down.
Note: If you press the volume bottom down all the way, the handset will mute itself. When using the volume button, a volume indicator will appear on-screen to indicate how loud/quiet the phone is. If there are no white bars present on the indicator scale, then the iPhone is muted. Press up on the volume button a few times to increase the volume and disable mute.
Aug 11, 2010 | Cell Phones
My reciever turns itself off
You most likey have a wire short on your center or rear surround speakers. The wire short will be between the + and - points of the speaker wire.
To find the problem speaker, disconnect one of the 3 speakers at a time from the back of the sony and see if the problem goes away. Once you identified the offending speaker, check both the sony side and speaker side for the short. The small wire strands are hard to see and it only takes one to trip the protection mode, so look carefully.
Mar 07, 2009 | Sony STR-DE845 Receiver
Onkyo ts595 goes into protect mode with volume increase
HI check your speaker cables are not touching, also make sure "b" speakers are not on and that all your speakers are 4ohm or higher as this will cause the amp to shut down if they are to low an impedeance,The amp is protecting itself when it shuts down.
hope this helps.
CABLE GUY.
Aug 03, 2008 | Onkyo TX-DS575 Receiver
My samsung HT-TX75 keeps shutting off in a few minutes saying protection.
protection mode activated to protect from serious damage and please follow me.1-shut down your system2-make volume in low position3-remove all your connected speaker4-switch your system on and watch if it does not go to protect mode insert your speaker one by one until you find the bad one and change it and start with cable change first and then speaker itself-if it goes to protect mode you must call service center.
Jul 07, 2008 | Audio Players & Recorders
PROTECTION MODE
The unit may be experiencing an overload caused by a short circuit, internally or externally. Try disconnecting all the speakers, then turning up the volume. If nothing happens, connect one speaker at a time and turn up the volume to see if you get more sound. You may have a speaker that has shorted internally and this will help you discover the bad one. However, if when you have all the speakers disconnected, and the unit still goes into protection mode with the volume up, then there is a problem with the unit itself.
Hope this helps, and please rate my advice, good OR bad.
Feb 04, 2008 | Audio Players & Recorders
Panasonic 50" LCD TV PT-50LC13
I did the following 'press and hold both the "VOLUME Down" button on the TV itself and the TV/VIDEO key on the remote control simultaneously for about 7 seconds (they say over 5 seconds in the manual)"
Will in the service screen I selected the number of hours of the lamp with the down arrows and the action buttons. Then I simply pressed and held the "down volume button" on the remote until the number of hours was 0. Then I turned the TV off, then back on and the message was gone. This worked for me.
Jun 21, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Toshiba 32A41 32" TV Logo
69 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
