Question about Nakamichi AV-10 Receiver
Nakamichi AV-10 very little sound on the center speaker
I have Nakamichi AV-10 for a long time now. just a while ago i knowtist that very little sound come out from my center speaker. i check the wire, i test tone it, and i switch the speaker, notting work.
thank
chai_2424@yahoo.com
  • 1 more comment
  • bud2008 May 26, 2008
    My AV-10 seems to be working fine except when I'm watching/listening to something in Dolby Digital, I only get the background channels and effects; no dialog. If I press the DD button on the remote, it converts to "downmix" and I get the dialog but lose the surround sound. It almost sounds like a stereo signal without center channel.
    I've checked all connections and tried a variety of fixes, without success. I also tried to boost the level on each output but the center channel at +10 still isn't loud enough to push the dialog over the other channels.
    I'm beginning to think it's a receiver problem, not "operator error."
    Anyone have any suggestions? Thanks
    continuing last post ... forgot to mention that I'm taking an Optical signal from a Direct TV DVR directly into the AV-10.
  • bhardy777 Oct 09, 2008
    I have the same problem. I get very faint audio from the center channel. When I run the test tone, it is still very faint out of the center channel. Speaker and wire all work fine.
The same thing happened to my Nak AV-10, brought it in, turned out soldering on the inside for the center channel had to be resoldered.
Posted on Apr 14, 2008
  • 31 Answers
Could be the speaker, try connecting another speaker and cable and see if it improves. If the problem is still there and you've checked all the settings insuring that its not turned down, then could be an internal problem with the receiver.
Hope this helps a little at least.
Posted on Mar 30, 2008
No audio from Nakamichi av-10 receiver. Checked all connections and speaker buttons. Even headphones don't provide any audio
There is a protection circuit in that unit. It has a relay that is either dirty or has detected a fault that might or might not be there.
Sep 16, 2013 | Nakamichi AV-10 Receiver
Lost Nakamichi av-10 owner's manual - can you help me get this information?
  • When you get to the link click on "Click here to start download from MediaFire.." and the PDF will download onto your computer.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 11, 2011 | Nakamichi AV-10 Receiver
Remote controller for Nakamichi AV 10 amp. stopped working last night despite replacing new batteries. Red LED not illuminating when 'power' button depressed. Any suggestions for repair/replacent of...
I got the Nakamichi Av-10 i too face the same problem i just tap the remote with my palm and it starts working...:) just try this am sure it should work
Jan 07, 2011 | Nakamichi AV-10 Receiver
Hi, my Nakamichi Av 10 receiver tuner and the video AUX section is dead and does not work except for the Tape in
I am facing the same issue All Analog inputs except for Tape in does not work and the tuner does not work on my Nak AV-10
Jun 03, 2010 | Nakamichi AV-10 Receiver
Nakamichi AV10. Re: left channel softer than the right one.
Hi,\
Its an issue with the tone switch activate and reactivate it to get back to normal volume on both speakers, and would suggest you to clean the switch with WD40 and it should resolve the issue
Jul 16, 2009 | Nakamichi AV-10 Receiver
Nakamichi AV-7 5.1
in this case the centre speakers are the main route to the sound. 5.1 is for movies, where the centre speaer takes predcedence.
Aug 29, 2008 | Nakamichi AV-7 Receiver
Nakamichi AV-7 (issue with surround mode - prologic)
Nice Receiver!
>In your surround sound settings make sure the levels are set correctly and the distance from your listing point to the furtherest
speakers are set to accommodate the levels etc.
>How many speakers 5.1, 6.1, or 7.1 (1meaning subwoofer)
>Pro-Logic supports 5.1 but not sure about 6 or 7
>Pro-Logic II does support all
>Make sure you are hear the sound from all sometimes the sound is really faint if you are in surround mode
Thank You and good luck
Aug 28, 2008 | Nakamichi AV-7 Receiver
Nakamichi TA-4A receiver no sound
HAI,AMP WORKS FINE , CONNACT ANY OTHER TO AMP(CD,DVD,COMPUTER,MOBILE,TV) IN BACKSIDE INAUDIO OR PRE_AMP .THEN SELECT  PLAYER TO IN MODE YOU HAVE INSAERTED.THE SOUND IS OK
Jun 26, 2008 | Nakamichi AV-10 Receiver
Nakamichi AV-10
The contacts in the switch are probably oxidized or warn out. More than likely it is oxidized.
You can get some switch and control cleaner from most any electronics poarts supplier.
You have to open the reciever to get access to the noisy switch. You would then spray a little of this cleaner in to the switch. Then work the switch back and forth rapidly to clean it.
If this does not work, then the switch would have to be changed.
If you don't feel confortable to do this procedure, you can bring the receiver to a service shop. They would be doing this type of service routinely.
Jerry G.
Nov 16, 2007 | Nakamichi AV-10 Receiver
Nakamichi AV-10 Receiver Logo
416 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
da surgen
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
