Question about Bosch Nexxt 300 Series WFMC2201UC
Door gasket has mildewed and need to remove it for cleaning.
How do you remove the door gasket on my 300 series Bosch clothes washer?
  • Bosch Master
  • 744 Answers
This video will show you how to change a door seal on this Bosch front loader washing machine
Posted on Jul 22, 2013
    Top Expert:
  • Bosch Master
  • 79,851 Answers
This is a fatal flaw of front load washers, i see this post over and over on a daily basis, all u can do is clean the front seal with bleach or Tilex brand mold and mildew remover (use rubber gloves, very caustic) as often as required, also make sure the tiny drain hole in the door seal is clean and clear.
Posted on May 14, 2010
Mildew odor in the machine....can't get rid of it and makes clothes STINK!
If you have a smelly front loading clothes washing machine, toss in a Finish Geltabs (the ones that are all liquid) and run the machine on a hot wash cycle, medium to heavy load (to get more water in the tub) with no clothes in the machine. You don't need to use much of a spin cycle so set it on low. The washing machine will come clean and even the moldy spots on the rubber gaskets will disappear. A second treatment may be needed if the smell is not completely gone. We tried everything from vineger to bleach to baking soda to borax to commercially available odor removers from Whirlpool and Tide. Nothing worked until I hit on this idea. It's cheap, easy and can be done anytime your machine needs a refreshing. I used the orange Geltabs but any fragrance would be fine. Keep the door on your washer open a bit when possible to air out to help preclude those nasty smells.
Oct 21, 2012 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Help!! I cannot leave my washed clothes in the washer longer than a few hours without them stinking. This has been an on going problem. No I have mildew around the door gasket. I have cleaned under the...
Well it only takes seconds for mildew to start forming on wet clothes it is advised by the manufacturer to remove them immediately after the cycle stops. I would run the machine on hot with detergent and maybe some towels that will rub any off, then i would re-wash the load.
Hope this helps
May 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Mildew
take straight bleach on a white rag or towel and while wearing rubber gloves, wipe the surface until clean.
then run the towel thru a cycle with other whites ...
May 31, 2010 | Bosch Nexxt 300 Series WFMC2201UC
Odor problem
clean the front gasket on the door with Tilex, they get mold and midew, also run a tub of hot water with some Tilex brand mold and mildew remover through it, then run a second washer tub to clean Tilex completely out, u will need to do this about once a month, and yes all fron loader have this odor problem.
May 20, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
I have a problem with mold or mildew inside the door in the gray gasket area
Clean the gasket with a bleach solution and a Mr Clean Magic Eraser .
leave the washer door open slightly from now on.
very common compllaint.
Nov 08, 2009 | Bosch WFMC2100UC Nexxt Essence Washer
We have mildew in the rubber gasket behind the front door
use a good mildew cleaner on gasket the gasket gets wet from when clothes are taken out and drip on gasket mildew grows on damp/warm surfaces
Sep 26, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch Nexxt 800 Washer Distugsting Smell
USING NON BIOLOGICAL DETERGENTS AND LOW TEMP WASHES WILL EVENTUALLY LEAVE GUNK IN DRUM AND AROUND DOOR SEAL TRY USING BIO DETERGENT HOTTER COTTON WASHES AND THE OCCASIONAL 90 DEGREE WASH
Aug 08, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Lots of mold and mildew stains on front door seal.
Easy, try running a cup of white vinegar thru the wash cycle. I sell and fix these and it usually work everytime. good luck
Dec 20, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Mildew and Smells
pull out soap dispenser draw and look up to where water comes out. my mach was full of mildew. i removed the top of dispenser soaked in bleach. i believe this is where mildew problem starts and spreads to drum and gasket
Nov 24, 2008 | Bosch WFMC 3200 Front Load Washer
New Bosch water not draining
we have all bosch repairs in our channel
Apr 01, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Nexxt 300 Series WFMC2201UC Logo
576 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
