Question about Partner Tech PT-5500 PC Desktop
Display problem screen displays for about ten seconds then blacks out--touch function works with a separate monitor.
    Scholar:
  • 47 Answers
Try to uninstall and reinstall video card driver. Check power settings in control panel. If settings have been checked and still the same issue and working with another monitor,then might need to replace the monitor.
Posted on May 15, 2010
Goes black, blinks and sometimes works fine
Sometime the cross-talk of signals is caused by the wiring behind the computer, touching. Separate the wiring.
Mar 05, 2014 | Apple Cinema Display 23" HD Monitor
Display not working but system functioning
tried with other monitor just to ensure if the problem is only with in the monitor. if the same problem, the cause it could be the inverter board for screen back light which has component being shorted.
Aug 15, 2012 | Samsung SyncMaster 713N 17" LCD Monitor
My monitor goes for 3 seconds black, every 1 minute
First thing, try to connect the monitor to another CPU and see if its gonna work. If it doesn't, then this might be a capacitor failure. One of the capacitors in your monitor that are responsible for holding up power for proper display is faulty. A faulty capacitor is either bulged(with a hump head) or burst. This causes the monitor to go off a few seconds after you switch it on because the capacitors can no longer hold power long enough for your display. One way to work this around is to take your monitor to a Computer Technician to open it up and probably replace the faulty capacitors
Nov 06, 2011 | LG Flatron L1718S LCD Monitor
I have a type 6734-LB1 17" Lenovo ThinkVision
where will i get to install the software/drivers of IBM 6734-L-B-1 for listening Music
Sep 30, 2011 | IBM L170M (Black) 17 in. Flat Panel LCD...
The computer boots but there's no display
check the display properties for dual monitor settings in
display properties>settings> check all options
I think it is set for external display u change to dual display. then both displays can work. or there is some display symbol of some function key. check that and press
Jun 17, 2010 | Acer Aspire One Netbook 8.9" Notebook
I have a toshiba A100 with windows 7, 32 bit. i jsut got a s-video to VGA so i can watch movies and such on my tv. however, there is no picture on the tv, windows says everything is working but all i get...
PC Running Windows
Windows XP is used, but Windows 2000 should be similar, as is Windows ME -- but Windows 98 and 95 are different.
  1. Please connect your PC to an external monitor to try this out BEFORE coming up to speak. Have your VGA adapter cable ready as well if your Laptop needs one and bring it with you to the stage.
  2. Connect the external monitor to the PC
  3. On the Laptop display, RIGHT CLICK on the desktop and say Properties.
  4. Click on the SETTINGS tap (far right) If you want your displays Mirrored, (what is on the internal display is on the projector) you should make sure the box next to " Extend my Windows desktop into this monitor" is UNCHECKED. Some older systems have a “ mirroring” box, check that if you see it and want mirroring. If you do not want mirroring, skip the next section and continue with 5a below, then return to #8 of the section immediately below.
  5. NOTE: The following steps apply if you are running your PC in MIRROR mode only. If, however, you're running your PC in NON-MIRROR mode you need to continue with these special instructions instead.
  6. Drag the screen slider to 1024x768 (if your laptop will let you.) Typically, the external monitor MAY limit this setting. If your screen display is higher, it might not display on the projector, so you might want to test this before you are ready to speak. Drag the color quality to Highest (32 bit) if available, or Medium (16 bit) if the first is not available.
  7. Now, look at your keyboard. Typically, one of the function buttons will have the words CRT/LCD or perhaps a small picture of a monitor on it. Note this key for future use. On a Dell, it is typically F8. And I have seen it in F5 as well. Your machine's keys will vary, but it should be there. Holding the FUNCTION KEY (FN), Press the proper function button ONCE and wait. After a few seconds, the second display should come on. Be patient, this can take up to 5 seconds. On the projector, it may take up to 10 seconds for the projector to detect your system and switch. Note: a second press of this function will (usually) switch to EXTERNAL monitor only. A third press will go INTERNAL only, and around the circle for each press after that. Also note that some laptops may do this sequence in a different order, so learn your system so you can quickly switch to the mode you want.
  8. Click on the ADVANCED button. If "apply the new display settings without restarting" is not selected, select it. Under Screen Refresh Rate, select 60 Hz. Click APPLY and CONFIRM the choice. Click OK to close the ADVANCED dialog window. Close the Display Properties Dialog. You should now see a mirroring of your monitor on the second monitor
  9. Testing: As a test, disconnect the second monitor, put your laptop to sleep. Wake it up and let it fully come up (log-in if necessary), and then reconnect the external monitor. On some machines, it should quickly display the screen in the last known setting (you may need to wait up to 10 seconds.) If it does not display correctly, press the monitor switching function key ONCE. Again, note that it may take up to 10 seconds to display, so be patient. If only the projector now displays, a few presses of the switching function key should bring it around to both displays again. If you cannot get the projector to display, recheck all your connections and settings stated above.
  10. Note that when using the Projector, after pressing the Function key for the monitor change, it may take up to 10 seconds for the monitor to find and lock on to your machine. Just wait for it. Pressing the FUNCTION key again may simply mess up your settings or switch the projector off.
  11. When you arrive at the front of the room to speak, connect your monitor to the display cable (BRING YOUR ADAPTERS FOR YOUR LAPTOP TO VGA IF NEEDED.) When the monitor switch is switched to display your laptop on the projector, it should detect the display and just show up, but some systems will not automatically switch. Again, if this does not happen, you may need to press your display function key to switch on the external monitor.
  12. A few more notes on this: Not all laptops work the same way, and there are some differences in Windows OS releases on the order of the switching functions. You should learn how yours works BEFORE you get to the stage. Also, I noted a difference between computers put to sleep before connected, and systems which have not been put to sleep. If the computer was connected to an external display, disconnected and then reconnected with no sleep in-between, the external monitor should should come right on when connected. However, on most of the systems I tested this on, if the laptop went to sleep between connections, it required using the switching function key to get the screens back on UNLESS the display was connected before waking the unit. On two Dell’s, pressing this key brought back the projector, but not the internal display, requiring two more presses of the key to get both displays on. Chalk it up to different hardware and software releases.
  13. When done, disconnect the external monitor. From the display menu drop down, you can reselect your desired display resolution.
Dec 30, 2009 | Toshiba Satellite A60 Notebook
Hear power on, black screen. wont do anything.
- try to connect you machine to an external monitor
- if the display appears on your external monitor the problem would be the LCD screen of your laptop (need to replace it)
- if there is no display on both laptop and external monitor i suspected it's the motherboard faulty
- send your laptop to service center to replace it (if it is underr warranty it's free
May 27, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Monitor flashes on then goes black.
I think you have the display shut off. the button on the bottom left will shut screen off. It will come on for a few seconds if you touch the screen, but will shut off again. just push the display button again and it should stay on.
Apr 02, 2009 | ViewSonic OptiQuest Monitor
SCREEN WON,T STAY LIT UNLESS I TOUCH IT
You are simply in blackout mode. This is so at night you aren't blinded by the glow of a screen. Here are instructions right from the manual to turn on or off.
Blackout Mode On and Off
When Blackout mode is turned on, the monitor display will turn off to
reduce power consumption.
This additional power enhances the sound quality.
1 Touch [VISUAL] on the main source screen.
The VISUAL selection screen is displayed.
2 Touch [OFF].
The backlit-display portion goes out.
3 Touch [OFF] again to cancel the display backlight.
To make the setting, set to “Setting the VISUAL Touch Button” (page
34).
If any button on the unit is pressed during Blackout mode, the
function will be displayed for 5 seconds to show the operation before
returning to Blackout mode.
While the backlighting is turned off, the function indicator
Jan 24, 2009 | Alpine IVA-D310 Car DVD Player
Monitor screen goes out (black) 2 seconds after turning on
Your site is extremely misleading and fraudulent. I was under the impression that I would at least get a hint at what might be a problem instead of you folks making me wait to get a money for something answer that you could have displayed on your main page. Places like yours have no place on the internet and I'm going to find out what I can do to report you.
Thank's for nothing
Jan 16, 2009 | Mag Innovision LT976S 19" Flat Panel LCD...
Partner Tech PT-5500 PC Desktop Logo
85 people viewed this question
Top Partner Tech Computers & Internet Experts
David Payne
David Payne
Are you a Partner Tech Computer and Internet Expert? Answer questions, earn points and help others
