Question about Kenmore 774 sq. in. Cooking Area Gas Grill 15337
Grill caught fire & went to 700 degrees
I left the grill unattended for a few minutes & it flared up. The heat went to 700 degrees. Will it be ok to use after it's cleaned up?
Thank you for your assistance.
    Sergeant:
    Champion:
  • 333 Answers
It should be OK. Just make sure you get ALL the greese cleaned out of the grill before you fire it up
Posted on May 14, 2010
Leg of pork 1.780 kilos how log do I cook it for
There's no magic number. It depends on what sort of result you want, the heat of your grill, the temperature of your meat, even your altitude. I would do a reverse sear, which means building a two-zone fire (or lighting only half of your gas burners), then using a meat thermometer probe and cooking it on the cool side of the grill until the middle of the roast reaches about 10 degrees (F) below where you want it. Then switch to the hot side of the grill and finish the outside (avoid lengthy flare ups). Let it rest, lightly tented with foil, for at least 20 minutes to give the juices time to redistribute and residual cooking to take place. Personally, I prefer my pork around 140 degrees (F), juicy and slightly pink.
Jun 11, 2017 | Grilling
On low the temperature is reading 700 degrees how do I adjust
Probably bad thermometer. Double check with a cheap oven thermometer. Warranty?
Apr 05, 2015 | Char-Broil Quickset Traditional 463761006...
It will only heat to 350 degrees, but the gage goes up to 700 degrees. In other words, how high can you get the temperature to with all burners on high? Thanks, Ron
LP or NG, all burners on high, top closed, out of the high winds (if any) 500+ degrees in 10 - 15 minutes. If not, double check temperture with a secondatry temperture device. If it an old unit, could be gas lines partially cloged. What size of flames come off of the burnes and what are the colors (AT THE BURNER, IN THE MIDDLE OF FLAME, AND AT THE TIP OF THE FLAME.). The olors will indicate the gas / oxyen mixture and therfore heating efficency and templture.)
Yellow is lowest - flame tip light blue almost imvisible is hotest.
Apr 16, 2010 | Char-Broil Commercial Stainless Steel...
The inside coating of my Silver C is also peeling.
it looks like paint but it is food and smoke enamel on hood is baked on at 1600 degrees no way to get grill that hot spray oven cleaner on top not the sides and wash off
Aug 01, 2009 | Weber Genesis Silver B Grill
Is not heating
i think when this happened to my sister it was the heating coil. her dryer caught on fire. don't run it unattended.
Aug 01, 2009 | Kenmore 700 6972 Dryer
Heat is out of control
check the back of the control knob. there should have a metal stem for control.
Jun 05, 2009 | Weber Genesis Silver B Grill
Need help smoking briskett on Char Broil Grill with smoker box
wood chips in the fire box. very low heat. around 200 degree.
maek sure the wood chip is wet and produce smoke. you need to monitor this through out the process.
briskette in the grill side without any heat. depends on the sixe and the thnikness of the meat, you need approximately 12-20 hours before meat become tender.
here are few web site you can get some information
http://www.smoker-cooking.com/howtosmokeabrisket.html
http://bbq.about.com/cs/brisket/a/aa111503a.htm
http://www.wyntk.us/food/smoking-brisket.shtml
http://www.bbq-fyi.com/how-to-smoke-brisket.html
May 29, 2009 | Char-Broil CharBroil 4637318 Grill
Grill not getting hot, fire not around burners, knobs are so hot you can't touch them. not getting over 300 degrees, fire seems to be behind knobs
We assembled our new Genesis E-310 yesterday. Went together nicely, but won't heat above 350 or so. It should get to 500-550 degrees withing 10-15 mins. Any ideas of what could be wrong?
May 11, 2009 | Grilling
Gas grill overheated
I might have an Idea to what happened. All grills have a drip pan, most all new grills have a drain for grease that falls from our savory meats. Well, if, (not saying that you haven't) but if, you have not cleaned the drip pan, there is still grease left over that gets absorbed by food droppings. IF this is the case, you had a ticking time bomb of a grease fire. The grill did not overheat, the grease caught fire. You said your grill was a year old; so the regulator did not go full blast and when they do go bad they do not let gas pass through.
Not trying to preach to no one because I have done it myself, never leave your gas grill on and unattended. I hate to say it but even the owners manual says it.
I hope I did not come off the wrong way and I hope this might give you an idea/thought of what happened.
Sep 26, 2008 | Thermos Stainless Steel Gas Grill
Kenmore 774 sq. in. Cooking Area Gas Grill 15337 Logo
132 people viewed this question
Top Kenmore Grilling Experts
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Paul Carew
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
