Question about Sony Cyber-shot DSC-W50 Digital Camera
????? How do you disassemble the lens?
    Problem Solver:
  • 5 Answers
You don't have to disassemble the lens. My camera would lens extend , pause and then lens retract, pause again, then lens extend, pause and then lens retract. It would do this maybe 4 or 5 times before displaying "ACCESS" on the screen and then shut down completely.
Where the lens extends from the body is the area I am referring to, there is a tiny gap large enough to slide a sheet of paper into. That is the area I shot a tiny drop/burst of wd40 into. Wd40 is sort of electronic safe and most of it WILL evaporate.If you would like, send me your email address I will send a photo file-picture of how i did it. Hopefully it is the same problem.
jgbhornung@hotmail.com
Just put "camera problem" in the subject box
Jim H
Posted on Mar 30, 2008
How to disassemble Sony 70-300 lens
Do you have access to a lens collimator and other equipment needed to ensure proper alignment when reassembling the lens? If not then you may just as well use a sledgehammer to disassemble the lens; it'll work just as well afterward.
Nov 28, 2013 | Sony Cameras
Canon 70-300 IS USM lens repair
Before you start disassembling your lens, let me ask this: Do you have a lens collimator and other equipment needed to ensure proper alignment when reassembling the lens? If not, you may as well disassemble the lens with a sledgehammer; it'll work just as well afterward.
Aug 10, 2013 | Cameras
Repair diaphram on Nikon 18 to 200 G ED lens
Before you start disassembling the lens, do you have a lens collimator and other equipment necessary to realign the lens when you reassemble it? If not, you may as well disassemble the lens with a sledgehammer; it will work just about the same afterward.
Jul 13, 2013 | Cameras
I cannot read dvd in my combodrive, my friend informed me that lens has damaged. so i want to any their is any software 0r solution to repair the lens.
hi there,
The lens can be cleaned by a lens cleaner however there is no software that can fix it. Mostly if the lens is damaged the combo drive may need to be replaced. However, if you are comfortable disassembling the combo drive you can replace the lens on your own.
Just have to know what Number/Type is the lens and you can buy a replacement and then you can open the Combo drive and replace it.
If you are not very familiar with disassembling a combo drive I suggest that you just have it replaced.
May 17, 2011 | Computers & Internet
I having trouble getting this back together, disassembled it to clean sand from the guide channels. I am sure there is a correct way. But can find no service docs
once again try,disassemble and asseble the lens unit,then clean the contacts of the lens unit and properly insert into the lens unit soket perfectly, takng precautions of the static electricity.
Apr 09, 2010 | Kodak EASYSHARE Z1485 IS Digital Camera
There is a small black tube like piece that has come loose inside my lense and I need instructions on how to disassemble. It has something to do with the zoom I think?? Nikkor 18-55 ED
The small black tube piece is a sliding light baffle which has come loose. Zoom lenses are very complicated to disassemble, and you have to have both the knowledge, experience, and the right tools to disassemble a zoom lens.
The tube should never have come loose in the first place, so I would classify this as a product defect. Contact Nikon, fully describe the problem, and insist that they repair the lens at no charge (although you will have to pay to ship the lens to their repair center).
Apr 26, 2009 | Kodak Pronea 24-70mm IX Nikkor Lens
Samsung L730 wont extend lens and dosent turn on right
Met the same problem. I disassembled camera and found a lot of sand in lens transmission. I couldn't move lens even by hand. It was strongly jammed. I had to disassemble lens block completely to remove all sand. Now camera fully functional.
Dec 15, 2008 | Samsung Digimax L730 Digital Camera
Nikon coolpix p2 lens error
You can disassemble the lens and clean the dust. Here are some photos of the disassembled P2 Lens http://fixit.limewebs.com/p2/
Aug 21, 2008 | Nikon Coolpix P2 Digital Camera
Tamron 28-300mm lens disassembly help
Both, But start at the rear to remove the electronics and the outer barrels. Remove any rubber grip to expose 'hidden screws'. I would mark everything or document with pictures during disassembly.
Jan 29, 2008 | Tamron 28-300mm f/3.5-6.3 DI XR for Canon
Something inside lens
i work with sonys all the time ..I do not recommend disassembling the lens section at all. unless its between lens and CCD imager but I doubt its there..
Nov 08, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
108 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
