Question about HP Pavilion dv7-1130us laptop
Pulled battery out tried to start goes for a few min and shut down
    Guru:
  • 302 Answers
It sounds like the memory cards are loosing connection pull the memory cards out and reseat the memory cards in the notebook.
if the cards get knocked loose it will cause shutdown they control a portion of the video.
that usually is from carrying the notebook around getting jarred in the car etc.
Posted on Jun 22, 2010
    Guru:
  • 722 Answers
Plug it in, the battery is probably dead. If it still does the same thing while plugged in, start again and push the F11 button to enter "setup". (F function button may be different than what I stated).
At start up, watch the very bottom (left to center) screen for the command button for setup.
Watch quick, and have your finger ready. You may have to restart again to try again.
Once in setup, press F9, and click (press enter) to save default settings). Do this for each menu (left to right) until you come to the Exit Menu. Select Exit Menu, and select Quit and Save changes.
After this, if it still doesn't start, restart again.
This time, watch for another command to select start up options. Once you find this command push it, (will be an F command as well) and wait for the start up list to appear.
Once this has popped up, select Start in Safe Mode.
Once in safe mode, click start, All Programs, Accesories, System Tools, Disk Defragmenter.
After it defrags (if it lets you); follow this same menu (or if you have an icon for it, find your anti virus program and run it.
Once your have performe these two actions, shut down the computer and let it sit for about 45 seconds. Unplug it during his duration to pull any excess charge from the computer. This will allow the Processor to completely shut down.
Also, if you have one, (if not invest) always keep the fan under your laptop. Laptops are known for overheating as they have very small fans inside that only cool the processor. Other components need to be cooled as well, and thus they made the external "lap" fans.
NEVER leave the laptop on a bed, couch,or any type of surface that will obstruct the airflow of the fan. This not only damages the fan and your computer, it is a fire hazard.
If after this the computer still does not start, run and functon, you may need to re-install your OS (operating system).
If you have the disc, insert it into the drive and restart the computer (will need to be on to open). Simply push the power button, open drive, insert disc, and close. If the disc doe not automatically run, restart the computer so it does.
Once it starts, (disc loads) it should give you the option to "re-install" or "repair"the OS.
If these two options are available, choose "repair". Let the repair process proceed completely and follow the direction carefully. This option allows you to keep personal files and such on the computer without completely uninstalling and reinstalling the OS.
If the "repair" option is not available, and only "re-install" is available, choose this, as it will give you the option to save "keep" personal files.
This will re-install the OS to it's original configuration, while keeping your personal files. NOTE: this is for windows xp, windows 98, vista home premium.
If you operate another OS, please indicate as such in your (or a new post) post, so an appropriate Expert can assist you.
Also be advised that any addtional (non-manufacture) programs will need to be re-installed later. These will not be saved during the installation process, so make sure you have all the required discs for each that you want to put back on.
If you need any further assistance please let me know.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Posted on May 14, 2010
2000 pontiac montana security system locked and it won't start. The information center on the van shows as follows; Low battery light, Then Security light, Then Low fuel light. Its full of gas. Help?
Does the security light come on when you turn the key to run ,Does it go off in a few min. The proper way to reset the anti-theft system would be to turn the key to the on position for 10 min. if the light goes out in that time ,turn the key off for a few seconds . Then try an start the vehicle . If light comes back on an won't start there is a hard fault . You mite at that point wan't to do a theft system by- pass . Also have your battery checked and or charging system . A low battery , a malfuctioning charging system may cause these type problems .
Oct 27, 2016 | 2000 Pontiac Montana
Bikegit
Replace the switch! It shut down when battery get depleted. and then when you start it again the cycle is shorter because the batery regenerate but not as previous cycle.
Jul 16, 2014 | Karcher WV50 Window Vacuum
Sony vaio PCG-7142L keeps freezing
Can check if the battery is low ... or is not (or cannot) holding a good charge ... when you unplug it (from the charger) ... when this happens ?
If that is the case, it may "freeze" while it is busy trying to store the contents of your memory before it shuts down (or hibernates). Does it shut down (or goes into hibernate if you let it continue to "freeze") for a while ? If so, then it's your battery.
If the battery doesn't hold a good charge, the laptop will run only a short time (while unplugged) before it has to shut down due to low battery. And if this is the case, consider getting a replacement (new) battery. And follow the initial charging instructions (for a new battery) to lengthen the life of the battery.
Apr 03, 2014 | Sony VAIO Computers & Internet
Reset computer
give it a few cycles to relearn its self- key on start run, shut down,start and run, shut down and start and check it out- Denny
Dec 31, 2013 | Nissan Murano Cars & Trucks
Gas dryer runs for 30 mins then shuts off.
This is a common problem that is not a good one. But the motor is goin bad. If you try to start it you will hear like a hum then start. Motor is going bad and over heating and shutting down on overload. Sorry. Hope this helps.
Jan 31, 2010 | Kenmore Dryers
My buicks battery has just died. When I jumped it it goes to turn over for a second with a click and then dies down, but all the lights come on. How do I know if its the starter alternator or battery
if the lights are bright and you hear a clicking and your heat blows good, the head lights are still real bright after trying to start a few time replace the starter (you can try to hit the starter with a hammer otr somthing heavy a few times and then try to start if it sounds better or starts replace the starter) if the battery goes dead try to jumpit if it starts then dies after a few min its the alt if it starts runs good and you let it run for about half hour shut it off and it wont restart rite away its the battery.
Jan 01, 2010 | 1990 Buick LeSabre
Crash!!
Could be Heat, sounds like the system is shutting down to protect the processor. Let it sit shut down over night and see if it runs longer when it's cooled down. Is the fan running?
Aug 29, 2008 | Acer Aspire 5315 Notebook
Battery Problem
take out the battery, let set for a few min. and put it back in, try it. If does not work you need a new battery
Nov 26, 2007 | Compaq Evo N610C Notebook
HP Pavilion dv7-1130us laptop Logo
419 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
