Question about Dishwashers
Hi there ,purchased an EZISET dishwasher privately through trademe, he said it was new. have installed it and each cycle pulls in water ,sprays, emptys and stops. can you please help us. their is a number on the front ,little ,52b850 thanks suzanne
Have a Homark dw009 dishwasher that has an E4 code.....why? Please help
Posted on Jun 11, 2009
    Problem Solver:
  • 21 Answers
This might mean you have a leak, in your dishwasher. the rings that stop the water from seaping might be broken, or it may be hat your motor is not in good condition. Anyway, i know that that dishwasher is a low quality dishwasher, for it has a reputation all over the internet that it is bad.
I hope you get it fixed!!!
Posted on Apr 16, 2008
SOURCE:
Spray arms not working
Hi frustrated in Raleigh,
I understand that the spray arms are not moving or spraying water, even after you have cleaned the screens and arms. What might be happening is you are not getting enough water pressure to the dishwasher.
The hot water line to your dishwasher must provide water pressure between 20 and 120 psi.
Low water pressure may occur when laundry or showers are in operation.
Wait until water use is reduced before starting dishwasher.
If you are still noticing that the spray arms are not moving or spraying water, I would have a local Authorized Technician come out to see what exactly is going on with the spray arms of your dishwasher.
-Best Regards-
Jan 06, 2014 | Frigidaire FPHD2491KF Dishwasher
My Frigidaire Dishwasher FDB126RBS2 sounds like it is running normally, but dishes are not cleaned. I suspect water is not spraying sufficiently. With the arm removed, I can open the door in mid cycle,...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Sep 11, 2011 | Dishwashers
Dishes on top rack on not getting clean on the outside e.g. the outside of an inverted cup is dirty and dirty water is collecting in depressions. There doesn't seem to be a mechanism to rinse the dishes...
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Oct 27, 2010 | Ariston Technologies L63SNA Stainless...
My dishwasher is filling with water, but the the arms are not spinning. It will drain. The cycles in between the fill and drain are stagnant. I just purchased it this summer.
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried in vainto clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if the heating element goesbad then that also can mess things up bad... So I would buy new spray arms, and also check out theheating element to make sure it is working... Here is a tip that will help you with the online buying...
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Sep 19, 2010 | Amana ADB1600AWS Builtin Dishwasher
I have a Vikin Dishwasher Model DFUD042 and the arms are not circulating water. When we start a cycle it drains previous water then fills it up after that it runs thought its regular cycle but the arms are...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
heatman101
42gda
Apr 21, 2010 | Viking 24 in. Professional Series VUD141...
Dishwasher is not cleaning dishes
heatman101
k
Apr 14, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
My dishwasher has stopped cleaning plates properly. It makes everything wet but at the end of the cycle the detergent block is half dissolved at the bottom. I have just run a cycle and opened the door...
heatman101
kjh;lkhjk
Mar 27, 2010 | Zanussi 18 in. ZSF4123 Slim-Line...
Wash cycle doesn't seem to work. bottom has water
Your gonna have to pull the dishwasher out and shut off the water line. Then disconnect the water hose and get you a bucket. Then turn on the water line to see if water comes out. If water comes out strong then your water supply line is good, which means your inlet port on the dishwasher is clogged or hard water has clogged the little holes in the dishwasher arms. Dishwashers are meant to leave a little water remaining at the bottom to keep the sensor from burning up.
Feb 16, 2010 | Dishwashers
No water in washing/rinse cycle of dishwasher
It sounds as if the warter inlet valve (solinoid) isn't working and might have to be replaced. If everything else opeates fine, (unit pumps and sprays water that you added to it, pumps out and drains OK, then it is very likely the inlet valve has failed.
You can check for a blockage in the water inlet line, but unless you have a lot of sediment in your water or use a private well for your water supply, that would be a remote possibility, but worth taking a look at before buying replacement parts, etc.
You can remove the water supply hose/line and check for proper water flow and see if there is anything blocking the water from getting into the dishwasher. Many uints have a filter screen installed in them, so check that to see if it is blocked. Otherwise, look at the inlet valve and see if it is working correctly and go from there in replacing it.
One last thing, make sure the water supply line is actually providing water to the dishwasher, sometimes the water valves some installers use do get blocked, depending on how it was installed.
Jul 28, 2009 | Crosley Dryers
Spray arms clogged
Top: Remove the upper tray by releasing the clips on the ends of the runners. (Squeeze the top of the clip and pull upwards). Remove the spray arm by holding the round plastic clip that holds the arm and turning the arm. It will unscrew.
Bottom: Grab spray arm in centre and pull sharply upwards to unclip.
Wash in warm water and solvent-free detergent.
Jun 11, 2009 | Samsung Dishwashers
Dishwashers Logo
361 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
