Question about Sony Cyber-shot DSC-W50 Digital Camera
Lens issue A black screen comes up with the word access. The lens seems like it is trying to fix itself but is jammed. After a few tries the screen says: Turn the power off and on again. I have done that and tried removing the battery for a period of time and recharging it but nothing seems to have an effect. Thank you in advance for your help.
    Genius:
  • 2,985 Answers
This is either a faulty lens mechanism caused by dirt ingress or damage, thus not able to complete the process- Contact Sony for repair erstimate.
If it is under warrantty may be free or if a known fault may also be free
Posted on Apr 01, 2008
My pl170 keep freezing after taking a few pictures
Lens jammed issue. little twist the lens in anti clock side and then try again in normal use.
Aug 05, 2012 | Samsung DualView PL170 Digital Camera
Canon PowerShot S2IS Digital Camera
Try to remove the battery for an hour, & put it back again..
Let me know..
May 29, 2008 | Canon PowerShot S2 IS Digital Camera
My camera will turn on then shut off a few seconds after even if it has been charging for an hour whats wrong?
Most likely the lens is jammed or stuck. The unit is trying to initialize, and not being able to, shutting itself down. Dust and sand can work it's way into the lens assembly, and jam the gears. You can try to spray it out with compressed air to try and free it up. If that doesn't work, here's some things you can try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
The page is for lens errors, but it applies to your problem.
They say about 50% of the cameras with a lens error/shutdown problem can be fixed.
Good luck, thanks for using FixYa, and hope this helps.
Aug 20, 2010 | Samsung L200 Digital Camera
My Samsung SL202 isnt working the back screen stays black when i try to turn it on and it makes a sizzling noise then then lens comes out but dosent pop back in
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Jul 03, 2010 | Samsung SL202 Digital Camera
Canon A630 lens error and black photos
hi u need to get the lens repaired the railing in the lessystem is no correct so pleas dont try to doit or push in .... it will be permanent damage ....get to the shot5 the camera is not broken need small fix....
Aug 30, 2009 | Canon PowerShot A630 Digital Camera
Lens error restart camera
This is a common problem with with cameras with retractable zoom lens .
Heres a few thing you should try :
Fix #2: Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. If you get another type of error message this may mean you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
TO AVOID THIS PROBLEM AGAIN : Keep away from dust, dirt, grit, sand and any camera bag that has loose fibres (clean it before use).
If this helps you, please vote...thankyou and good luck!
Jul 28, 2009 | Canon PowerShot SD1100 IS Digital Camera
Lens error 0x02110000
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one). TO AVOID THIS PROBLEM AGAIN : Keep away from dust, dirt, grit, sand and any camera bag that has loose fibres (clean it before use).
Jul 28, 2009 | Pentax Optio E60 Digital Camera
Lens jammed with sand
This does not get fixed - throw it away and buy a new one.
Aug 03, 2008 | Olympus FE-280 Digital Camera
Access
Hello, there is a problem with the optical unit (lens). Normaly when the camera is in camera mode the lens should go out. In your case it seems that for some reason the lens is stuck. Please contact your nearest Sony dealer. If you want to repair the camera yourself please tell me. I can send some additional info as well. Regards, Arpi
Jul 12, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
49 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
