Question about VAX Appliances Vax X5 Bagless Upright Cyclonic Vacuum
My miele monte verde vacuum's red light is on at the base and the brushes aren't rotating
My miele m clenaers brush stopped rotating desite the belt is intact
The brush roller ends could be clogged with debris, especially if you are cleaning up after a pet.
Oct 27, 2017 | Miele Vacuums
Miele vacuum
Check the end caps on the brush roller they might have collection of dirt build up also the unit nust be assembled correctly with no air leakage by the fan so the suction can spin the fan
thiis turbl is made by wessell for Miele the replacement is just as good under their brand for a lot less money
miele turbo nozzle carpet and bare floor brush
Jul 02, 2016 | Miele Vacuums
Miele seb 213 quit spinning on rug
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first let's focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Miele replacement parts for your Miele Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=miele
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Apr 14, 2013 | Miele SEB 213-2 Vacuum
I just changed my bag and now it is squealing and the red bar is in window?
It would seem that your vacuum is clogged, hence the change bag indicator. Pull the hose out and and remove at the swivel connection at the base of the hose.You can use a small flashlight to check the hose, lay the hose on the floor with the light at one end and look for light at the other end. I know the grip end is curved but you should be able to see some light. Check the rear port by removing the cover located near the base, on the rear side, close to the hose swivel. Unscrew the 2 plastic screws and lift out the cover; check for a clog here. Next lay the vacuum flat on it's front and shine the light behind the brush roll and up the short black internal hose. Facing the metal sole plate, the hose should be near the right corner. Good luck.
Jun 03, 2012 | Miele S7210 Bagged Upright Vacuum
How to change the belt?
There is no belt on a Hoover SteamVac. The brushes are rotated by an air driven turbine. If the brushes aren't spinning, you most likely need to replace the turbine assembly.
Jul 05, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Brush is not spinning
Usually, this is caused by the brush assembly end bearings becoming bound up with string, thread, and hair. Remove the brush and clean the bearings and end shafts. Oil them lightly with 3-1 oil or similar. Check the condition of the drive belt and replace it if badly worn or broken. Check the rotation of the brush by hand before installing the belt. Hope this helps!
Oct 04, 2010 | Miele Powerhouse Plus Bagged Upright...
My S 7000 upright vacuum red carp light on
its probobly the belt is broken
Sep 08, 2009 | Miele Vacuums
Miele S2511 Vacuum Cleaner Disassemble Question
My problem is with the power brush...I checked the belt and cleaned the rotating bar..still very low suction. The canister is still giving me plenty of power...thanks for any help
Sep 30, 2007 | Miele Vacuums
VAX Appliances Vax X5 Bagless Upright Cyclonic Vacuum Logo
109 people viewed this question
Top VAX Appliances Vacuums Experts
Jerry Kramer
Jerry Kramer
Tom Chichester
Are you a VAX Appliances Vacuum Expert? Answer questions, earn points and help others
