Question about Saws
Table saw My 10'' delta table saw does not star. No any sound. I check the ciril break and pushed in but does not come back. That is only thing I found. Do you think it cost the problem?
    Guru:
  • 60 Answers
I had a similar problem with my table saw. It would not come on. I unplugged it and cleaned out the on/off switch...it had saw dust in it that was preventing it from contacting and coming on. You might want to try this.
Posted on May 15, 2010
How do you "unlock" the Delta miter saw?
To unlock a miter saw, push down on the saw to unlock the head and loosen the knob on the table to make adjustments. Start using a miter saw with help from a custom furniture maker in this free video on woodworking tools. Read more: How to Unlock a Miter Saw How to Unlock Miter Saw Best Miter Saw Reviews Real Man Miter Saw
Oct 22, 2011 | Delta SM100M 13 Amp 10" Compound Miter Saw
I have a 10" Delta table saw. It was running rough
Check that the blade is not warped or binding. Don't use long extension cords. Check your home breakers. Also check if the table saw has a breaker. Don't force lumber into the blade too fast and don't jam the lumber between the guide and blade. Try a different outlet and check your wire for breaks. Good luck!
Oct 05, 2011 | Saws
The belt in the motor of my 10 inch delta table saw broke its a Bando synchronous 100XL belt...Think I can find a replacement...However, before it broke whenever I started the saw I noticed unusual sounds...
I have the delta 10 inch cabinet saw with the uni-fence, I bought just before somebody at delta smartened up with the left tilt blade, that is the worst design I have ever seen. I came real close to buying a Powermatic the same day I got this thing. Anyway, my saw sounds like a mack truck in reverse slamming the dump gate when it starts, I don't think there is anything to oil, it has bearings on the shaft. I found a ring of some sort on the floor one day that fell out of the saw, broken in half, I have never found where it came from. We just laugh at it, It is a bad saw. I bought the 12 Rockwell/delta planer the same week, Oh boy did we have fun with that, instantly went through the set of knives on it, maybe 3 passes, I said what the heck. I called delta and told them this is the biggest piece of junk I have ever seen, I said for $1300 it should put a finish on the board when it comes out, and it should have carbide knives, I said, If I had know it was made in Taiwan, i would have bought a grizzly. and saved $500. And gotten a better planer. She said, I'm sorry, I can send you some new knives. I sold it. Still have the saw though. Never had problems with the bearings. Hope this helps.
Feb 21, 2011 | Delta 36 982 10 Inch Left Tilt 1 1/2...
Table saw does not start.
if it just hummmms then check for a start capacitor on the motor body,if none,then check for a bad centrifigual motor switch on the end of the motor
May 14, 2010 | Craftsman 10" Table Saw
Delta saw model no. 28-245 saws a taper form top of wood to bottom why does it not saw a stander line Delta saw model no. 28-245 s/n 91B1335
Sounds like your table is tilted. Put a small square on the table against the blade, then adj the table to it. If that is not it, then the blade guides are off up and down, back off all the guides, wheels, turn the blade by hand, get it tracking in the center of the tire, then bring the bearings up the blade, don't push it , just touch it, then bring in the guides, again, make sure it doesn't push it, the guides stop it from going off, it should track by itself. Hope this helps.
Feb 05, 2010 | Delta Saws
Delta Table Saw stopped running
I have a table saw that the cord from the motor plugs into the the back of the on/off switch. I yours is configured like that, unplug the motor cord from the back of the switch and plug it in to the wall and see if the motor will run. If so replace the switch.
Jun 21, 2009 | Delta 10"Hybrid Tablesaw with 30"Unifence
Can I mount a Delta 36-T30 T2 30-Inch Fence and Rail System on my
I just installed a Delta T2 fence on my 10" Craftsman Table Saw. It's 27" deep. The bushing either could be relocated or you could use spacers on the front, back, or both on the saw to get the required distance. Also, you'll have to drill new holes, however, I used one of the existing holes in the front and back of my saw as well.
Mar 11, 2009 | Delta 36 T30 T2 30 Inch Fence And Rail...
Delta shopmaster saw blade stuck down and won't go back up
sounds silly, but on the right side there is a blue knob.Push down on the saw handle and pull out the blue knob. That should release the saw arm.
Oct 08, 2008 | Delta JT160 Shopmaster 10 Amp 6 Inch...
Saws Logo
107 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
