Question about Kenwood VR-716 6.1 Channels Receiver
Kenwwod VR 716
Turns on clicks a few times then shuts off
  • tchaffin1978 May 14, 2010
    Thanks, Although i cannot get it to work myself this was very helpful. I will be contacting a repairman this up coming week. thank you
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, unplug from the mains / outlet. Inspect the speaker wires and ensure that no stray strand is inadvertently touching its pair. Use a continuity tester to verify the speaker impedance.
Offhand, the clicks are the relay trying to engage. It forms part of the protection circuitry. If a fault is detected, the built-in watchdog triggers the relay off and disengages the speakers to prevent further damage.
The only easy user doable try of a fix is the above speaker / wires check and performing a RESET:
  • unplug from the wall outlet;
  • press and hold the POWER ON/STANDBY key while plugging back in.
As the term RESET implies, the VR-716 would be forced to revert back to factory defaults removing glitches, errors in settings & configurations as well as memories, presets and user preferences.
Good luck and thank you for asking FixYa.
Posted on May 14, 2010
    Ok, I unplugged all speakers and tried the reset. Still turns on clicks and shuts off. How long do I need to hold in the power button?
  • Louie  Role
    Louie Role May 14, 2010
    Hold it just a couple of seconds.
    If the RESET is not corrective, then it would be a hardware fault. The unit has to be opened up to effect repairs. Options then are:
    • consider a DIY (do-it-yourself) repair if and only if comfortable working with electronic components & circuitry, use of a DVM/VOM, a soldering iron/station and safe practices with electrically powered devices. Access to a Service Manual or at the very least, a schematic diagram would be a necessity;
    • should you be uncomfortable with a DIY, perhaps your best bet would then be to consult with and/or seek the services of an authorized Service Center (specially if still under some form of extended warranty) or a qualified professional.
    If a DIY is being considered:
    • Service Manual is available here;
    • preliminary check on the standby 6.8VDC to relay K101;
    • power amp board X09-6750/10;
    • ICs 301 & 401;
    • +/-76V, +/-46V.
How to reset the Kenwood vr-716
Unplug power cord from the wall outlet, then plug it back IN WHILE HOLDING DOWN THE POWER KEY = only for U.s.a and Canada
For other Countries With the power cord plugged in, turn the POWER key
OFF. Then, while holding down the ON/STANDBY
key, press POWER.
Memory back up function
Please note that the following items will be deleted from the unit's
memory if the power cord is disconnected from the AC outlet for
approximately 3 days.
• Power mode. • Distance setting.
• Input selector settings. • Input mode setting.
• Picture output. • Midnight mode setting.
• Speaker ON/OFF. • PRO LOGIC II mode setting.
• Volume level. • Broadcast band.
• BASS, TREBLE, INPUT level. • Frequency setting.
• Dimmer level. • Preset stations.
• MD/TAPE settings. • Tuning mode.
• Listen mode setting. • CINEMA EQ ON/OFF.
• Speaker settings. • LOUDNESS ON/OFF.
• SW RE-MIX ON/OFF.
Cautions
MODEL PARTS # REMOTE CONTROL # DESTINATION
VR-705-SA A70-1612-05 RC-R0626 K1P1
VR-707A A70-1617-05 RC-R0824 K2P2
VR-716A A70-1617-05 RC-R0824 K4P4
REMOTE CONTROL vs MODEL
DIFFERENT POINT
ACCESSORIES / CAUTIONS
Model Service Manual Surround Display Sub
VR-705 B51-5840-00 X09-6740-10 -
VR-705-SA - X09-6740-11 X25-6600-10
VR-707 B51-5840-00 X09-6750-12 X25-6520-12
VR-707A - X09-6750-14 X25-6610-10
VR-716 B51-5840-00 X09-6750-11 -
VR-716A - X09-6750-13 X25-6600-10
Note:
A different information will be available from this service manual. Pls refer to original service manual(B51-5840-00), too
Nov 13, 2016 | Kenwood Audio Players & Recorders
Optical hdmi
need to see the back of both units..
Jan 11, 2014 | Kenwood VR-716 6.1 Channels Receiver
Kenwood vr-405 turns on only momentarily and then shuts off
your receiver has a bad audio output ic.replacing ic will take care of the problem
Apr 10, 2010 | Kenwood VR-405 Receiver
Kenwwod VR-615 - display disappears
Its becuase it is dirty inside, Unplug it. Take the case off of it. Get sum compressed air from a computer store or Walmart. Like 10 dollars. And just blow the whole thing out with that canned air. do it ever 3 months.. It should fix the problem for life!(:
Jan 30, 2010 | Kenwood VR615 Receiver
I have no sound with my lg blue ray player but my lg dvd player has sound throught and i am using a hdmi cable and i have set the blue ray audio settings with a lg tech anything will help thankyou
Some times the DVD player needs to be set to output digital audio through HDMI. If that is set, then do the same with the menu options on the TV/LCD/Plasma/Screen that you are using.
Jul 25, 2009 | Kenwood VR-716 6.1 Channels Receiver
My Kenwood VR-209
your speakers wires are touching together. this system has a protecter so you don't blow out the amp. the blinking is how it lets you know that
Jan 28, 2008 | Kenwood VR-209 Receiver
New vizio tv cant get remote to turn tv on
same problem
but it does turn on with a remote.
no other functions
i'ven repl. power supply brd. no help.
i do not hear relay click on
it seems to be in the main brd.
thank you
zbyg
Dec 19, 2007 | Vizio L37 Television
IR receiver on unit not working?
Sounds to me like the issue is the rx in the unit. It can be fixed with very little work if you can locate the part. Let me take a look and see if I can locate the part number for you. Although I have to say that Kenwwod can keep a tight lip on their parts lists.
Nov 22, 2007 | Kenwood VR-309
Tv won't turn on
Just Repaired a HD4208-III with the same problem, found faulty
Relay RLY8002 (Faulty Contacts) Replace both RLY8001 &
RLY8002.
Regards
Patrick
P-Tronics
Adelaide
Oct 11, 2007 | SVA-USA HD4208TIII-VR 42 in. Plasma...
Remote control failure
Try these simple trick to find out yor remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
Feb 06, 2007 | Kenwood VR-409 Receiver
Kenwood VR-716 6.1 Channels Receiver Logo
49 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
