Question about Uniden 2.4GHz Digital Answering System Expandable System Cordless Phone
Handset not working
Title; handset not comunicating with base. tried changing sec. code but no buttons on handset work. Rodger modelTRU4485-2 how to reset code?
  • rds07 Dec 10, 2010
    the handsets do not respond at all! I can use the base with the speaker phone. Rodger
  • Uniden Master
  • 19,396 Answers
Hi
If deregistering base does not work, then either base or handset is probably faulty. Before calling manufacturer to see if a replacement is possible it is worth performing a full system reset by disconnecting power.
Please do the following system power reset:
Disconnect all power adapter cables from wallsockets.
Remove all handsets from cradles.
Remove all battery from cradles.
Check the phone socket and ensure that the line is OK. Use a corded phone to test.
Connect back the Vtech phone cable.
Fit back the batteries in their handsets.
Place back handsets in their cradles.
Connect power.
The procedure above will reset the system and will re-sync handsets to cradles. If that does not work, then some of the units in the system is defective..
Regards.
Ginko.
Posted on Dec 11, 2010
    Genius:
  • 1,340 Answers
This should reset your handset.The first parentheses has a phone symbol in it.
Press and hold [ ] and [#] for more than five seconds. Select DEREGISTER HS.
Select the handset which you are operating, and then press [menu/select].
The phone will ask you to confirm the deregistration. Select YES. The selected handset will clear its registration
information only from the base it is currently connected to, and then delete the link to the base from its own
memory.
When the base information is deleted, the handset displays HANDSET NOT REGISTERED-PLACE HANDSET
ON BASE TO REGISTER. SEE YOUR OWNER'S MANUAL FOR HELP.
Re-register the handset to the base (see Registering accessory handsets on page 12).
If the handset cannot contact the base, it will display OUT OF RANGE. Make sure the handset is in range of the
base and the base is connected to power
Here is a link.It is not your exact handset but very similar.Many Makers use the same technology in newer models.If you have any questions or need more help,just comment here and I will get an autolink to your post and reply ASAP.Greg Also,if this doesn't work,there are many ways which makers use to do this same thing,register a handset.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Posted on Nov 29, 2010
DS6321 out of range, no power at base
This sounds like a registration problem, the handset(s)
and the base have lost identification with each other.
I. To address this, first de-register the handset(s) ---
do this procedure for each handset:
0. Start by taking off the battery compartment cover....
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??", press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY (why the cover was off)
9. Wait ~30 seconds, re-connect the battery & replace the cover
10. display reads "Not Registered" ===============================
II. To register the handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #1" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a few
hours and try the registration ( II ) again.
NOTE: the base can only handle 5 handsets and will
increment the number of each handset registered
until "Handset #5" has appeared, even if some of
the handsets are lost/not in use. Trying to register
more than 5 handsets will result in "Registration Failed."
III. To clear the base of all handset registrations and
be able to start registering again at Handset #1:
1. press [Find Handset] on the base and hold past ~4 sec when the "In Use" lamp lights, at
about 10 secs the "In Use" lamp will begin to
blink.
2. release the [Find Handset] button momentarily,
then briefly press it again. After a moment,
all handsets that were registered to the base
(if any) will display "Not Registered" and be
ready for fresh registration
3. for multiple handsets, return to II. above and
register each handset in turn.
Good luck !!
May 02, 2016 | Vtech Lands Phones
3 of my 5 phones say "No Line"?
This sounds like a registration problem, the errant
handset(s) and the base have lost identification
with each other.
NOTE: the CS6429 works a maximum of 5
handsets, so you have a "fully populated system".
You will have to clear each handset ( I ) then clear
the base of all registrations ( II ) before re-registering
each handset ( III ).
( I ). First de-register each handset ---
1. press [menu]
press [select]
(this is why the cover was off)
replace the cover
( II.) To clear the base of all handset registrations
blink. 2. release the [Find Handset] button momentarily,
ready for fresh registration ===============================
( III.) To register each handset to the base:
"Handset #x" or it will say "Registration Failed".
few hours and try the registration ( III ) again.
Good luck !!
Apr 16, 2016 | Vtech Accessory Handset with Caller ID for...
VTech CS6409 register handset fails with no message
From what I read it seems you are trying to register and add a new handset to your system. I am also assuming that the handset is de-registered.
A common problem with registering a handset to this system is Owners Press and Hold the # sign before releasing it. This button is to Press and IMMEDIATELY release. DO NOT HOLD. If this does not solve your problem then
With a charged battery in the handset, the display should read "1.PRESS FIND HS ON BASE 4 SEC and 2.THEN PRESS # ON HANDSET" if it say so, then when you press and "IMMEDIATELY RELEASE " the # sign on the handset the information should change If the screen goes blank when you do so and return to "1.PRESS FIND HS ON BASE 4 SEC and 2.THEN PRESS # ON HANDSET" then you will have a bad battery or your base memory is full.
Replace the battery and try again. If no change then
The best way to go is to clear the system and re-register all the handsets. Begin by removing any handset from the main base cradle. Then
Press and hold /FIND HANDSET on the Main base until the IN USE light turns on and starts to flash. then release it, then without pause Press and Release it again. That will clear the system and de-register all your handsets.
All handsets will show 1.PRESS FIND HS ON BASE 4 SEC and 2.THEN PRESS # ON HANDSET. To re-register follow this instruction
Jun 02, 2017 | Vtech Lands Phones
System error #1 Panasonic kxtg2770
1)On handset, press MENU, 0, 0, 1.
Handset display shows as follows.
*Skip this step when handset already shows as above.
2) On base unit, press LOCATOR for 3 sec until CHARGE LED flashes.
3) On handset, press OK button. Then wait until the handset display changes as follows.
If you receive an error message indicating the maximum number of handsets have been registered, you will need to deregister the handset from the base unit, then try to register again.
*If this does not work, your unit is defective. Please send your unit for service.
Panasonic Services Company Customer Servicenter
Suite B 4900 George McVay Drive
McAllen, TX 7850
McAllen, TX 7850
1) Press FUNCTION on handset. Then, using the Navigator key, press Down (V) 4 times, Right (>) 1 time, Down (V) 7 times, Right (>) 2 times.
2) On base unit, press MUTE. (MUTE LED flashes.)
Dec 04, 2010 | Panasonic KX-TG2770 Phone System w/...
My vtech cordless reads out of range or no power at base, what is wrong?
Official solution to this issue:
Make sure base station serial number matches all handsets serial numbers.
If they don't match you will have to de-register the units.
De-register the base station by holding the find handset button for 10 secs or until the In Use light illuminates, release the button and then tap it once more. You should hear a short beep followed by a longer beep.
Press Menu Select and the press the following without pause - *7890#
You should now see Test Base at the top of the screen press the Vol up button until Test Handset is present.
Press Menu/Select and you should see SW Version displayed. Press Vol up button until you see regstr clear, then press Menu Select and then Menu Select again.
At the handset remove the battery for 15 secs and then place the battery back into the handset. You should see 1. Place handset ... 2. press # on the handset screen. DO NOT FOLLOW THE ON SCREEN DIRECTIONS.
Next place the Handset on the base station and press the find handset button for 4 secs until the In Use light shows up. Remove the handset and press the # button.
Your handset should now display Handset 1. You can do all the other handsets the same way.
Hope this helps!
Jul 25, 2010 | Vtech 9009111 Cordless Phone
Uniden XS 1210 cordless phone won't connect to base unit
try connecting both phones via the base that is working and see if they recognize each other. Let me know if that works.
Jul 21, 2009 | Uniden Cordless Phone
Handset can not connect to base unit ATT E-2126
AT&T 2.4 cordlessE2126 handset will not reset to base
Apr 01, 2009 | AT&T E2126 2.4 GHz Cordless Phone
Kx-tg1100
On your handset go to "SETTINGS HS" -> "REGISTRATION" -> "CANCEL BS"
This will discard the registration of the handset to any base.
Then go to "SETTINGS HS" -> "REGISTRATION" -> "REGISTER HS"and select the base you want (i.e. BASE 1, BASE 2, ..., BASE n).
After you finish all the above, hold down the "PAGE" button for about 5 secs.
You are now done!!!
Good luck
Simos
Nov 04, 2008 | Panasonic KX-TG1100 Cordless Phone
Tesco arc200
I solved it out u must pres de paging button on the base while registering the phone to base keep the paging button pressed until starts to beep like 5-10 sec. Good Luck
May 16, 2008 | Uniden Cordless Phone
Lost comunication
I solved this problem with a RESET of the handset. Instructions from the Philips website: Please perform a reset of your device. You will not loose your recorded data (phonebook and personal settings are being kept). 1. Unplug the mains of the base station. 2. Remove one of the batteries of each handset. 3. Put the batteries back in and re-plug the mains of the base station.
Mar 09, 2006 | Xact Communication XG2200 Cordless Phone
Uniden 2.4GHz Digital Answering System Expandable System Cordless Phone Logo
271 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
