Question about GE WBSR3140DW Top Load Washer
The plastic agitator isnt spinning it sounds as though the piece it sits on is turning but just spinning insde the plastic housing on the underside of the agitator
    President:
  • 2,468 Answers
Your "agitator coupling" is worn out underneath the agitator,remove the dispenser cup on t6he agitator,then the agitator,it sits on the coupler on splines and they wear out and the agitator can,t grip them anymore and slip
Posted on May 14, 2010
Whirlpool stylemaster 4217141 REV A Agitator/spin cycle broken upper agitator spins by hand but tub won't spin
open the lid and get a model #, sound like all you need is agit dogs # 80040. then remove top of the agitator, could be a softener dispenser. under that you will find a plastic cap, pull up with needle nose pliers. under that you will find a 7/16 or 1/2 bolt, remove the bolt and the agitator can be lifted off. the agitator can now be split into to pieces, turn the top half over and the assy with the agit dgs will fall out. simply replace and reassemble and DO NOT OVER TIGHTEN BOLT. just snug it up. should be fine.
Jan 02, 2012 | Washing Machines
Roper washer rtw430sq will not agitate, spin or drain only makes a humming noise>
this unit has what is called a drive coupling under unit... if you gain access to underside of unit,,
you will see it between the transmission and motor assembly... it has two plastic pieces and a rubber piece between them each piece has three teeth that interlock intothe rubber piece...alot of times these break and that is what runs the unit... the motor turns and turns the transmission check this piece.... inexpensive part....hope this helps
Jan 21, 2011 | Roper RTW4300SQ Top Load Washer
Washer wont agitate or spin
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 27, 2009 | Kenmore 43052 Front Load Washer
Kenmore washer will not agitate or spin and makes a loud noise
I will cross my fingers that it isn't your transmission. One thing though that it could be is the agitator dogs. Pop of the top of the agitator and look down inside. You will see a ring of teeth and 4 little plastic pieces that sit inside. What these do is catch the agitator when it agitates and spins. Pull them out and see if the teeth on them are worn down and if they are replace them. If it is making noise though it is most likely going to be the transmission that is the problem. Try to find one that is refurbished as it is about 100 dollars less then a new one. If you have any other questions or need help with replacing the transmission let me know. I can give you a step by step walk through on changing that out. It's a pretty simple process. Let me know too if this was helpful for you. Good luck and I am glad that I could help you out.
Jan 22, 2009 | Kenmore 24032\24036 Top Load Washer
Ge wvsr1060a2ww washer does not spin or agitate
first look to see if this is a belt drive. If not look for a coupler(round black rubber piece with three holes, three plastic fingers from both sides going in it) from the motor to the gearcase. The motor sit between the pump and gearcase, it will pump out, but not spin.
Nov 08, 2008 | GE WVSR1060A Top Load Washer
Frigidaire Washer won't drain
Sounds like a bolt on the agitator shaft is broken which is causing the imbalance. Open lid, lift off fabric softener dispenser, pull out plastic cap, take out bolt, lift agitator out(might have to wiggle it a bit). Replace BOTH horizontal bolts holding inner tub to shaft. Tighten all the way. Replace all parts.
If it doesnt spin all the water out, that could be due to a bad bearing. Hold inner tud at the rim and turn clockwise and then anti-clockwise. If it turns bothways, you have a worn bearing. This job isnt for the do-it-yourselfer.
What is happening is the motor is spinning the bearing but it's not engaged to the drum.
Jun 22, 2008 | Washing Machines
Washer will not agitate but will spin
It sounds like the plastic inside the agitator cog are worn. The smell is the plastic cog turning but the agitator not turning.
Take off the top of the agitator. If any screw are available remove them. If not grab the agitator from the bottom and yank off. Unscrew the agitator drive cog and inspect underside of agitator. Go to an appliance repair shop and reorder a new one. Between $15-30.
Mar 05, 2008 | Frigidaire GSTF1670A Front Load Washer
GE WBXR2060V1WW won't agitate...
There's a part under the agitator(which lifts off if you pull up from the bottom evenly on two sides) called the "Air Bell Coupler" that attaches to a metal toothed motor shaft with one bolt. More than likely the plastic teeth have stripped off from this coupler, preventing it from sitting tightly on the shaft, thus causing the agitator to not "agitate" properly. You can get this from www.partselect.com. PS1517844 KIT - AGITATOR COUPLING
Cost is $7.15 plus shipping.
Jan 12, 2008 | GE WDSR2080D Top Load Washer
The tower of the washing machine isnt spining, but the base of the tower is.
The "tower" that you are referring to I assume is the agitator. If your agitator isn't moving, the agitator dogs (or teeth you mentioned) are the general suspect. They are made of plastic and typically wear out. The heavier the use, the quicker they wear out. If the teeth on the inside wall of the agitator are still in good shape, the dogs can be replaced without replacing the entire agitator and can be purchased at most appliance parts stores for less than $10. I hope this helps.
Apr 11, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
GE WBSR3140DW Top Load Washer Logo
124 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
