Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
My weedeater wt3100 the trimmer head wont rotate when running,it cranks up but wont turn.I have never even used it
2 Suggested Answers
SOURCE: Weed Eater wt3100 wheeled trimmer engine runs but
Replacement parts .com has the heads part # 530095854 for $18.54
Posted on May 22, 2010
Drive head rotates counter-clockwise. Can't get it back into position. Use to be able to simply turn it back around. Can't now.
Husqvarna 128 LD Weedeater Repair Questions,... - Fixya
www.fixya.com > Forum > Lawn Trimmers & Edgers > Husqvarna
Recent Husqvarna 128 LD Weedeater questions, problems & answers. Free expert DIY tips, ... Drive head rotates counter-clockwise. Can't get it back into ...
HOW TO CHANGE HEADS ON HUSQVARNA 128LD - Fixya
www.fixya.com/support/t20975899-change_heads_husqvarna_128ld
Oct 25, 2013 - Question about Husqvarna 128 LD Weedeater ... SOURCE: MyHusqvarna 128LD primer bulb .... Drive head rotates counter-clockwise.
Weed eater bogs out at full throttle - Fixya
Oct 07, 2015 | Husqvarna 128 LD Weedeater
Why does my new Craftsman 4 cycle Trimmer's head turn counter clockwise
Curved shaft trimmers turn clockwise.. straight shaft trimmers turn Counter Clockwise. Also the Bump head is reverse threaded because of the engine rotation.
When using this trimmer , Angle the right side of the string line down so the grass gets thrown in front of you not at your legs.
May 30, 2015 | Craftsman Garden
Why did my weedeater lost power when trimming on grass but still spun?
There is a cable that runs from the motor to the trimmer head check that. Remove trimmer b.y removing small screw at the base of trimmer head
Aug 05, 2014 | Troy-Bilt 25cc 2-Cycle Curved-Shaft Gas...
Weedeater repair
Its possible that the drive shaft is broken or the end of the shaft is worn where it hooks into the gear head. The trimmer head has a hex fitting that meshes with the gear assembly in order for it to turn, its possible the hex is worn on the cutting head from usage, which would require replacing the outer spool assembly. Here is a link to a parts breakdown. http://www.partstree.com/parts/?lc=troy_bilt&mn=TB70SS+41ADT70C711&dn=769014720002
Jul 18, 2014 | Troy Bilt Tb70ss Gas Trimmer
Weed eater head spins on its own, no power.
check the compression on your weedeater low compression will cause this
Jun 26, 2013 | Poulan Genuine Weedeater Part # 36006-128
Weedeater wt3100 carb and fuel line diagram
motor will start after several pulls but will only run for about 10 seconds,
Nov 01, 2012 | Poulan Pro 952711635 String Trimmer Line...
How to get the head off of a Stihl weedeater. Model FS 45
There is a hole beside the angle gearbox, stick an awl or small screwdriver into it & turn the head until it 'locks'. Then rotate the head clockwise until it comes off.
Jul 29, 2010 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Feather lite weedeater disconnected shaft and
You may not have the drive shaft seated all the way into the power head.
You will have to loosen up the drive shaft and push the shaft in but at the same time turning the trim head to fit it into the drive area, then tighten it back down.
Oct 03, 2009 | Poulan Garden
Pull rope does not return
Unless the rope has broken, you dont need to replace it. The problem is probably the rewind spring. It is located under the starter pulley (the one the rope is in). The best thing to do is pull the unit apart and see if you can see if maybe there is something holding the rope up. The spring is a little dangerous to replace. If you go for it, be careful....Lee
Sep 03, 2009 | Garden
Weedeater trimmer not engaging
maybe on reassembly the drive shaft did not align properly.
Jul 18, 2009 | Garden
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
126 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
