Question about Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher
My Bosch dishwasher, model SHE46C, will not start. The circuit breaker is not tripped. Once in a while when the start button is pushed, it does sound like a pump is coming on and then it stop. Any ideas on what could be the problem?
  • Bosch Master
  • 2,605 Answers
Hi D. McKinney and welcome to Fixya. The problem could be a a simple one like a poor connection at the dishwasher junction box. Based on your discription that's what I'd suspect. Having said that I would start by first shutting off the breaker. Then removing the kick plate ( access panel at the bottom ) and checking the wiring at the junction box for the dishwasher 120vac supply line. This is actually quite common to find a wire connector come loose due to improper fastening and once the unit is in use for a while the connections heat & cool, become loose from normal operating vibrations and burn up from all the added heat caused by "resistance". The end result is no power to the controls. Check it out and post back what you find. Thanks for visiting "fixya" and please take a moment to rate the solution/suggestion provided here for you. Good luck. Macmarkus :)
Posted on May 14, 2010
Hi, I have a Bosch exclusiv dishwasher of 2002 vintage. Recently it has stopped working. When you press the start button you can hear the pump running but it wont let in any water, I have checked for power down to the water solenoid and it appears to have no power down to it. If the machine is left for a week it will perform a wash cycle perfectly but then thats it for several days. Could a relay be failing on the logic board?
Posted on Aug 01, 2010
Bosch diswasher,model Sms68m02AU trips circuit breaker
rcd units trip from the milliamps that are in a short
it trips the rcd to prevent electrocution and acts in nano seconds besides being a circuit breaker for excessive current
the trip can be from moisture allowing a current leakage to ground or some other simple operation
I suggest that you get in a qualified electrician / bosch service technician to find the reason for the problem rcd
Sep 15, 2016 | Bosch Dishwashers
Bosch classic dishwasher
Circuit breakers do fail. You could swap a different 15amp breaker from another circuit to test this hypothesis, or just swap it with a new one. At least this way you'll know it isn't a power supply issue.
Feb 17, 2014 | Bosch Dishwashers
Hi! My Bosch began by tripping the breaker during the cycle (several times if I could get it to reset) and now will not start at all. Even when the dishwasher is off I cannot reset the breaker unless I...
Hello
Welcome to Fixya.
Based on your post,"...Even when the dishwasher is off I cannot reset the breaker unless I kind of move the machine around a bit. Sometimes it pops the breaker just closing the door..."
These are the most common reason for these Bosch dishwashers not having power.
#1
Remove the murret's and visually inspect the wire for "resistance burn" and strip the wires back and install new fastener's if necessary to repair.
i.e.
#2
A wire severed inside the door panel, hence the breaker trips by just moving the door in an open/close motion.
Check thoroughly in this location...
The end result is tripping the breaker and no power to the controls.
Good luck.
Regards,
Macmarkus :)
Oct 06, 2010 | Bosch SHU9915UC Dishwasher
My dishwasher won't start. I pushed the start botton. It does not light up. Nothing has happened.
Assuming the mains power circuit breaker has not tripped, it is likely an internal thermal fuse has tripped.
Can you please provide the full model no. of you dishwasher
Aug 11, 2010 | GE Dishwashers
Bosch Dishwasher (SHE44C05UC) won't turn on
Just had the same problem, same model. Found the wiring below the front cover fried. So now I'm checking to see if anyone else had this happen.
Jan 13, 2010 | Bosch 24 in. SHE44C05UC Stainless Steel...
I loaded my Bosch SHU3305 and started it up. It
Start at the main power connections underneath. Then look in the control board area next. Eric
Aug 09, 2009 | Bosch SHU3305 Dishwasher
Bosch Dishwasher will not power on
I saw my repair man do the following, which you might try...
Open the door and simultaneously press & hold down the power button with the 2 buttons used on your model to "Cancel & Drain." If the unit comes on it now is in self-diagnosis mode. Release the buttons and close the door. The unit should start to fill with water. Press the power button to exit the mode.
Jun 28, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch snu 6806
Have you checked the breaker? Is the dishwasher on its own circuit or on shared circuit with the kitchen outlets? If shared with the kitchen, might one of your GFI's be tripped?
Aug 04, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 5315 dishwasher
A fuse may have blown or a circuit breaker tripped. Replace fuse or reset circuit breaker at your fuse box/breaker box windman
Jan 30, 2006 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher Logo
1,011 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
