TEAC CT-M685 I have TEAC set Model CTM685 which has now only a white horozontal line across the middle of the screen. I can change channel with the remote but a distorted picture only holds for a couple of seconds the goes back to the white line. Any ideas ? Stecam@bigpond.com
  • joe441 Jan 30, 2009
    TEAC CT-M685 colour tv set CN533 V98098 9y60880-21. Was working ok then in a short time went to a single white line across screen. Nothing i can do will allow anything else to happen. I thought i detected a faint wiff of electrical overheat directly after this happened
  • MiztaDave Mar 23, 2009
    In my case looks like a power supply problem. C926 (22uF 160V electrolytic) on the power supply board is fried. Similar sympton to joe441- smoke and burning smell at failure.
    Sergeant:
  • 247 Answers
This is a vertical-deflection problem. Try to adjust the vertical (height and linearity and hold) controls, which should be screwdriver potentiometer controls on the back of the set.
If this does not work, a defective component in the vertical-deflection circuit will need to be repaired.
I hope this helped you. :)
Posted on Mar 31, 2008
White flickering line across top of screen
Set the screen format using your TV's menu. Do not set the format of the screen using your provider's receiver. I had this prob with a few channels with a dish provider when I set the format with the remote from the dish provider. I picked up the TV's remote, went into the menu, set the format, problem fixed.
May 15, 2010 | Vizio GV42L 42 in. LCD Television
Panasonic TV has a white line across it (No Picture, just a line)
The vertical output ic has loose solder joints. The back has to be removed to do this. The reference number for the ic is IC451. Thanks for using fixya.
Feb 21, 2010 | Panasonic Televison & Video
Black Screen with white line across the
the vertical IC most likely has failed
Jul 19, 2009 | Televison & Video
Line across middle of screen.
The line of color is due to a failure in the vertical circuit. The main suspects are the vertical Ic AN15525A and/or capacitor c308 220uf@35volts
If you have the capacity to do so, you should check the other electrolytic capacitors in the vertical circuit which are USUALLY located near the vertical IC in most cases
you can purchase the part at
https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=5760279&smodel=CT32SL15N
or mcm electronics
Mar 13, 2009 | Panasonic CT-32SL15 32" TV
Horozontal balck line across the middle of the screen
also check the dvd player set up menue some times you have to choose wich outlet your using like the rgb cables, s cable etc...
Mar 12, 2009 | Panasonic PT-60LC14 60" Rear Projection...
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Washed out colours and thin red lines across the screen
your problem is in red video circuit. please get it done with skilled tech.
Oct 05, 2007 | Panasonic CT-32SL15 32" TV
Televison & Video Logo
234 people viewed this question
Top Televison & Video Experts
Electro Med Services...
