Question about AOpen S651M (918EM10S50) Motherboard
I would like to upgrade the graphics card, now using. GF6200 but this doesn't like my new widescreen monitor. Is there a different card I can use that will see the monitor and produce a better picture from the stretched version that I have at present. Currently running XP with P4 3.06 processor
    Genius:
  • 1,066 Answers
Look for an nvidia 9800 serias card, if you have pci-e.
Posted on Jun 19, 2010
I had problems with my monitor. I am purchasing a new monitor. When the new monitor is connected to the computer does the BIOS default setting adjust to the new monitor? I am just a computer user not,...
Sometimes the BIOS doesn't display properly on the widescreen monitors if your video card was built before widescreen monitors were acceptable. I have an old ATI Radeon video card from 2006 and it cuts off the BIOS setup screen when setup. If a 640 X 480 monitor was plugged it, the problem would go away. The graphic drivers aren't going to initialize in your computer until the computer is booted which compensate for the current resolution settings.
Another solution is to see if you have a BIOS upgrade available for your computer that will create a resolution and refresh rate that will work for your monitor.
Oct 11, 2013 | Computers & Internet
Getting 4:3 aspect ratio
off the monitor for few hours and use it
tell me what happens then
May 15, 2008 | Computers & Internet
Installed gf6200 windows wouldnt start up
remove the card, go to setup utility in disply mode section use the AGP or PCI disply setiings or auto then save settings. turn of pc, install the card and then reboot, this time system will boot up, actually system boots but no display is being given.
Jan 07, 2010 | Nvidia GeForce 6200 AGP Graphic Card
Unable to get 1440 x 900 resolution with onboard graphics.
Yes, through bios you can only select VGA but it wont have any effect on what you see on windows, so let bios aside. Is through Windows Display properties that you select all the different resolutions... (RIGHT CLIC YOUR MOUSE OVER THE DESKTOP, SELECT PROPERTIES AND LOOK FOR THE SETTINGS TAB ON TOP, MOVE THE SLIDER AT THE MIDDLE TO SELECT RESOLUTIONS) in windows is where you should have the latest drivers from ECS (now PCCHIPS) for your motherboard's onboard graphics. 1440x900 is widescreen type resolution, only available rather recently by new monitors that support it and so I guess it wasn't included in your original motherboard driver CD. Then it's a must to have the new drivers installed and the monitor's plug and play recognized by windows in order to attain the desired resolution from the card.
Any new AGP video card will be far better than the onboard type. DVI is just a digital type of conector and doesn't have to do with the resolution selection, but it will make the images in the monitor show a little better since there is no signal degradation in digital transfer through the monitor cable.
Jan 04, 2009 | Computers & Internet
The desktop no longer extends to the left side at the 1440 x 900 at 60 hrz resolution. There is a black vertical stripe on the left. I don't know what happened. I've set the horizontal position at zero,...
This problem,could be a problem with the monitor or the graphics card. You need to test your computer with another monitor at the same setting to see if the graphic card is having a problem with the setting. Also test the monitor on another computer with the same setting and see if you still get the problem. You can also try using a different graphics card in your computer to see if the graphics card is having a problem. Setup the new card for the same settings and see if you still have the problem.The customer support telephone number for Envision is .1-888-838-6388. Their customer support website is. www.envisiondisplays.com. They should be able to help with your problem.I hope this information helps you with your problem.
Jul 30, 2008 | Envision 19" Widescreen Flat Panel TFT LCD...
Re: widescreen monitor
Assuming the PC has a slot for which you can still get a suitable graphics card, the card will cost very little. The advantage of the widescreen is that, for example, you can get a web browser window and a text editor window side-by-side so you can work on the text and see what you're writing about/responding to simultaneously. Alternatively, you can see two A4 pages side-by-side which is sometimes useful. You can also see a full page of text and have all the tool palettes you need by its side. One last advantage: If your new monitor has a DVI socket and you get a video card which has DVI output, you should get a better quality picture which will be easier on your eyes.
Jun 02, 2008 | Computers & Internet
Distorted screen
Youre problem is because when a widescreen monitor is fed with a signal that is not ws it stretches the image sideways making people look short and fat. The only way to really fix this is to make sure the graphics card is providing a widescreen resolution to the monitor. In this case the native resolution (the resolution the screen looks best at) is 1680 x 1050 . If you right click ur desktop and go down to properties and settings u want to change the screen resolution to a widescreen res.
Hopefully 1680 x 1050 ... if this is unavailable try 1440 x 900
If you have an nvidia graphics card you can also go to the nvidia control panel and change the resolution attributes. If the widescreen res isnt available u could also try the 'change flat panel scaling' and select the do not scale option.
Please note before starting any of this make sure u have the latest graphics and monitor drivers available.
May 27, 2008 | Acer AL2016W 20" LCD Monitor
Upgrading Graphics Card
So your dell only has a AGP slot.
You need a AGP card
On nvidia side you can get
The geforce 6000 - series
Geforce 7000 series
On Ati side you can get
Radeon x1000 series
Radeon HD 2000 series
Radeon Hd 3000 series
Remember they have to be AGP
May 26, 2008 | Dell Dimension 8100 PC Desktop
New widescreen Monitor
You should download latest graphic card drivers from this link below
http://ati.amd.com/support/driver.html
Feb 27, 2008 | Westinghouse L1975NW Monitor
New monitor but unable to use its maximum resolution settings
no, there's nothing wrong with either your graphics card & monitor.. it just that your graphics card does not support a 1680x1050 resolution. if you want to fully enjoy the resolution of your monitor, you should upgrade your graphics card. purchase at least 256mb graphics card and you will see the difference..
Jan 21, 2008 | Gateway FPD2275W LCD Monitor
AOpen S651M (918EM10S50) Motherboard Logo
Top AOpen Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Gareth Cockram
Gareth Cockram
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
