Question about Lands Phones
Medion mobile phone problem
When phone is turned on, message appears stating Handset Save Error. This happens with and without the sim card, and even if the battery has been taken out for hours.
    Problem Solver:
  • 21 Answers
This is caused by an error in the memory and (or) in the receptor of the phone.
Posted on Apr 16, 2008
Why is my phone giving me a message: No sim inserted or why is my Samsung S5 2017 model requesting that I insert a pin to unlock my sim card if I have not switched off my phone.
Have you tired removing the sim card, giving the contacts a clean and putting it back in. Sometimes they will be dirty and make intermittent contact. If you want to clean the contacts, remove the sim and CAREFULLY clean the contacts with alcohol or methylated spirits. See if that works.
Jul 04, 2017 | Samsung Lands Phones
I cant get my motorola w510 to send a text message
Hi, issues like this are related to your Sim card (network),
not your Cell Phone . In most cases, regarding the text messages,
the problem is from the Service Operator. Have you tried the Sim card on another phone? If not,
remove the Sim card, insert it on another phone and try sending a message from another mobile to you number,
or you can do it in vise- versa by inserting another Sim card on your mobile.
If you can't receive text messages even when it's inserted on another handset,
then you will need to call the customer care of your Network Operator and tell
them your problem, they will help you fix it immediately.
You can check the message center number, but I don't think
it's very much important in your case, well, if you wanna try,
just check the text message settings and verify that the message
center number (which is currently in use) is the same number which
is on another phone with the same network (the other Sim should be
of the same network in your area). If it's different, make the changes
and save the settings. Also disable the "Receive Via" or similar settings..
(I can't recollect the exact settings as i don't have the same model with
me, please excuse me for this.).
If the same Sim card doesn't receive text messages using another handset,
don't bother to change the settings or to make any changes with it,
first call the customer care and verify from them, you may make mistakes instead of fixing it.
Hope that helps.
Thanks for using fixya.......
Jun 20, 2011 | Motorola Mobility W510 Mobile Phone
My E63 has been blocked by the Optus network...how do i un block it
Your handset can become fully locked due to exceeding the number of attempts to enter the correct unlock code. The type of handset you have will determine what process to follow to see if the handset can be unlocked.If your handset appears with a Code Error or does not unlock with the first or second attempt, you will need to call Customer Service to confirm the code. Once the handset is fully locked it will require manually unlocking from Optus and your handset will need to be sent away.
1 Insert SIM
N.B. Can be unlocked with SIM removed from handset however there is a 5 second time limit 2 Power phone on 3 Type: #pw+15 digit code+1 (where '15 digit code' is the unlock code) 4 Press Hash (#) - SIM Restriction OFF will display on screen for one second
Troubleshooting:
  • If the unlock code is incorrect the phone will display the message 'Code Error'
  • If the user tries to unlock a phone which does not have SIM Lock activated the phone will display the message 'SIM was not restricted'
  • If the syntax (#pw+) is incorrect when entering the unlock code - nothing will happen.
Jun 07, 2011 | Nokia E63 Cell Phone
I have a nokia 6700s slide and need to unlock the handset from vodafone. when i insert telstra sim it states sim not something please help.
To Unlock Nokia 6700 Slide from the United Kingdom(UK) or Australia's Vodafone NETWORK use the Unlock code and instructions ,buy the code at
Onlinegsmunlock.com
after unlocking it use any gsm Network.
Nokia 6700 Slide Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Nokia 6700 Slide mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 6700 Slide mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 6700 Slide without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6700 Slide.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6700 Slide would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6700 Slide mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6700 Slide
May 27, 2011 | Nokia Cell Phones
Hi, I cannot send any text messages on this cellphone, yet I could receive them. When I send something, all I get is a pop up that says ERROR! My Samsung Model is GT-C3303K How can I fix this?
Hope that helps.
May 24, 2011 | Samsung Cell Phones
My Blackberry Curve has stopped sending and recieving picture messages and it has only started happening this monht. how can I fix it?
Hi, If you can't receive text messages even when it's inserted on another handset,
Hope that helps.
Jan 19, 2011 | Cell Phones
My lg neon wont send text messages
I suspect it's related to your sim card (network), not your samsung cell phone. In most cases, regarding text messages, the problem is from the Service Operator. Have you tried the sim card on another phone? If not, remove the sim card, insert it on another phone and try sending a message from another mobile to you number, or you can do it in vise versa by inserting another sim card on your mobile.
If you can't receive text messages even it's inserted on another handset, then you need to call the customer care of your Network Operator and tell them your problem, they will help you fix it immediately.
You can check the message center number, but I don't think it's very much important in your case, well, if you wanna try, just check the text message settings and verify that the message center number (which is currently in use) is the same number which is on another phone with the same network (the other sim should be of the same network in your area). If it's different, make the changes and save the settings. Also disable the "Receive Via" or similar settings.. (I can't recollect the exact settings as i don't have the same model with me, please excuse me for this.).
If the same sim card doesn't receive text messages using another handset, don't bother to change the settings or to make any changes with it, first call the customer care and verify from them, you may make mistakes instead of fixing it.
Sep 25, 2010 | Cell Phones
My text messages wont send, keeps saying system error
Also itmight be caused by VIRUS,
You will need to format to restore back phone.
Take care.
Sep 14, 2010 | Cell Phones
Cant sed pictures etc rang t mobile they said the...
I suspect it's related to your sim card (network), not your samsung cell phone. In most cases, regarding sending picture messages, the problem is from the Service Operator. Have you tried the sim card on another phone? If not, remove the sim card, insert it on another phone and try sending a message from another mobile to you number, or you can do it in vise versa by inserting another sim card on your mobile.
If you can't receive picture messages even it's inserted on another handset, then you need to call the customer care of your Network Operator and tell them your problem, they will help you fix it immediately.
If the same sim card doesn't receive picture messages using another handset, don't bother to change the settings or to make any changes with it, first call the customer care and verify from them, you may make mistakes instead of fixing it.
Have a nice day.
May 20, 2010 | Sendo Sonim XP1 JCB phone extreme...
Insert SIM Card message in nokia 6080 though SIM is inserted
May be its detecting your sim card properly. Check your sim card in another handset. Verify if its the propbelm with sim card not your handset.
Nov 26, 2008 | Nokia 6080 Cellular Phone
Lands Phones Logo
118 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
