Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
Code E54039000 Recording Error can not record on this disc
SOURCE: recording error
mine was doing the same thing.and we found out that if you recorded something and dont finalize it will not recored anything else till you finalize what you recored then it works again
Posted on Jul 17, 2008
  • 4 Answers
SOURCE: Error code E 4 54040990
You need to go into the set up menu and select recording options. On the recording options menu, scroll down to dubbing options. On the dubbing options menu select either VCR to DVD or DVD to VCR.
Recording and Dubbing are not the exactly the same thing. You use the record buttons to record TV directly to VCR/DVD you use the dubbing buttons and set up to record DVD to VCR or VCR to DVD.
Hope this helps.
Dafid
Posted on Jul 19, 2008
SOURCE: I get Disc Error while recording. Why
I cleaned the laser lens and the problem went away
Posted on Oct 07, 2009
SOURCE: Recording Error, Can not record on this disc, E 4
magnavox dvd recorder/vcr mwr 20v6. forgotten how to get to the finalize screen
Posted on Mar 30, 2010
SOURCE: I have a SV2000 Vhs/Dvd Recorder. I can't seem to
Do I have to download something to be able to record vhs to dvd on my sv2000 dvd/vhs recorder?
Posted on Sep 12, 2010
Emerson EWR10D5 DVD Recorder/Player - using 16x DVD-R I get an error while recording
Sounds like a bad disc. You may also want to clean the laser lens with a cleaner disc just to be sure.
Sep 07, 2017 | Emerson Televison & Video
Error 0507
see the cause and fix it:
1 alternative for playing DVD:
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
2ND ALTERNATIVE: FOR VHS RECORDING:
play the VHS TAPE CLEANING , FOR clean the sensors, rollers, drum etc.
b) Try it.
c)Otherwise you must go to the repair shop TV for fix it.
God bless you
Jul 21, 2012 | Samsung VR-325 DVD Recorder / VCR Combo
My VCR-DVD magnavox ZV427MG9 A i get recording error, can't record +VR mode E 45
this is a similar problem with the same code http://www.epinions.com/review/Philips_DVDR3545V_37/content_464296251012?sb=1 The person in this says that the plastic "tab" on the back of the tape was broken off to keep from recording over it, but was unable to use it in a combo like you have. he put tape over the hole and it worked...Is this similar to what you are trying to do? let me know
Jun 11, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
Recording error
Refer to your user manual for error codes and troubleshooting tips.
If you cant find the error code then please kindly forward the following:
Disk Type:
Recording Device:
Hardeware Specifications:
May 26, 2009 | Symphonic SR90VE
Samsung DVD-VR320 DVD wont record and shows EC0509
Try cleaning the lens. A commercial lens cleaner should do the job, but if not, contact me again, and I'll try to help you clean it manually
Jan 04, 2009 | Samsung DVD-VR320 DVD Recorder/VCR
Panasonic DMR-ES30v Combo- Message of "Check disc for error"
Pay TV in Australia will record "no problem" BUT BUT when it is a pay per view or Box Office etc it will be blocked in a similar way as Macrovisin that is recognized in the encoding of the recording device that the signal is passing through. The result point blank displayed you are not allowed to record this program or it is blocked or distorted part of the way through the recording etc...
Dec 31, 2008 | Panasonic DMRES30V DVD Recorder/VCR Combo
Error code
Try using a DVD / CD cleaner disc in the unit - this might fix the problem.
Post Back here again..
Thank you
May 21, 2008 | Radio Shack Accurian ADR-0106
Recording Error "Can not record on this disk/E4 54037380
I had that exact same problem. I would record a bunch of dvds with no problems for months and then some and one day it doesn't work. Only this showed up E4 EA03738B. However I've found the solution. Instead of going out and returning the recorder or buying new dvds just purchase a Laser Lense Cleaner. It's a dvd cleaner. Works like a charm.
May 05, 2008 | Emerson EWR20V4 DVD Recorder/VCR
TOSHIBA RDXV45KB
This is a disc read problem the discs recommended in the manual seem to be the only discs that will work on this machine.
I was getting the same error code everytime but the disc that i know does work is a Verbatim 16X DVD-R.
These discs work in all situations on my machine , dubbing and direct from TV.
Mar 22, 2008 | Televison & Video
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
67 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
