TEAC Model CTM685 The Screen has gone to one single horozontal white line across the centre When I try to change channels it holds the new channel sor a couple of seconds then goes back to the white line Stewart
I have the same effing problem and i dont wanna pay to fix the damn thing cos it will probably end up costing more then the damn tv!
Posted on May 24, 2008
  • 137 Answers
You have a problem on your sinc board. Not posible to fix on internet. You must take it to dealer.
Posted on Mar 30, 2008
White line across black screen (setup mode?) model
if line is horizentle check vertical ic supply and out put capcitor if line is vertical check yoke wirsand cap 560k at horizentle yoke and any print brunt
Jul 03, 2010 | Quasar SP-2725 27" TV
White flickering line across top of screen
Set the screen format using your TV's menu. Do not set the format of the screen using your provider's receiver. I had this prob with a few channels with a dish provider when I set the format with the remote from the dish provider. I picked up the TV's remote, went into the menu, set the format, problem fixed.
May 15, 2010 | Vizio GV42L 42 in. LCD Television
Picture blank
Maybe it needs to be replaced with something more up-to-date.
Jun 26, 2017 | Sharp LC32D62U 32 in. LCD HDTV
Trying to connect Sharp VCA310X VCR to TEAC TV CTM5140; am only getting blue screen with audio; no picture! Have tried every possible combo with the AV cables (red, white, yellow).
I would suggest trying to change the channel, either on the tv or the vcr. Sometimes, if the channel is one off, you will get sound but not a picture. On the back of the vcr, there SHOULD be a switch to change it to either channel 3 or channel 4. You must match this up with the channel your tv is set for. I hope this helps, but if not, I hope you can get it figured out soon. Good luck! Der Strom
Apr 13, 2010 | Sharp Televison & Video
Horizontal line across screen
This is called "Field Collapse". Line collapse is different (a single vertical line) in the centre of the screen.
But field collapse is usually a fault in the field circuit (possibly a field output IC has gone short circuit) or electrolytic capacitors have dried out. The same can happen in a CRT TV - looks as if LCD panels are the same way! I think you will have to take this to a service centre.
Sep 12, 2009 | Memorex Televison & Video
Magnavox with a white screen, sound, volume and channels working
dont put in back the vertical prossesor ic get a new one and solder it in see what it does.good luck.
Aug 19, 2008 | Philips Magnavox 27MS343S 27" TV
This is a vertical-deflection problem. Try to adjust the vertical (height and linearity and hold) controls, which should be screwdriver potentiometer controls on the back of the set.
If this does not work, a defective component in the vertical-deflection circuit will need to be repaired.
I hope this helped you. :)
Mar 30, 2008 | Televison & Video
TV Trouble: Toshiba Flatscreen CRT (Brazilian model: Linha Face)
i suggest if you buy it few months ago that item is under warranty
you to call the toshiba service and try to have changed with another
one or get free service - delfo
Mar 21, 2008 | Televison & Video
If the lines across the screen are made up of coloured blocks, then the problem is likely to be a weak signal.
Digital channels are broadcast in groups called multiplexes. Sometimes one multiplex may have a weaker signal than others, and so you experience problems with up to 6 channels when all others are ok.
If it is only one or a few channels then just wait and see what happens, because it may be transmitter works.
If you have problems with all channels it could be a connection or antenna problem.
If the lines are just straight lines, then try resetting the TV as follows:
Switch on the TV
Press and hold the menu button on the side of the set. The settings menu will appear. Hold until the menu disappears again.
When you release the button, the TV will take up to about 90 seconds and then reset.
The TV will then show the original screen when the TV was new.
Press ok when shown.
Set language and country settings.
Move down the list and press ok to re-install all channels.
Feb 22, 2008 | Philips 26PF5521D 26 in. HD-Ready LCD...
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
