Yamaha YSP-4000 Main / Stereo Speaker Logo
Posted on May 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The subwoofer on my yamaha ysp 4000 is not working
Any advice appreciated
Anonymous
Level 3:
  • Master 10,515 Answers
  • Posted on May 14, 2010
Anonymous
Master
Level 3:
Answers
10515
Questions
Helped
2934543
Points
31530
For less money you could repair the sub yourself if it's something you're interested in doing. First off, does the amp come on and there is simply no sound, or is there no power to the amp at all? If there amp powers up, and there is no sound, try removing the woofer and put a multi-meter on the woofer's main leads. If the reading is between 4-8 ohms- then the speaker is likely fine. Push down on the cone gently in the center and listen for any scraping sounds. If it scrapes then the woofer has a scraping voice coil and would need to be replaced.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
  • marty602 May 14, 2010
    Hi the woofer powers up and does seem to be ok but there doesn't seem to be the sound there when you think there should be.
  • Anonymous May 14, 2010
    Thanks for your response!!
    Let me know the value, so that we could proceed further.
    Hope i helped you.
Yamaha YSP 4000 is not working.
What lead you to a bad capacitor? Have you tested the various power supply rails?
I AM LOOKING FOR A REMOTE YAMAHA SOUNDBAR YSP-1100
The replacement remote is available at Amazon.com and probably other vendors of replacement remote controls. The replacement original remote at Amazon is here: https://www.amazon.com/OEM-Yamaha-Remote-Control-YSP-1100SL/dp/B0166DUFAE . If you need the information to program this remote for other devices, see the manual. The manual is available from Yamaha at the product support page: http://usa.yamaha.com/products/audio-visual/digital-sound-projector/ysp-1100_black__u/ . The direct link to the manual is currentlyhttp://download.yamaha.com/api/asset/file/?language=en&site=usa.yamaha.com&asset_id=8872 .
I hope this helps.
How to change voltage from American standard 120 V to European 220V
This is for a powered speaker? You'll need an "autotransformer" or "step-down transformer" with a 240VAC primary winding and a 120VAC secondary winding. If you try to just use a plug adapter and power that speaker from 240V, you'll destroy it immediately.
4helpful
3answers
I get a loud static noise, when I first turn on the yamaha ysp-1. Lasts a few seconds. Have unplugged all inputs. Problem persists.
u have a cool sound projector but u have a baaaad power supply system. bad power supply design - u will get all sorts of noise when u power it up. i have a sub woofer with the same problem(which in my case is the way it is designed). i used a delay circuit. but in ur case i know YSP-1 has a clean start up. so, if the warranty still covers it get it replaced. static noises, pop noises are often caused by bad capacitors.
Connecting an iPod to Yamaha YSP-1000
The best way to get quality sound would be to go through the USB connection of the phone.
It will be hard and a bit costly to get a cable to link the Ipod and projector.
Easiet and economical way is to go to apple and purchase a cable for the jaudio jack at the top of the Ipod that will also have an audio jack connector for the projector
2answers
Power Subwoofer doesn't work
Two possibilities:
1. Your source material does not contain bass frequencies.
2. Your SUBWOOFER SET - BASS OUT is set to Front, rather than SWFR (subwoofer). See page 63 of the manual.
https://www.yousendit.com/download/dVlvdFdaY3lJMHZIRGc9PQ
or
http://tinyurl.com/csw8sy
Let me know if that helps.
2helpful
2answers
YSP: Need remote code for TV Sony Bravia KDL-46W4500
I have the sony KDL 46 EX720 and got the code 2751 to work.
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
