Question about Whirlpool WED6200S Electric Dryer
Have power but will not start
I replaced the heating eliment. it nearly burned the cloths and stopped with 7 mins to go . Now it will not start at all. could this be a fuse or a shut off switch somewhere?
  • Whirlpool Master
  • 43,501 Answers
There can be many reasons why your dryerhave  power but will not start - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The have power but will not start - 2_bing.gifsrc="http://i.fixya.net/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 15, 2010
Dryer willnot heat
heating eliment is most likely burned out. Better off getting new dryer. But if that is not an option then call a repair person that can replace the heating element.
Nov 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My dryer will not heat at all. I have replaced the heating eliment, checked the fuse box. It still will not heat. What else could I check?
check for a burned neutral power connection at element,a defective thermal/hi-limit switch or cycling heat switch or control pad
Nov 01, 2009 | Dryers
Power, channel and sound buttons are not functioning properly.
Dear Sir,
By analysing your problem it seems to be a moisture problem.Take out the circuit board check for any dry soldering,then rub the upper surface with pure cotton cloth where key pad located,then make dry by heating it beneath the 60 watt bulb for about 15 min, ensure that bulb is not located to near,it may burn inner circuits.After this process,rearrange your remote and check it agin.I think it solves your problem
good luck.
Aug 10, 2009 | Philips 50P8341 50" Rear Projection...
Dryer does not dry clothes completely
Could be a clogged exaust path..
Or could be a heating eliment..
A way to check it --
remove the exaust hose..
put a mirror to see inside the exaust hole - trying to see the eleent(s)..
When on - the eliment will glow hot..
If not - might need replacing..
Hope this helps !!
rate me good ;o)
Jul 13, 2009 | Kenmore 63942 Dryer
It wont dry my clothes
Check the following for a gas dryer--
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Check the following for a electric dryer--
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Jun 01, 2009 | Kenmore Dryers
Wirlpool dryer heating eliment keeps braking
Sounds like you use dryer sheets. If you do, try cleaning your lint screen with vinegar. Dryer sheets leave a film on the screen that the dryer eventually can't breathe through, the dryer overheats and burns up the elements.
May 26, 2009 | Whirlpool LER5636P Electric Dryer
Heating eliments do not heat up
Did the electrical service power go out, or did the display on the oven go out?
If it was the display, then make certain the breakers didn't trip or fuses blow feeding power to the unit. If they are both good, and the display is still not lighting up, the unit may have blown a thermal fuse, usually located near the control head. This failure could be caused by a number of things (it happened that my KitchenAid had a service bulletin and modification kit to replace the blowers and reroute the wiring).
Please reply you findings and I wil help you more.
Jan 24, 2009 | Whirlpool RS696 Electric Kitchen Range
Kenmore cloths dryer will not heat up
3. Igniter
Oct 18, 2008 | Kenmore 659 Electric Dryer
Whirlpool WED6200S Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
