Question about Samsung DLP HL-P5663W 56" TV
Dlp tv i have white spots on my dlp tv what can i do to fix this
  • Samsung Master
  • 610 Answers
There is a chip on the DMD board that needs to be replaced.Samsung is covering the cost of the part and labor for this problem.Just call 1-800-samsung and they will set up the repair with the closest service center. VERY common problem.
Posted on May 14, 2010
3 Suggested Answers
  • 3 Answers
SOURCE: MY SAMSUNG TV HAS WHITE SPOTS APPEARING ON THE SCREEN
There is a link to a forum with the solution, it's your DLP chip on the DMD board:
http://www.avsforum.com/avs-vb/showthread.php?p=16445994&posted=1#post16445994
Samsung denies this is an issue, to express ouroutrage a facebook group is created:
http://www.facebook.com/home.php?ref=home#/group.php?gid=76261763079&ref=mf
Posted on May 12, 2009
SOURCE: White spots on screen of my Samsung DLP TV
What causes the DMD board to go out?
No Picture, but have sound
Had a new lamp put in this morning
TV now has 2 white spots
TV - bought in 2003 for $3600.00 and only used 5 months of the year
Posted on Dec 15, 2010
Is there a recall on the mitsubishi dlp chip wd-65735 and are they replacing them free
Nope,,,White dots, white snow or sparkling stars on your DLP TV mean only one thing - a worn out DMD chip. The white dot syndrome seems to happen when the DLP TVshave been in use anywhere from two to five years - usually when the warranty has expired
Certain brands seem more vulnerable than others to the white dot syndrome. Samsung and Mitsubishi DLP TVs have been plagued with the problems for several years now. Sony and JVC choose to take the TVs set off the market in response to complaints from disgruntled owners.
If you read the various forums offering solutions, you'll see customers being given quotes of $600 and upwards for solving the white spot syndrome or replacing the DMD DLP chip. Fortunately, there are companies offering the offering the DLP chip for under $230 if you want to fix it.
Dec 31, 2017 | Mitsubishi Televison & Video
I have a 67" DLP TV and last night 2 white spots
That usually indicates that the optical block is going bad. That repair is usually 900-1100 dollar fix.
Mar 30, 2011 | Samsung HL-67A510 67" DLP HDTV
Bright white spots on mitsubishi wd-73833 I just replaced the lamp and now these bright white spots have started to appear!
This unit uses a DLP (digital light processor) chip and if this starts to fail then you will get spots appearing on the screen. The DLP chip will need to be replaced.
Mar 24, 2011 | Mitsubishi WD-73833 73" HDTV
I have a Mitsubishi DLP WD-57734 and white spots just started appearing I have owned the TV for 2 years and only one person in family uses it and not video games have replaced the lamp on time
The projection engine have problems,it the cause.Two years tv shouldn't have this problems already.Call talk to mitsubishi,might get some help the cost of the repair.
Jul 03, 2010 | Mitsubishi WD-57734 57" HDTV
Samsung dlp tv hl-s4266w has white spots on it? How much to fix?
Are they spots or dots? If they are spots then the optics are contaminates. If they are dots either white or black then you have a bad DMD chip. The cost of repair depends on who you hire to repair the set or if you do it yourself it depands who you purcahse the part from.
Jul 17, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP white spots
Are the spots fixed or do they move with the image? Verify that all venting is clean of dust. If the spots are fixed and upon close examination are a square shape, The device is overheating of failing. If the spots are moving with image it's a front end problem, and can be overheating as well.
Jun 27, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White spots on Samsung DLP
Hello the problem here is absolutely the DMD Board this is a commune problem with the Samsung DLP
are your spots like this picture?
try this link...
http://www.discount-merchant.com/
Jun 12, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP with white spots
Hello rockel, As the commercial goes, "It's the mirrors" and that is exactly what it is. The DMD (digital micromirror device) DLP chip that is the problem. The areas that are white are due to stuck or malfunctioning mirrors. This will only get more pronounced as time goes on. The fix is to replace the DLP chip and or module. I would advise that you get a qualified TV technician to do this. I hope this helps Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 11, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White spots on screen and growing every day
If these spots are small, they are likely the visual effect of a failing DLP chip. When some of the tiny mirrored surfaces on the chip stop moving, this is the result. This is not something you can fix yourself. A Samsung authorized service center will charge $400-$500 to replace it for you.
michtech
Feb 18, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Numerous white spots on Smasung DLP TV
See link below for "field of stars" fix:
http://www.avsforum.com/avs-vb/showthread.php?t=1107926
Worked a charm on my 50" Samsung DLP. Read thread carefully as there are 2 different version of the DMD chip you will need to replace. I ended up fixing mine for less than $165!
Chuck
Feb 07, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HL-P5663W 56" TV Logo
307 people viewed this question
Jerry Greenberg
Jerry Greenberg
