Question about HP OfficeJet 7310 All-In-One InkJet Printer
How do you set date and time on HP7210 printer?
Press: Setup, press: 4, press: ok, enter Date, then Time
Time is found in Basic Fax Settings option 4 and option 1 on the HP OfficeJet 7210 All-in-one series printer fax scanner
Posted on Dec 23, 2010
HP7210 scanner won't recognize computer
In a wireless setup, the printer needs to be installed on each machine, exactly as you would to have the printer hooked to that machine.
Follow the directions exactly, from the install program provided free from HP.
Nov 30, 2012 | Adobe Acrobat Professional 7.0 for PC
How do i set the time and date for faxing on a canon mx410 wireless printer
Press the Menu button repeatedly to display Device settings
Use the left/right arrow buttons (the - and + buttons) to Select "Device user settings", and press the OK button.
Use left/right arrow to select "Date/time setting", and press OK.
Use the numeric keys to enter the date and time (in 24-hour format) and press OK.
Press the FAX button to return to standby.
Mar 26, 2012 | Canon Pixma MX410 All-In-One Printer
Can my hp7210 office jet work for my hp laptop without be plugged into my laptop? I have a router for the laptop. Can the printer be plugged into the same router? Thanks.
Yes, this printer is a network printer so definitely you can connect it at the router, make all the settings that you can find at the user manual (pages132 - 145) and not also print but scan also from your local network.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Sep 21, 2010 | Computers & Internet
How do i change the time and date on my hp officejet 6310 printer
First of all, congrats, you are using one of the best printer on the market.
For HP Officejet 6310 :-
To set the date and time
1. Press Setup.
2. Press 6, and then press 3.
This selects Tools and then selects Date and Time.
3. Enter the month, day, and year by pressing the appropriate numbers on the
keypad. Depending on your country/region setting, you might enter the date in a
different order.
4. Enter the hours and minutes.
5. If your time is displayed in the 12-hour format, press 1 for AM, or 2 for PM.
The new date and time settings appear on the display.
And, you can also download it's User Manual from :-
http://h10032.www1.hp.com/ctg/Manual/c00633922.pdf
Sep 19, 2010 | HP Officejet 6310 All-In-One InkJet...
How do you set HP7210 all in one for distinctive ring fax
The user manual is posted here if you have access online: http://h10032.www1.hp.com/ctg/Manual/c00278645.pdf
and distinctive ring information is on pages 77, 79, 83, 84, 97, 102, 103, 119, 187, and 189. Hope this helps you find info to set your 7210 for distinctive ringing.
Jul 15, 2009 | HP Officejet 7210 All-In-One InkJet...
How do I set the date and time
I found this that may help you:
"Set the date and time      You can set the date and time from the control panel. When a fax is transmitted, the
current date and time are printed along with the fax header. The date and time format
is based on the language and country/region setting.
Note If your HP all-in-one loses power, you will need to reset the date and time.
1 Press Setup.
2 Press 4, and then press 1.
This selects Basic Fax Setup and then selects Date and Time.
3 Enter the month, day, and year by pressing the appropriate numbers on the
different order.
The underline cursor is presented initially beneath the first digit; it automatically
advances to the next digit when you press a button. The time prompt
automatically appears after you enter the last digit of the date.
4 Enter the hours and minutes.
5 If your time is displayed in the 12-hour format, press 1 for AM, or 2 for PM.
The new date and time settings appear on the control panel display. "
Jun 27, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HOW TO SET TIME IN PRINTER
You can set the date and time from the front panel. When a fax is
transmitted, the current date and time are printed along with the fax header.
The date and time format is based upon the language and country setting.
Normally the computer software sets the date and time automatically.
1. Press Setup.
2. Press 3, then press 1. This selects Basic Fax Setup, then selects Date and Time.
3. Enter the month, day, and year (last two digits only) by pressing the appropriate number on the keypad. The underline cursor presented initially beneath the first digit advances automatically to each digit after, each time you press a button. The time prompt automatically appears after you enter the last digit of the date.
4. Enter the hours and minutes. The AM/PM prompt automatically appears after the last digit of the time is entered.
5. Press 1 for AM or 2 for PM.
The new time and date settings appear on the front panel.
Apr 26, 2009 | HP PSC 2210 All-In-One InkJet Printer
HP7210 Installation to MacOSX 10.5.5. No Device Found
I suspect you are right that it's the USB cable. If the printer does TCP/IP you should try plugging an Ethernet cable from the printer to an empty port in your router. Get the IP from the printer configuration page and print to the IP using a general postscript driver. If that doesn't work, it's the printer...if it does you can start troubleshooting back to the machine.
Dec 10, 2008 | HP Officejet 7210 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
326 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
