Question about Sony HVL-F56AM TTL Flash
I need a base part for my flash. the track is cracked.
  • 10,515 Answers
Are you looking for :-
http://cgi.ebay.com/Mini-flash-stand-Foot-Base-4-Sony-HVL-F58AM-F56AM-F42AM-/250632265461?cmd=ViewItem&pt=Camera_Flash_Accessories&hash=item3a5ad8def5
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 14, 2010
  • jpoist May 14, 2010
    this is what it looks like
  • jpoist May 15, 2010
    did you get to see the part pic that i sent?
Replacement part
The bases are sold on EBay, I replaced 2 of them. There cheap comparably from buying a new one. Like you said 4 screws, but be careful there is also 4 springs inside. http://www.ebay.com/itm/Canon-MR-14EX-Ring-Light-Replacement-Flash-Shoe-Foot-Free-Shipping-/370901814099?pt=Camera_Flash_Accessories&hash=item565b788b53
Good Luck Raf Camera Guy!
Mar 26, 2014 | Canon MR-14EX TTL Ring Light Flash
Replace rear turn signal lens 2000 sable wagon
Undo the bolts or nuts inside near the deck lid it should have a cover to remove.
Jan 18, 2014 | 2000 Mercury Sable - Wagon, with factory...
Loose drivers side seat on 1998 acura
if you look , you'd have seen them.
but id bet it not the bolts. but do look
what you do is look at the track.
the track has 2 parts. bottom and top
if you wiggle the seat and the :
bottom wiggles with top , the base is loose.
if the top and bottom tracks , only move there, the track is bad.
there is no visual play at track juncture. so..... if there is, its bad.
if the base and track dont move the seat frame is cracked.
sounds hard, no,
its a 10 second job, you look and see what is loose.
now my wild useless guess.
the someone removed the seat, and its on back on track.
or as my fat boss did, broke the seat frame.
Dec 03, 2013 | 1998 Acura CL
The porcelain spark plugs keep on cracking when the car is being used
Is the porcelain "cracking" or are they getting "carbon-tracked"? (see example photo of carbon-tracked plug below).
It is common for carbon-tracking to occur if your original plugs were carbon-tracked and you replace the plugs without replacing the wires. If the plug is carbon-tracked, the boots on the wires or the coil boots (coil-on-plug ignition) are also carbon-tracked. If you do not replace the wires or the coil boots, the ignition will still misfire by following the carbon-track on the inside of the boot. This will cause your new plugs to also be carbon-tracked within a short period of time (days or weeks).
There is no reason I can think of for the porcelain itself to actually crack other than faulty installation techniques or possibly, cold liquids getting poured on extremely hot plugs.
May 11, 2012 | Buick LeSabre Cars & Trucks
The plastic base the blades are fitted in ,cracked need to order replacement
the part is Black and Decker Blender Base Collar Ring BL5000-11
However these are prone to cracking. I ordered a second after my first cracked, and the second one cracked after just a couple uses.
Jun 09, 2010 | Black & Decker BL1900R Blender
F1 display flashing?
Flashing wrench means a fault code has been triggered.
F1 is the fault code when flood switch at base of dishwasher cabinet turns on.
This can occur due to several reasons when moisture gets to the base of the drawer cabinet.
You will have to turn the power off and extend the drawer out as much as possible to expose the back of the cabinet. Take towels and a hair dryer to dry the base. Once the flood switch gets dry the problem will go away.
The main thing is why did the water get there. You could have a crack in the hose or simply the detergent may have caused too much foam.
Jan 07, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Flash does not work on my Nikon D 80
My D80 had the same problem, I took it apart by first removing the base (make SURE you track which screw goes in which hole!), then remove the front shell (around the lens mount) but first remove the A/M lever by prying the cover off and unscrew it- pop the flash to remove the two small screws at the front of the flash rest point. Still keeping track of the screws? Now remove the screws holding the sides, you do not need to remove the battery side (it has another screw holding in deep inside the battery well). Now you can remove the rear shell - watch the flat ribbon cable, it is released by gently prying up on the thin black bit of plastic on the connector - I did say GENTLY. Now remove the side cover on the left (rear view). Check the tiny wires that are loop around the top from front to rear - I found one was broken. Find someone very good at soldering and solder it back. Now reassemble - you DID track which screw went in which hole? I also recommend that you photograph each screw removal and measure the length of the screws (mm - 4, 5, 6, & 8mm).
I too a bunch of pictures and am considering a take-apart page, but rather busy right now...
It is easy to break ribbon cables - be careful!
John :-#)#
Dec 13, 2009 | Nikon D80 Digital Camera with 18-135mm...
Minn Kota 24v auto pilot. will track correctly
Usually this means that there is a crack in the coil cord or there is something metal close to the head of the motor.
The coil cord can be checked while you are out fishing next time by grabbing the cord (black coiled cord from base to head of the motor) and stretching it and pulling on it. If the motor reacts to the pulling then that's the problem.
best of luck!
Mike
Jun 20, 2009 | Minn Kota 55 AutoPilot Universal Sonar...
Reset my laptop user password
Go to safe mode to reset it?
star the PC and press F8 then go to :Administrator
then enter “net user "your user ID" 1234 /add”, then your user ID password is 1234.
or take a look at http://www.laptops-battery.co.uk/blog/hacking-ibm-thinkpad-bios-password
I think Hack Dell inspiron 1501 password is the same as the IBM.
Jan 08, 2009 | Dell Inspiron 1501 Notebook
Problem with technics SL-L20 linear tracking turntable
Not sure what your question is? Linear tracking turntables also have an assortment of gears and pulleys which make it function correctly. Sometimes the drive belt will break, other times, the gears will crack. You will have to open her up, and take a look inside to see if there are any components which are damaged. There may also be grease applied to the gears, which might also be preventing it from moving properly.
- OPTiC
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
Jul 22, 2008 | Panasonic Audio Players & Recorders
Sony HVL-F56AM TTL Flash Logo
119 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
