Question about Bose 901 VI Main / Stereo Speaker
I have a pair of bose 901, v1 I have a old pioneer vsx 5300
I youse the required eq, and tape moniter function. I need a lot more power I think to drive theese. what are your thoughts ??
  • David Dunn
    David Dunn May 15, 2010
    Fill in some blanks here. What's the symptom? More power? That's subjective. What's the amp? If this is really 901 V1 then you'll need a LOT of power. Good article:http://www.epinions.com/content_46918944... "Keep in mind that Series I & II are considerably less efficient than Series III thru VI. Amplifier clipping should be avoided and one must choose an appropriate amp for each series. "
    Brigadier General:
  • 8,546 Answers
Not knowing anything about your specific amplifier or if it correctly configured for the 901 Active Eq, the first thing I would say is these are designed for analog stereo sources ONLY and a multichannel digital-capable receiver will NOT work properly with any devcie in a Tape loop.
There is no way around this part. Get a separate power amp for the 901's if you want to use them in a multichannel way or alongside non-901 speakers.
Connect the Active EQ between the pre-outs and the amp input. Run speaker assignment, levels, etc and have fun.
Posted on Mar 31, 2011
How do I connect my bose equalizer to my pioneer amplifier
The manual is at Bose.com.
In any question regarding connections the exact models of all parts in the scenario should be defined.
"Pioneer amplifier" is not unique nor revealing. Integrated amplifer? Power amp? Tape Loops available? Pre-Outs? What's involved as a preamp?
The key thing to know is that any amplifier channels driving 901's must not drive other speakers as the Active EQ severely modifies the Line Level source input. If the EQ (or any sound processor) is used in a Tape Loop on a modern multichannel digital-audio-capable AVR, ONLY 2-channel analog sources will function when the Tape Loop is engaged; and all downstream speakers will be affected by the processing. That's par for the AVR course.
Bose 901 use in multichannel applications (which I have) will require access to Pre-Amp outputs for the chosen channels (likely the Front) and you will need to get a separate amp for the 901's, placing the EQ in series with the chosen amplifier. I currently drive mine with a Carver MT-200T.
Sep 20, 2011 | Bose 901 EQ1915 Home Equalizer
I'm connecting Bose 901 speakers with an Active Equilizer hookup required to my new Pioneer VSX-520. What in/out puts should be used ??
The solution to using 901's in a multichannel rig works best when you have individual Front Right and Left Pre-Outs but this receiver doesn't have them so a compromise is in order.
First some background.
The use of 901's Active EQ (or any external processor) in any digital AV receiver setup for anything EXCEPT STEREO listening through the 901's alone requires you to have a separate amplifier for them and to avoid having to use a Tape Monitor which could introduce proprietary and potentially damaging Active Equalization back into anything in the AV Receiver with its conventional speakers.
In an AVR, if you activate any Tape Monitor circuit at all, you will kill any digital sources. That is a function of AV receivers in general, nothing to do with 901's. Your Pre-Outs get us around that possibility and limitation but it also means you need a moderately powerful amp for your 901's.
http://www.retrevo.com/support/Pioneer-VSX-520-K-Receivers-manual/id/23653ag911/t/2/
This works for all models of AV receivers when you want 901's as Front L&R speakers...
Get yourself a nice separate amp, draw the Front L&R pre-out signals from wherever you can find them, in your case maybe the CDR or DVR/VCR outputs.
On many AVR's, there is a pre-amp out for every channel in case you want to run external amps for any channels. That is how my old Pioneer VSX-36TX is equipped. For others (yours), you have to borrow the signals from a typical CDR or DVR/VCR Output RCA pair. Just remember, AV receivers disable digital inputs as soon as you switch in a Tape Monitor, so choose one you won
Feb 13, 2011 | Pioneer Audio Players & Recorders
I have a Bose 901 Series VI speaker system & have recently purchased a Pioneer VSX-1020-K AV Receiver. How do I connect the 901's EQ to this amp. I believe the only option is the CDR/TAPE IN/OUT...
This receiver has no pre-amp outs to drive the required separate amp the 901's need for you to continue to have multichannel digital audio. The reason: activation of a tape loop disables digital inputs. But they DID give you Front Height. Oh boy.
Sep 15, 2010 | Bose 901 VI Main / Stereo Speaker
Pioneer vsx 1020 K receiver. I connected the bose 901 eq to the tape in and tape out but it doesn.t seem to be compatible.
It would be compatible if you ONLY listened to stereo ANALOG sources on ONLY Bose 901's. Engaging any device in a tape loop automatically disconnects digital sources. Bose Active EQ is not intended for anything BUT Bose 901's. The sub could be destroyed by it.
Lacking appropriate Front Left and Right volume-controllable pre-outs on the 1020k, you can't use the 901's for multichannel or digital source material unless you accept a severe compromise and get a separate amp for the 901's borrow mixed-down stereo from the Pioneer's Tape Out, run it through the Active EQ to the new amp and manually manage the external amp's volume.
You need Front Pre-outs.
Jul 20, 2010 | Bose 901 VI Main / Stereo Speaker
How to install bose 901 eq to my pioneer vsx-1019ah-k
Get yourself a nice separate amp, draw the Front L&R pre-out signals from wherever you can find them. On many, there is a pre-amp out for every channel in case you want to run external amps for any channels. That is how my old Pioneer VSX-36TX is equipped. For others, you may have to borrow the signals from a typical Tape- or Adapter-Out RCA pair. Just remember, AV receivers disable digital inputs as soon as you switch in a Tape Monitor, so choose one you won't have to switch IN. The signal Out is always there regardless of the monitor state.
Patch the Active EQ directly off that point (Amp In from the receiver, Amp Out to the new amp). Run all the speaker level settings on the AV Receiver and rock on.
Nov 04, 2009 | Pioneer VSX-1019AHK A/V receiver
How to connect old 901 Bose equilizer to amp/receiver
If you plan to use them with a home theater, you will need a seperate amplifier, as most a/v receivers don't have tape monitors. With an integrated amp hook rec out to the input on eq hook output on eq to playback on tape mon. with seperates hook pre amp out to input on eq, output on eq to power amp input.
Jun 23, 2009 | Bose 901 VI Main / Stereo Speaker
How do I connect my Bose 901 to my Pioneer VSX-515. I have used the eq to the tape in tape out as instructions tell me to do, but do not have a "tape monitor" button on my receiver. I get sound from the...
I'm not sure that receiver is compatible with outboard EQs like the 901 EQ. This receiver is also not on Bose's 901 EQ compatibility chart, so it's possible that this is not going to work at all. You could call Pioneer and ask if this receiver is compatible with ANY outboard gear (such as EQs, compressors etc) but I don't think it is.. The tape in/ tape out I think is only for 1 source.. That's the problem with new receivers, they expect that nobody will want to connect any external gear (like back in the day) because everything is built in.
Jun 11, 2009 | Onkyo TX-SR705 Receiver
Best amplifier for bose 901 VI speakers
By all-in-one amplifier that handles the surround I think you mean all-in-one receiver or preamp. Amps are just big dumb muscular power supplies for speakers.
The source control and digital decoding could be handled by a modern AV receiver with multichannel analog outputs for driving separate amps or you could get a digital AV preamplifier/control unit functionally like this Adcom. Prepare for sticker shock.
http://hdtvdreams.com/Adcom-GTP-870HD-7.1-Multi-Channel-Processor/Preamplifier-GTP870HD.aspx
Understand that EACH PAIR of Bose 901's will require its own DEDICATED two channels of amplification AND someplace to jack in its Active Equalizer - between the line level source and the power amp.
Conventional speakers can probably run off the receiver's amplifiers since they don't/can't/must not have the Bose Active EQ in line with them.
Having a single pair of 901's plus a passive subwoofer or two in the same room for accurate 6- or 7.1 surround would require at least four stereo amps or some combination that adds up to 8 channels.
In my own system I have a Pioneer VSX-36TX Receiver (with 5 potential channels of amplification for Left, Right, Center, two Surrounds) doing light duty as the control and routing center but ONLY driving the Center (two Kenwood 777's) and Surround speakers (Bose 301's). I have a Carver 5-channel amp pushing the Bose 901 Front speakers (100Wx2), two dbx Subwoofers (110Wx1) and the Bose 301 Rear Surround speakers (60Wx1).
You could probably get by with a powerful 2-, 3- or 4-channel amplifier to push the 901's and subwoofer(s) as I did. It's the cheapest way out if you get a decent AV receiver. Once you set up the levels and delays the receiver does all the thinking and controlling for you.
Mar 18, 2009 | Bose 901 VI Main / Stereo Speaker
Bose 901 equalizer hookup
how do I hook up the bose 901 EQ to a yamaha DSP3090??
Nov 08, 2008 | Bose 901 VI Main / Stereo Speaker
Bose 901 VI Main / Stereo Speaker Logo
139 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
