Question about Pioneer AVICU310BT GPS Receiver
I hook my head unit up and it comes on with out the key in the car and will not turn off on the pioneer avicu 310bt I have a wire kit so I know it hooked up right any answer on that
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 35 Answers
Sometimes harnesses get pinned wrong by the factory. Very rare but I have seen it a few times. Also, if you drive a european vehicle, the yellow (constant) and the red (ignition) are actually backwards on the vehicle side.....not all but some. The yellow and red should always be separate. A lot of new vehicles don't have an ignition lead. They turn on with data. In that case you will have to run your own ignition lead
Posted on May 15, 2010
Pioneer DEH-3300 UB
Apparently, you have no power at the 12 volt battery/memory wire at the radio harness of the vehicle. This wire is white with blue in color.
Also, based upon your description, you have connected the battery/memory wire and the accessory wire of the radio to the 12 volt accessory (switched) wire of the vehicle. This wire is white with red in color.
Check the radio/ stereo fuse of the car. You may have blown the fuse during your installation.
You have no memory at the radio because when you turn off the key, you lose all power to the radio.
Also, I mentioned the wire colors just in case you used an aftermarket radio wiring harness. Make sure that the yellow from the Pioneer unit is going to the battery power source and, the red of the Pioneer is going to the switched power source.
Sep 12, 2012 | Pioneer Car Audio & Video
Problem wirings for Pioneer AVH-P6500DVD Car DVD Player
very easy fix. you can pay thirty bucks on ebay and buy the bypass kit or make it yourself. but the light green wire on the harness has to be hooked up to ground. just hook the light green wire to the chassie of the car and you will be able to see dvds all the time. If you want to buy the kit its not really needed I have a toggle switch on mine just for turning it on and off when I am driving. simple as putting a wire from your chassie of the car(Ground) and then the other from the unit(light green wire) to a switch. hooking it up from Supply to Acc on the switch.
Mar 17, 2009 | Pioneer AVH-P6500DVD Car DVD Player
Automute car kit for Sony Ericsson OEM HCB-300
I am having the exact same problem with my vauxhall corsa and my pioneer deh-6000ub its so annoying it works with the manufacture stereo soon as i connect my pioneer in it doesn't come alive (the HCB-400)
Mar 13, 2009 | Sony -Ericsson OEM HCB-300 Bluetooth...
Pioneer head unit plays in accesory mode, but not when vehicle is fully started
he tapped into starter wire instead of accessory. Remove radio and verify the switched power (red) wire is properly hooked up to an accessory wire that stays on after vehicle is started.
I believe the wire is white/black behind the radio. Check with a voltmeter to be sure.
http://www.the12volt.com/installbay/stereodetail/967.html
for the wire codes to that vehicle.
Oct 18, 2008 | Pioneer DEH-P3700MP CD Player
Soundstream300 amp how do I hook it up to my pioneer head unit
That depends on which wires you are referring to. High level inputs or low level (RCA) outputs? If you are thinking about trying to wire the amp up to your Pioneer direct, ie; running the power and ground off of the factory harness, think again, you'll fry your electrical system. You need to run a seperate power kit (8 gauge minimum; 4 gauge pref), then run RCA's from the line level outputs on the Pioneer. If you are planning to run a sub with the Soundstream then run your RCA's from the Pioneer's sub output. Let me know if I can help you any further.
Aug 17, 2008 | Soundstream EGA900D Car Audio Amplifier
Someone gave me a Pioneer DEH-2700 head unit and didn't have any of the manuals. I have a 2007 Chevy Cobalt How to I install this unit into my car. I don't know which wires go to what or anything
the easiest way to solve this issue is to buy a wire harness for your car this will make the install alot easier. Its already color coded for your wires, so head out to your local installer or try best buy you might also need a stereo kit. Email me with questions on installs. jerree_cardenas2006@yahoo.com
Jul 25, 2008 | Pioneer Car Audio & Video
How do i turn on sub mode?
For one thing I hope you know you need an amp to even power subs at all.. The remote wire coming off the rca wiring that you hook your subs up with has to go on the prong 3-in on the top here is a rough diagram: the = signs are power and ground and the prongs are thicker the comma is you remote..
You need a wire coming out of that slot on the wiring harness.. it should be blue. and unless you have a power antenna(comes out when you turn your radio on) then you dont need the blue/blue&white power ant. wire you can just cut it and cap it. if your amp isn't coming on when you turn your ignition to acc then your remote wire isn't properly attached..
May 15, 2008 | Pioneer DEH-P4700MP CD Player
Pioneer DEH-225 Car Audio
The system remote control is usually a blue wire on your decks harness and it is for an amplifier for a sub or other speakers. It sends power to the subs amp when the deck is turned on. You may need to find the wires coming off the antenna and splice them into the red power switching wire 12v on you decks wire harness. Good luck
Oct 07, 2007 | Pioneer DEH-225 CD Changer
Changed settings(LP to SP)
If there is still no sound, you probably hooked up the unit's wires wrong. Try switching the wires coming off of the back of your head unit so that the wire that is supposed to be connected to the amp turn on in your factory harness isn't connected to the antenna lead or something like that. I don't know what the Pioneer wires look like, on my Sony there are two blue wires, one with a white stripe on it and one just plain blue. The wire with the white stripe on is the one that should be connected to the amp turn on in the factory harness.
Mar 05, 2006 | Pioneer MEH-P5000 MiniDisc Player
Pioneer AVICU310BT GPS Receiver Logo
190 people viewed this question
Top Pioneer GPS Experts
isaac johny
isaac johny
Are you a Pioneer GPS Expert? Answer questions, earn points and help others
