Question about McCulloch FHH18A Electric Pressure Washer
Small crack in the wand.
I have a small crack in the wand (PA6630GF). Is there anywher that ships to Canada, that I can get this part. TIA.
  • 3,740 Answers
This part number is for the wand and hose assy 41 7228-H18A01 WASH MANCHINE HAND ***'Y
This is the manual I used: http://ipl.ordertree.com/ipl/604/FHH18A.pdf
It is available from this source: http://www.ordertree.com/ModelInfo.asp?Final=1&SiteID=1&Mfg=139&Model=FHH18A click on the 4th item with the part number above listed and add to cart. $35.93
The shipping fees are listed here: http://www.ordertree.com/cms/shipping-policy/14.html
$9.95 + $12/95 for Canada shipping
If this is not your model or not part of what you needed just respond here and I will get back to you. Please ensure you include your exact model number when responding.
Thanks for using FixYa.
Kelly
Posted on May 17, 2010
Testimonial: "Thanks. They are out of stock but found a universal kit from RONA."
Model FH130B, part # 6021-150002B, Main wand,where can I get one,Brantford,Ontario,Canada
try Northern Tool + Equipment at NorthernTool.com. They have quite a few accessories available.
Jul 05, 2014 | McCulloch Garden
Wand jammed in shark vacuum after being placed backwards in the machine
Lubricate the wand near where it's stuck with a small amount of soap and water solution...small enough not to go any place it shouldn't. Then just wiggle it back and forth until it becomes free.
Nov 07, 2013 | Shark Navigator Bagless Upright Vacuum
I have my Incanto Deluxe for about 1 year. I have never had any problem making a good quality froth, but recently the frother is producing too much air and milk is becoming bubbly. I am religesly clean my...
I think you have a chrome steam wand end.
To froth properly, there is a very small hole on the side of the chrome steam wand that injects small bubbles into the milk, the hole is located aprox 1/4" down from top of the chrome wand, if this hole blocks up you can only heat the milk, not froth. I commonly use a stripped tin tie wire or a sewing needle to clear the hole . Clean the hole,do not enlargen the hole.
Mar 02, 2009 | Saeco INCANTO DELUXE Espresso Machine
Rival Slow Cooker Control Knob
Try going to MarBeck.com they are a great source for small appliace parts.
http://www.marbeck.com
Nov 30, 2008 | Rival 3060 6-Quart
Sparks bluish bright purplish? very small sparks, after plugging in to wall socket. also rythmically every 3 seconds a cracking sound is heard concomittantly ..???!
Sounds like it needs a good cleaning. Does this one have the metal bars that pull out? I have a ionic pro and when it gets dirty it will emit small sparks where the dust connects from one bar to the other. It also has a pull up wand that cleans the wire that help build the charge. If this is the system that changes the charge on the ions to attract them to plates, you will see small sparks when it becomes dirty. Mine always let me know by the sparking sounds it makes.
Aug 02, 2008 | Bionaire BAP825-U Air Purifier
Steam Wand Broken
Something is stuck inside the wand. Get a small pice of wire or small paperclip and inset and try to clear the blockage
Nov 12, 2007 | FrancisFrancis! X3 Espresso Machine
Toshiba 32A10 Sound but no Picture, Red Light Blinking
Your set has cracked solder joints, most likely on one of the small regulator transistors on the main board, with its own little heat sink. I have seen that many, many times, and it is a very simple thing to correct. Loose solder joints on the vertical output IC can cause no picture too, but it is usually those regulators that cause the problem. The set needs to have those regulators, the vertical output IC and all other major components resoldered and the set will play fine. If you do not have experience resoldering small parts on PC boards, allow a qualified tech to handle it for you.
Sep 03, 2007 | Televison & Video
McCulloch FHH18A Electric Pressure Washer Logo
1,128 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
