Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Intec saltwater genrator on a hot tub ?
Can i us a krystal clean salt water generator on a hot tub
  • Anonymous Mar 13, 2014
    Salt controller is flashing "err". What shall I do to fix it.
  • Intex Master
  • 8,404 Answers
Probably ... but that is a lot of unnecessary expense for such a small body of water.
Posted on May 16, 2010
Can intex krystal clear saltwater system be used on 12000 gal. above ground pool?
personally, my opinion is no. if you have a real pool, get a real salt system.
Sep 08, 2014 | Intex Automatic Salt Water System for ...
Why is my saltwater pool turning green?
balance the water with chlorine super shock it once in balance your chlorinator should maintain a chlorine reading if you have a heavy bather load you must shock manually
Jul 29, 2014 | Intex Krystal Clear Saltwater System Pool...
Help with low flow on intext krystal clear saltwater system.
You can check the inlet line where it comes from the pool... Their is a little sreening/filtering system in the the parts that screw together and connect the valve to the pool... When I unscrewed mine, it was jammed with bugs, leaves, green algea... That did the trick for me... I am sure you already changed/cleaned the filter in the filter/pump that comes before the Salt water system... That will cause low flow as well...
Jun 04, 2014 | Intex Automatic Salt Water System for ...
Why is my intex pool water turning green even with the saltwater chlorniator
enough salt? too much salt?
running enough hours per day?
adequate flow to activate salt cell? (cf dirty filter)
Salt cell clogged with calcium deposit?
Jun 21, 2012 | Intex Krystal Clear Saltwater System...
I have an Intex Krystal Clear Saltwater System, model CS8111. My problem is green water. I had been out of town for a few days and when I came home the pool was green. Also the low salt light was on. I...
If your salt is at the correct levels required for your pool and your still getting the "91" code on your LCD screen do not add more salt you need to clean the plates on the chlorinator. Look at your manual and it gives you instructions on how to remove, clean, and replace the chlorinator section on the pump. Reminder, if your PH and/or alkalinity levels are off you'll be cleaning the plates often because of the scale build up. I personally run my pump 4 hrs daily and I have never had a problem with green water however, once it did become cloudy (white) I began treating with algaecide and changing filter every 3 hrs. It cleared it right up. I love the Krystal Clear System.
Jun 26, 2011 | Intex Automatic Salt Water System for ...
I have installed my Intex Krystal Clear Saltwater system for my above ground pool and have run it for 12 hours. I want to run it another 12 hours. How do I start the system again instead of waiting on the...
First of all you should not have set it to generat chlorine until straight filtering for 24 hours. unplug then plug it back in
88 will appear let your salt disolve by filtering only for the 24 hours then proceed to generate chlorine
It may look disolve but there are many hot spots that need to get distributed eveny
Jun 07, 2010 | Intex Automatic Salt Water System for ...
High ph, algea, salty taste
You are going to need to buy chemicals anyway (acid for sure and probably algaecide) so find a good pool store tech and have them test your water and recommend the proper doses.
In summary though, you should not taste the salt in the pool and being able to means the salt content is to high. Chlorine generators will not work if the salt is to high and the fix is to drain water and dilute the remaining water until the salt content is no higher than max. No chlorine could explain the algae.
Generators also cause the pH to rise over time so you will need to keep acid on hand to counteract that.
Jul 05, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
148 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Charles T Nevin
Charles T Nevin
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
